Old August 15th, 2022, 05:46 PM   #1
Patrizio
Clutch Replacement Help
Hello, my clutch seems like it is slipping when I go wide open throttle. The RPMs will go up but my bike will not accelerate / accelerates very slowly. If I gradually open the throttle, everything seems fine but wide open I am having this issue. It is like a loss of power wide open. Anyways, I think the clutch is slipping and wondering if anyone has any videos / diagrams / helps to help me inspect the clutch and / or step by step on replacement. Should I be replacing the whole clutch or just a friction plate / springs? Thanks
Patrizio is offline   Reply With Quote
Old August 15th, 2022, 07:28 PM   #2
Ceeloo Yello
Motorcycle(s): 250
Will this do?
https://faq.ninja250.org/wiki/How_do...ping_clutch%3F
Old August 17th, 2022, 12:31 PM   #3
Definitely sounds like it’s slipping, but have you checked the adjustments on both ends of the clutch cable? It’s possible that the clutch is not fully engaged.
Clutch Cable Replacement Trick/Tip Mechanikrazy 2013 - 2017 Ninja 300 Tech Talk 4 December 3rd, 2016 10:48 PM
Clutch replacement Jdero_620 General Motorcycling Discussion 11 April 1st, 2016 11:12 AM
clutch cable replacement james250ninja 1986 - 2007 Ninja 250R Tech Talk 3 April 20th, 2015 11:54 AM
Please help!! Clutch cable replacement complication Dustinfools 2008 - 2012 Ninja 250R Tech Talk 31 November 29th, 2012 01:34 PM
Clutch Replacement talisman.26 1986 - 2007 Ninja 250R Tech Talk 11 February 26th, 2012 01:35 PM
