Old July 17th, 2022, 04:57 AM   #121
petrolhead
Budget limitations mean I'm also the team's seamstress and electrician.
petrolhead is offline   Reply With Quote
Old July 20th, 2022, 01:48 AM   #122
petrolhead
The two sets of warmers I have, were bought second hand. And they're not the most hitech to begin with.
When we get to trackside, putting them on is the first thing I do. Front goes on first and comes off last. I keep a blanket with aluminium foil on top of the front heater.
I'm not so much concerned with the surface temperature. More interested that the heating time is long enough. Rubber in itself is a heat insulator. Takes a long time for it to be hot on the inside too.
I realized that that philips head screw on the filler cap assembly is just an anti theft measure. Can't remove the assembly without out a key. I took the screw out. Now, should I ever forget the key, the bike is still operable.
Last futzed with by petrolhead; July 23rd, 2022 at 09:22 AM.
Old July 24th, 2022, 02:57 PM   #123
petrolhead
Google maps link to the karting track we call our home circuit.
https://maps.app.goo.gl/HdAGKoSMujQDJKbp7
Narrow, short, twisty. Great for training riding technique. 8 metres elevation change in a small space. Reasonable run off areas, low top speeds. So I can tell my son to just go for it.
My boy's favorite, Pesämäki circuit at Honkajoki, Finland.
https://maps.app.goo.gl/Ay6z9nsbgKfQeiLj8
Just perfect for a youngster with a 250. A lot faster than a karting track, half the size of a proper racing circuit. 400 metre main straight, 5th gear.
Last futzed with by petrolhead; July 25th, 2022 at 03:57 AM.
Old July 24th, 2022, 05:27 PM   #124
Oooh, very nice!!! Since track-day season is over for summer-break and racing won't start up again until Sept., I've been going to PKRA weekly - https://goo.gl/maps/3zSio5kgVa2FrMtG6
However, N250 is too big for this track, I'm stuck between 1 & 2nd-gear most of time. Looking for smaller lighter (100kg max) 65-100cc 2-stroke bike. Something like Kawi KX65/85 or Honda CR85R...
Last futzed with by DannoXYZ; July 26th, 2022 at 09:37 AM.
Old July 25th, 2022, 03:57 AM   #125
petrolhead
However, N250 is too big for this track, I'm stuck between 1 & 2nd-gear most of time. Looking for smaller lighter (100kg max) 65-100cc 2-stroke bike. Something like Kawi KX65/85 or Honda CR8R...
Closest possible gearing is the answer for karting tracks. Rev drop between 1-2 is massive. 2-3 is a lot better, noticeable everywhere.
We're currently at Pesämäki circuit. So far 3 seconds quicker than last year.
Edit: 4,7 sec improvement from last year. 3km/h higher top speed. On shorter straights almost 10 km/h faster. I'll compose a video at some point. Morning warm up plus 43 timed laps.
Last futzed with by petrolhead; July 25th, 2022 at 12:05 PM.
Old July 26th, 2022, 05:44 AM   #126
petrolhead
I could swear replacing the front warmer's power cord with a thick one with good connections made it heat up better.
I haven't got previous years' data available anymore, but jugding from videos the apex speeds were now higher and he opens the throttle earlier on exit.
Last futzed with by petrolhead; July 27th, 2022 at 01:02 AM.
Old August 2nd, 2022, 11:51 PM   #127
petrolhead
Current specs
Since I cant edit the opening post, here's a recap of the current specs:
- race fairings, DIY foam seat from a camping mattress
-Michelin Power Cup evos(110 & 140), Bstone R11s in storage
-13/48 sprockets (others in storage)
- ~0,5kg battery
-1,5kg DIY muffler v 2.0
-DIY rear sets
-tank grips
-some cheap clip ons with soft Renthal grips
-Front brake Brembo P30/34 caliper, stock disc
-Braking 16mm radial master cylinder
- ~8% quicker throttle
-about 140kg or bit less with couple liters of fuel. Nonessential wiring and most brackets deleted. Kickstand, its bracket and aux parts deleted.
-Stock suspension, bit thicker oil in forks.
-Rear wheel pushed as far forward as it can fit.
-Ignition lock deleted
Last futzed with by petrolhead; August 7th, 2022 at 09:06 AM.
Old August 5th, 2022, 12:05 PM   #128
petrolhead
I was familiarizing myself with stuff related to swapping the engine. The new motor came without clutchparts, stator etc.
Now the factory manual says the clutch outer basket needs to match the crank gear. Match color markings and choose the right part number accordingly. I'm guessing this has to do with tooth clearance between them. Does anyone have practical experience of this? I was going to swap the old clutch stuff to new engine. Thinking am I allright if I measure the tooth free play before and after and call it good if it's not very wrong.
Old August 5th, 2022, 01:31 PM   #129
yeah, should be OK.
Old August 7th, 2022, 08:46 AM   #130
petrolhead
The rider mentioned that the throttle travel feels long/difficult on certain spots of track. So..
14,90€ minus company discount, throttle tube with a set of cams/rings whatddoyacallem. I had previously used some 2 component plastic repair goo to get little more diameter. It was now 37mm, the new one is bit over 40mm. Not a big change but surely helps some. For some reason it took a lot of filing and sand paper to have smooth operation and return. Lot of my mods are like this. Get the cheapest solution and then spend half a day trying to make it fit and work.
Old August 8th, 2022, 11:36 PM   #131
petrolhead
Does anyone have an opinion which are better, Wiseco or JE +2mm pistons? I read somewhere that they're heavier than original? Can't find the info right now.
Edit.. JE pistons are apparently 140-148 grams. Other info still appreciated, including the weight of originals.
Last futzed with by petrolhead; August 9th, 2022 at 02:42 AM.
Old August 9th, 2022, 08:47 AM   #132
Both heavier than stock.
Check with Spears Racing for upgrade parts. He's been most helpful to me over the years.
Budget builds can use even better parts. +4 +5mm over using ZX-6R cylinders and pistons. Buy used on ebay for $20-30. Press out factory cylinders, machine block for ZX-6R cylinders, install pistons, done!
Look up bruce71198's builds. He's gotten double factory power.
Old August 9th, 2022, 11:50 AM   #133
petrolhead
I'm not looking for the very last hp and cost be damned. Nor am I ready yet to start hunting the last possible cc:s from this engine. My calculator says the engine makes 20,7 Nm @ peak power revs, 11000. 25 Nm is possible, 24Nm is feasible with 249cc. I'm interested in making a bit more torque a bit higher up the rev range. 40hp engine power is doable without over bore. I'm just asking for experiences different pistons should I go that route. I consider piston weight to be critical for the longevity of rods and bearings. Bigger bore would mean a Cometic head gasket, which are not without issues.
If I open up the engine and find that the cylinders and pistons are in top condition, I won't replace them just for the hell of it. Then I'll concentrate on the top end.
Spears. They'd be one mighty expensive set of jugs once they reach me. Add VAT, postage and customs to their price tag. I don't doubt their quality.
Last futzed with by petrolhead; August 9th, 2022 at 01:24 PM.
Old August 19th, 2022, 04:06 AM   #134
petrolhead
What kind of engine power or RWHP have people gotten with the stock ITBs, which are 28mm? I'm not completely sure whether they'll be a restriction.
Old August 19th, 2022, 03:12 PM   #135
I've gotten 32-33rwhp with factory carbs +24%. They're not much restriction. Main restriction is intake-ports inside head. Compare 250 head with 300 head and you'll major differences.
Old August 20th, 2022, 12:07 AM   #136
petrolhead
You are talking about carburetor which I undestand are 30mm a piece. Injection ITBs are 28mm. Difference in cross sectional area is (30/28)² , right? That's almost 15% more.
Edit. We were at the Akaa track again today. He got to ride behind a much faster supermoto, improved his lap time quite a bit. He seemed to think the "new" tyres have much less slip. I lowered the hot pressures some, no ill effect. I've kept fairly conservative (high) pressures on them until now.
Some repeating gear shifting problem between 3 and 4. We do have the spare engine package, should solve that problem. The quicker throttle was a noticeable improvement the rider reported. I was skeptical whether it would help since the change is small. No complaints about the shortened foot pegs.
Last futzed with by petrolhead; August 20th, 2022 at 10:39 AM.
Old August 20th, 2022, 01:55 PM   #137
EFI 250 ends up with +5bhp more than carby models for same mods due to ability to precisely adjust fuel-maps ~36rwhp. I doubt TB is restriction. Take look at intake ports in head. They are much, much smaller than TB size. Where do you think major restriction exists?
It's like funnel with small [outlet]. You can increase diameter of inlet all you want. But flow-rate is limited by smallest section in path.
Last futzed with by DannoXYZ; August 21st, 2022 at 01:10 AM.
Old August 20th, 2022, 10:54 PM   #138
petrolhead
It's like funnel with small inlet. You can increase diameter of inlet all you want. But flow-rate is limited by smallest section in path.
You are correct. I'm all about measuring and calculating stuff. I googled a whole lot ITB sizes for different engines and ran the figures to get some idea. Namely about how much cross sectional area per cylinder hp the manufacturers have in ITBs. That got me thinking our bike's parts might be on the small side.
Edit, I did just that. Inlet port is under 28mm and narrows down from there.
Short video from yesterday, quickest lap is lap 14
Last futzed with by petrolhead; August 25th, 2022 at 02:34 AM. Reason: typo
Old August 21st, 2022, 09:03 AM   #139
petrolhead
The ergonomics have some what changed from stock
Old August 21st, 2022, 09:48 PM   #140
Yes, I prefer handlebars around seat-height. Chopped top of fairings off so I can lower bars 15cm.
Old August 26th, 2022, 08:51 AM   #141
petrolhead
When I repaired the front forks I set the oil level to exact factory specification. If I were to run more oil in them, how much is safe?
Old August 28th, 2022, 02:06 AM   #142
petrolhead
I have a long list of actually neccessary things I need to do on the bike. But, I'm planning on making the silencer bracket from titanium so save weight.
Old August 28th, 2022, 09:16 AM   #143
petrolhead
We measured the suspension sag . Front is OKish, rear too stiff. I lowered the rear one click, raised the front by 11mm to about stock height. My fork oil level question had to do with this. My thinking was, smaller airspace might raise the effective spring rate a bit. The rider said he'd be happier braking late and carrying a bit brake pressure in to corner entry if the front didn't pitch so much. Another zero budget idea I had was to add shims on top of the springs to raise the preload.
Old August 28th, 2022, 10:51 AM   #144
I believe you can add 3cm of extra oil to reduce air-volume. That seems to be amount Racetech suggested with their springs when I installed. Along with more preload should reduce diving under braking.
Old October 20th, 2022, 12:50 PM   #145
Ornithology
Motorcycle(s): 250
Originally Posted by petrolhead View Post
I repaired the forks this spring (leaks), and replaced the oil with 15W instead of the 10W recommended by shop manual. Otherwise the suspension is stock. It's mainly ridden by a 50kg person so it's not too soft.
The seat foam I cut from an old camping mattress. My son seems happy with the bike, which is the point of the whole exercise.
Did you make that seat yourself? I have been looking for a superbike seat for the 250 with no luck.
Ornithology is offline   Reply With Quote
Old October 21st, 2022, 02:40 AM   #146
petrolhead
Yes but it's just the padding, the seat has no frame as it's on top of a race fairing which supports it.
Old May 11th, 2023, 10:01 PM   #147
petrolhead
Reason that the old thermostat was dripping.
I'm currently replacing the engine.
Old May 19th, 2023, 10:34 AM   #148
petrolhead
What is the function of the secondary throttles and what happens if I leave them out including their electrical parts?
Still waiting for a pile if seals and such I ordered a week and a half ago.
Old May 19th, 2023, 01:48 PM   #149
Secondary throttles eases transition from fully-closed throttle to off-idle smoothness. Can be sudden with jerking. You can disable it and if engine-response still smooth, leave disabled.
To smooth jerking without 2ndaries, you can use non-linear throttle-cam. First 5-10 degrees rotation pulls on cable very little. Then pulls more cable for same rotation-angle from then on.
Old May 20th, 2023, 03:35 AM   #150
petrolhead
OK, thanks. The bike is only ridden on track so with 30hp the throttle is on/off anyway. My thinking was that they don't help air flow plus they weigh something. I m guessing the two electrical parts for them are the throttle motor and the other a position sensor. If they are removed ECU receives illogical signals from them, does it cause some sort of limp mode.. maybe I'll leave them be for the moment.
Hollow bolt heads weigh less .
Last futzed with by petrolhead; May 25th, 2023 at 06:38 AM.
Old June 30th, 2023, 05:56 AM   #151
petrolhead
Seems to run fine despite the repairs and mods . Currently at Ahvenisto racing circuit ( google it).
No pops and bangs when on engine braking, rider reports gears engage effortlessly.
Last futzed with by petrolhead; June 30th, 2023 at 09:05 AM.
Old July 1st, 2023, 04:23 AM   #152
petrolhead
Not much to see in this video, the camera mount is broken and the picture is all shakes and such. At first I thought I wouldn't upload it at all.
He's taking it very easy round the track, because I told him to. It's a dangerous place for a bike. No runoff, off-cambered corner, couple fast turns and very big elevation changes. Bikes don't race there.
Yet he still improves his lap times there and seems to like the track.
I did an experiment. I bought the cheapest motorcycle oil with correct viscosity and reuquired classifications ( standards, what do you call them). Bike runs nice, clutch works just fine.
On finnish-speaking forum there's always a lot of talk how you need to switch to this or that expensive oil to solve any powertrain issue. I for one don't believe in any snake oils or wonder lubes.
Last futzed with by petrolhead; July 5th, 2023 at 01:38 AM.
Old July 4th, 2023, 07:13 AM   #153
petrolhead
This is a "work in progress" piece. Lighter muffler bracket. 20% lighter now than the old one and will be much lighter still once it's finished. 3mm titanium.
Naturally, it works with shorter bolts than original so saving weight there .
While I was at it, I did a quick repair on the muffler. It had a leak from when the bike went down last season. While leaking, it produced 90,8dB .
Last futzed with by petrolhead; July 4th, 2023 at 09:27 AM.
Old July 4th, 2023, 10:10 AM   #154
Awesome work you're doing! Titanium's great stuff. Are you able to source cheaply there? Still very expensive in U.S.
Old July 4th, 2023, 12:05 PM   #155
petrolhead
Thanks.
Cost me 0€. I've had that for many years. Donated by a guy who does very specialized metal work. From the markings I'd guess it's grade 2 titanium.
Old July 6th, 2023, 12:22 AM   #156
petrolhead
Currently at Ahvenisto. Switched from 48T to 47 rear sprocket. 4th and 5th match the two straights better.
Edit.. 3rd too, he managed to hit the limiter on a short back straight.
Wow. 10000 views on this topic.
Last futzed with by petrolhead; July 6th, 2023 at 08:19 AM.
Old July 10th, 2023, 09:13 AM   #157
petrolhead
Back from Pesämäki circuit. 38 timed laps, lap times and top speeds much improved from last year. I'll probably upload a video at some point. Rear Michelin starting to show it's mileage.
One almost-a-high side and one overtaken (street tyred) Fireblade.
Last futzed with by petrolhead; July 10th, 2023 at 12:25 PM.
Old July 11th, 2023, 02:29 AM   #158
petrolhead
I should probably start thinking about a mod to the clutch lever. Complaint was that it's heavy work going 6->5->4->3 on the longest braking zone lap after lap, if you release/pull between each shift.
The cable has got some empty travel before biting point. So.. changing the motion ratio of the lever/cable should be possible.
edit.. the amount of stuff I bring to the track just increases year by year. Bought a really cheap pit tent. See how long holds together.
Last futzed with by petrolhead; July 11th, 2023 at 04:39 AM.
Old July 11th, 2023, 12:01 PM   #159
Get teflon-lined clutch-cable housing.
There are also cables with die-drawn inner-wires with smoother surface for easier action.
Old July 14th, 2023, 11:46 AM   #160
petrolhead
Video from Pesämäki track
[superbikeplanet.com] - Reigning XR1200 Champ Barnes Looking For Sponsors To Help Fin Ninjette Newsbot Motorcycling News 0 July 1st, 2013 01:40 PM
[roadracingworld.com] - Updated: Moto2 Race At Mugello Is Three-Way Battle To The Fin Ninjette Newsbot Motorcycling News 0 July 3rd, 2011 10:40 PM
Sneak peek : hi flow copper fin peformance radiator dlres 2008 - 2012 Ninja 250R Tech Talk 12 July 2nd, 2011 05:55 PM
[roadracingworld.com] - Team Suzuki Alstare's Fabrizio Looking For Another Podium Fin Ninjette Newsbot Motorcycling News 0 March 21st, 2011 12:50 PM
[roadracingworld.com] - Even More Previews Of This Coming Weekend's MotoGP Season Fin Ninjette Newsbot Motorcycling News 0 November 3rd, 2010 09:30 AM
