Old February 24th, 2020, 12:50 AM   #1
Rafeeq
Motorcycle(s): Kawasaki gpz 400R
Smile Hi all im from Cape Town
Hi all, I have a kawasaki gpz 400R. So my bike starts only on choke and dies when choke is closed. If I adjust the idle screw it idles without the choke being on but the moment I blip the throttle the revs hang at 3/4 rpm and then when I down adjust the idle screw the bike dies again... The other issue im having is the bike runs well for a couple of km then all of a sudden fuel supply to my carbs is no longer flowing. I then remove the fuel line from my tank and blow into the line to hear if its blocked but its not cause I can hear air going into the float bowls and after I blew I put the fuel line back into my tank and open the tap and fuel starts flowing with ease again... My tank was cleaned and my carbs were taken off and thoroughly cleant using compressed air and there were no blockages, I replaced the diaphragms and springs aswell as the float needles. I adjusted the pilot air screw to factory settings which stated 2 full turns out. Further more I dont know what to do and need advice.
Rafeeq is offline   Reply With Quote
Old February 24th, 2020, 01:22 AM   #2
lizardywizard
green stig
lizardywizard's Avatar
Motorcycle(s): '15 Ninja 300 ABS (Hurricane)
MOTM - May '16
Rafeeq! Glad to have you aboard...
You treat her like a lady. And she'll always bring you home. --Admiral Leonard H. "Bones" McCoy
lizardywizard is offline   Reply With Quote
Old March 14th, 2020, 07:06 PM   #3
Snake
Snake's Avatar
Hello and welcome!
Old March 15th, 2020, 06:32 AM   #4
snot
sammich maker
snot's Avatar
MOTM - Apr '15
Welcome @Finesse might be able to suggest a fix.
Old March 16th, 2020, 05:25 PM   #5
CaliGrrl
CaliGrrl's Avatar
Motorcycle(s): Ninja650
Welcome!
Old March 17th, 2020, 12:41 PM   #6
Ceeloo Yello
Motorcycle(s): 250
Aloha
New Owner from Cape Town, South Africa paper New Members 12 December 10th, 2014 07:46 PM
Hi from Cape Town raphaeltube New Members 10 August 25th, 2013 05:56 AM
[webbikeworld.com] - Alpinestars Cape Town Jacket Review Ninjette Newsbot Motorcycling News 0 August 12th, 2012 06:50 AM
[visordown.com] - Cape Town police confiscate driver's phones Ninjette Newsbot Motorcycling News 0 July 12th, 2012 06:10 AM
[motorcyclenews.com] - Video: Nick Sanders gets his Yamaha R1 serviced in Cape Town Ninjette Newsbot Motorcycling News 0 June 25th, 2008 04:35 AM
