Old January 16th, 2010, 03:35 PM   #1
Betlog
Betlog's Avatar
Motorcycle(s): 2009 250r
Engine bogging down on start
Hi guys. When I am at low revs (below 4k RPMs), I feel the engine is bogging down. This is most usually the case when I first ride. After about 30 mins or so of driving, then it is not as bad. Sometimes at a stop, the lag is as much as 2-3 seconds. I have 200 miles so far and I do warm it up approximately 2 minutes before riding. Any suggestions?
Betlog is offline   Reply With Quote
Old January 16th, 2010, 03:53 PM   #2
tapdiggy
Humble Observer
tapdiggy's Avatar
Motorcycle(s): 2009 Yamaha XT250
Hey noob. Was this bogging happening when you bought the bike?
Everything I post is "IN MY HONEST OPINION".
Why is "Parking Lot Enduro" not a thing?
tapdiggy is offline   Reply With Quote
Old January 16th, 2010, 04:06 PM   #3
Betlog
Betlog's Avatar
That is a good question. It might have been. I probably just couldn't feel it then as I am very inexperienced and I was not very smooth. Now that I am getting the hang of it, I am feeling more of the bike's intricacies...
Old January 16th, 2010, 04:14 PM   #4
tapdiggy
Humble Observer
tapdiggy's Avatar
I meant to ask also what year is your bike, and were you the first owner?
Old January 16th, 2010, 04:16 PM   #5
Betlog
Betlog's Avatar
Yes. I got the bike new, it's a 2009.
Old January 16th, 2010, 04:21 PM   #6
tapdiggy
Humble Observer
tapdiggy's Avatar
Is it happening when you start from a stop, or is it when you stop?
Old January 16th, 2010, 04:23 PM   #7
tapdiggy
Humble Observer
tapdiggy's Avatar
Hope you don't mind all the questions. They will lead to more solid advice.
Old January 16th, 2010, 04:23 PM   #8
Betlog
Betlog's Avatar
This is most noticeable starting from a stop.
Old January 16th, 2010, 04:27 PM   #9
tapdiggy
Humble Observer
tapdiggy's Avatar
Ok, we may be getting somewhere. Are you giving it a lot of throttle pretty quick or are you applying smooth, steady twist?
Old January 16th, 2010, 04:31 PM   #10
Betlog
Betlog's Avatar
Decent amount of throttle. More so than I used to do when I first got it as I was inexperienced then...
Old January 16th, 2010, 04:39 PM   #11
tapdiggy
Humble Observer
tapdiggy's Avatar
Ya, I was sheepish with the throttle at first also. So are you twisting quickly on it or building it up smoothly? And how are you at letting the clutch engage?
Old January 16th, 2010, 04:42 PM   #12
Betlog
Betlog's Avatar
I let the clutch disengage smoothly. At this point, I am only on the gas but then I notice the engine bogging down, I apply more throttle, but then it just moves at the same rate, then all of a sudden after a second or two, I get a burst of torque.
Old January 16th, 2010, 04:47 PM   #13
tapdiggy
Humble Observer
tapdiggy's Avatar
Ya, I just talked to Plasmatoast. He says their is a deadspot in the low RPMs when the bike is cold. Try warming up longer, with tyhe choke on.
Old January 16th, 2010, 04:51 PM   #14
Betlog
Betlog's Avatar
Truong. Thank you for all your help on this. I'll do that and keep an eye on this and will post again if it becomes a bigger issue. Thanks again bro!
Old January 16th, 2010, 05:02 PM   #15
tapdiggy
Humble Observer
tapdiggy's Avatar
Glad to help. Hope my advice was good.
Old January 17th, 2010, 09:04 AM   #16
g21-30
g21-30's Avatar
Can't believe no one mentioned this!
http://www.ninjette.org/forums/showthread.php?t=11963
Old January 17th, 2010, 10:34 AM   #17
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
+1
Old January 17th, 2010, 11:47 AM   #18
tapdiggy
Humble Observer
tapdiggy's Avatar
Shimming the needles was outside the immediate scope of this troubleshoot. It is rational to improve upon basic technique (ie, longer warm-up period) before simply chalking it up to a supposed shortcoming in the machinery.
Old January 18th, 2010, 12:33 PM   #19
g21-30
g21-30's Avatar
Originally Posted by n00br1d3r View Post
Hi guys. After about 30 mins or so of driving, then it is not as bad.
This is a perfect example of an engine that needs to have the needles shimmed! 30 minutes warmup is totally unacceptable! My bike was the same way and that was with the air temp at 70 degrees! The temp can be in the teens and I can drive away after 2 minutes of warmup.
Old January 18th, 2010, 05:18 PM   #20
Plasmatoast
Plasmatoast's Avatar
Motorcycle(s): 09 250R - 08 250R - 03 250EX - 86 KLR 250
when tapdiggy asked me about my bikes I thought he was asking about start up.. definitely need to do something if the bike acts like this for 30 minutes, Shimming the Needles is a good, quick, and relatively inexpensive place to start. Be very careful of the screws on the top of the carbs, and the rubber diaphragms that the needles are in.
Plasmatoast is offline   Reply With Quote
Old January 18th, 2010, 06:44 PM   #21
Samer
Samer's Avatar
Motorcycle(s): 09 Ninja 250R SE
Do you turn the choke off before riding it? I haven't done any mods on my bike and I haven't had too much trouble getting it warmed up quickly. I put the choke on and start it, then I gradually reduce choke to keep the RPM at about 2500, once it is settled with the choke at about half way (maybe 5 minutes), I start riding the bike and as it is moving I turn off the choke as I'm applying throttle. This works fine for me.
Samer is offline   Reply With Quote
Old January 18th, 2010, 07:04 PM   #22
Chubbs032
Motorcycle(s): 250r
Shim the needles and desnorkle, it's a night and day difference.
Chubbs032 is offline   Reply With Quote
Ninja 250 engine won't start. Bwdeaton 1986 - 2007 Ninja 250R Tech Talk 9 March 24th, 2015 11:15 PM
Engine won't start. Clicking sound zzrguy 1986 - 2007 Ninja 250R Tech Talk 17 October 27th, 2014 08:25 AM
Engine bogging at speed. Sometimes wants to die at idle broilmebk 2008 - 2012 Ninja 250R Tech Talk 11 September 10th, 2014 07:45 AM
engine bogging down az3200 1986 - 2007 Ninja 250R Tech Talk 13 August 7th, 2013 01:22 PM
Bogging on start Betlog 2008 - 2012 Ninja 250R Tech Talk 12 March 17th, 2010 05:32 PM
