Old April 9th, 2017, 08:21 PM   #1
acook3323
Motorcycle(s): 2005 ninja 250
Cooling system help
05 250 temp guage wont go above abput 1/4 cooling fan wont turn on. Flushed the system and bled it as well
acook3323 is offline   Reply With Quote
Old April 9th, 2017, 08:32 PM   #2
juliusmichaelhonrada
Motorcycle(s): GPX250-RII
i dont really see that as a bad thing well in my case because im in a tropical country hehe ,you can check the thermostat if its not closing. fan turns on just about the redline if its an ex250f , if its a zzr250 fan turns on at half temp
juliusmichaelhonrada is offline   Reply With Quote
Old April 9th, 2017, 08:38 PM   #3
acook3323
I ran the bike for about 20 minutes amd didnt crack 1/4 im just worried that something may not be readong roght and it will overheat.
Old April 9th, 2017, 09:02 PM   #4
The temperature gauge with its sensor, and the cooling system thermostat, and the fan switch are three different things. If the gauge malfunctions, the cooling system thermostat can still control the coolant flow through the radiator, and the fan switch can still turn on the fan.
Idling in neutral will test all three, within reason. You should see the temperature gauge climb slowly, and as JMH said, when the gauge gets high enough the fan should come on. As long as the temperature then drops somewhat, you know the cooling system thermostat has opened to let coolant flow through the radiator.
All three can be tested if necessary.
Old April 9th, 2017, 10:00 PM   #5
yeah you may have a malfunctioning gauge , or a bad radiator ground that the sensor needs to operate correctly
Last futzed with by juliusmichaelhonrada; April 9th, 2017 at 11:22 PM.
Old April 9th, 2017, 10:46 PM   #6
acook3323
It only reads up to 1/4 and doesnt move at all
Old April 10th, 2017, 06:51 AM   #7
Yes, so your temperature gauge sensor or the gauge itself may have a problem. My point is that's not related to the thermostat that controls water flow, or to the fan thermostat.
Old April 10th, 2017, 06:53 AM   #8
Ram Jet
Ram Jet's Avatar
Cardboard
Try covering the radiator with a piece of cardboard and tape and take it for a short ride. You should see a change.
http://shop.watt-man.com/Thermo-Bob-...EARS-TB3-N.htm
I'm considering installing one of these kits on my 2007.
Old April 10th, 2017, 07:03 AM   #9
taz
taz's Avatar
MOTM - May '17
don't wast your money
Old April 10th, 2017, 07:09 AM   #10
Ram Jet
Ram Jet's Avatar
Tell me more
Have you had experience with this kit? I sure don't want to toss-away $129.00 on snake oil. This guy really talks-up a storm about this product.
A Sucker born every minute?
Old April 10th, 2017, 07:18 AM   #11
hahah yeah i thought his temp never goes up to 1/4 could be a free flowing thermostat
Old April 10th, 2017, 07:41 AM   #12
True, JMH. When in doubt, test the parts.
Adam, you can test the thermostat by removing it from its housing and putting in a pan of water on the stove. By the time the water boils, you should see the valve open.
You can test the fan switch and the gauge sensor similarly, if you have an ohm meter.
Here is a page that describes the cooling system, and it has a troubleshooting link:
http://faq.ninja250.org/wiki/Cooling_system
Old April 10th, 2017, 10:36 AM   #13
greg737
Motorcycle(s): -
I'm betting TAZ doesn't know what he's talking about.
Here's the deal with the Thermobob:. All modern water-cooled vehicles (both cars and motorcycles) have small radiator bypass lines built into the cooling system. The EX250, which is an old design, does not have a small constant-flow radiator bypass line. The lack of this design feature causes the EX250's thermostat to act in strange ways, the foremost of which is that the thermostat is often full open when it really doesn't need to be, which is why the EX250 has a reputation for being "a cold blooded reptile" (except when you live in a tropical climate).
I've had a Thermobob on my '05 EX250 for about 7 years now and I really like the difference it makes in the bike temperature behavior. I even did a do-it-yourself constant bypass line on my '93 Suzuki GSF400 which made that bike better also.
Old April 10th, 2017, 11:13 AM   #14
Ram Jet
Ram Jet's Avatar
Thank you1
[QUOTE=greg737;1168177]I'm betting TAZ doesn't know what he's talking about.
I've had a Thermobob on my '05 EX250 for about 7 years now and I really like the difference it makes in the bike temperature behavior. I even did a do-it-yourself constant bypass line on my '93 Suzuki GSF400 which made that bike better also.[/QUOTE
You said very concisely in one paragraph what it took this guy at Thermobob 12 pages with graphs and visuals to do. You basically said what he said only I understand your explanation far better. Your 7 year experience with this product has cinched-up a sale for Thermobob. Thanks.
Bill
Old April 10th, 2017, 11:57 AM   #15
arnvc
Motorcycle(s): ex250
also have a therm o bob, keeps water temps within aboot 20 degrees, stock thermostat had aboot 90 degree swing on average ride . stock thermostat diameter at hose is aboot 3/4 inch, therm o bobs is 5/8 inch diameter.
arnvc is offline   Reply With Quote
Old April 10th, 2017, 12:47 PM   #16
acook3323
Do you know the part # foe that sensor. I want to make sure im looking for the right thing
Old April 10th, 2017, 01:13 PM   #17
Ram Jet
Ram Jet's Avatar
Thanks to you too
I'm getting it as soon as payday rolls around!
Bill
Old April 10th, 2017, 02:42 PM   #18
acook3323
Do you happen to have the part # just to be sure im getting the right part
Old April 10th, 2017, 02:57 PM   #19
I do not, sorry. Which one are you trying to identify? A gauge stuck low could be:
1. A defective gauge
2. A defective sending unit for the gauge (gauge temperature sensor)
3. A thermostat stuck open (the one in the thermostat housing that controls water flow)
Are you saying that if you let the bike idle or drive it around very slowly for like 15 minutes, the gauge never gets up over about 1/4 of full scale?
Old April 10th, 2017, 03:26 PM   #20
acook3323
I do rides back and forth of 25 to 50 mph and it doesnt go above 1/4. It may be fine but i just want to be sure before im stuf on the side of the road due to overheat. Im looking for the guage temp sensor
Old April 10th, 2017, 03:38 PM   #21
There should be a procedure for checking its resistance with a meter while heating it in water. Offhand, I can tell you that its resistance should decrease when it's heated.
Checking the coolant thermostat is also simple, as I said above. Take it out and look at it. When cold, it should be closed. Put it in a pot of water on the stove, and by the time the water is boiling, you should be able to see that it's opened. In your case, if it's causing your engine to stay too cool, you'll see that it's open at room temperature.
If I keep my 250 between 25 and 50 mph, the temperature gauge behaves about like yours. I'd hate to see you buy a new sensor, then find it doesn't change anything, so you buy the next thing, and end up replacing everything and find out it was all working properly.
Old April 10th, 2017, 03:44 PM   #22
Another pro-thermo-bobber here.
The bike no longer rides differently in the cold vs the heat. I no longer need cardboard on the radiator in late fall. I don't have to ride gently for nearly as long when I first start it. The temp gauge comes up and stays there, no questions asked. I was even able to make the gauge work properly with it, so it's literally no difference from the cockpit, aside from a smoother running engine. The bikes should come from the factory like this.
Old April 10th, 2017, 04:25 PM   #23
Ram Jet
Ram Jet's Avatar
Installation
Is installation difficult?
Bill
Old April 10th, 2017, 04:59 PM   #24
No, not at all. If you're capable of flushing the coolant system, you're capable of installing a thermobob.
Old April 10th, 2017, 05:54 PM   #25
Ram Jet
Ram Jet's Avatar
Thanks
I can do the cooling system flush. I feel that if I can successfully adjust the valve clearances on the 250 I could accomplish a moon launch! This is definitely the most difficult valve clearance maintenance I have ever run into. That includes a 1959 Alfa Romeo Spyder Veloce and a Suzuki GS750. Installing Thermo Bob ought to be up there with a beer blast.
Thanks,
Bill
[motorcyclistonline] - How To Service Your Cooling System On Your Motorcycle Ninjette Newsbot Motorcycling News 0 July 21st, 2016 07:00 PM
[motorcyclistonline] - MC Garage Video: How To Service Your Motorcycle Cooling System Ninjette Newsbot Motorcycling News 0 June 17th, 2016 02:10 PM
[visordown.com] - New RG introduce range of coloured cooling system guards Ninjette Newsbot Motorcycling News 0 October 28th, 2014 08:30 AM
fun with cooling system, and wiring a fan switch marc_previtera 1986 - 2007 Ninja 250R Tech Talk 5 June 17th, 2013 07:03 PM
Cooling System Issues AlfredoGonzalez 1986 - 2007 Ninja 250R Tech Talk 8 January 4th, 2013 02:14 PM
