Old June 11th, 2010, 11:23 AM   #1
DRivero
DRivero's Avatar
Motorcycle(s): 2001 Ninja 250 (Sold); 2008 Ninja EX500
Another tire question...
Okay, I have a silly question. I need tires. I've narrowed my choices down, but I'm stumped by something. My bike, as it came to me, has 100/80 16 front tire, and a 130/90 16 rear tire. I am quite short (slightly less than 5'2"). I'm not tippy-toeing on the bike, and I don't want to be, but some of the tires I'm looking at come in 100/90, not 80. So here is my question: since I already have a 90 on the rear, if I put a 90 on the front, will I notice, height-wise?
See, I told you it was a silly question.....
www.facebook.com/#!/profile.php?id=1568567524
DRivero is offline   Reply With Quote
Old June 11th, 2010, 11:33 AM   #2
http://faq.ninja250.org/wiki/Do_tall...stock_sizes%3F
Old June 12th, 2010, 03:08 PM   #3
Snake
Snake's Avatar
Yes you will notice a difference in the height if you put a 90 on the front. The 90 you have on the back has raised the rear about 1 inch from stock. If you go back with an 80 in the back it will lower the bike back to stock and may give your feet a little bit better reach to the ground.
Pirelli makes the Diablo Scooter tire in the stock size for the pre-gen. I have them on my bike and they have very good grip.
Stock front size: 100/80-16
http://www.denniskirk.com/jsp/tpl/ti...fCatId=&mmyId=
Stock rear size: 130/80-16
Old June 12th, 2010, 03:22 PM   #4
DRivero
DRivero's Avatar
Snake, I read about those but I couldn't find them when I looked. Thanks for the link! Now, what about mileage?
Posted via Mobile Device
Old June 12th, 2010, 03:46 PM   #5
Snake
Snake's Avatar
They wear very good for a sport tire. Just an estimate on my part but you can expect about 15,000 miles from the front and about 10,000 from the rear. That of course depends on how aggressively you ride your bike. From what I hear you are quite the speed demon...Serously though I think you will like these tires.
Last futzed with by Snake; June 12th, 2010 at 07:06 PM. Reason: miss spell
Old October 15th, 2010, 11:11 PM   #6
Bornondirt
The profile ht will be negligable, really. I doubt seriously you will even notice the ht difference. If you do, then re-check EVERYTHING because it is not the new tire.
Bornondirt is offline   Reply With Quote
Old October 18th, 2010, 08:20 AM   #7
FrugalNinja250
FrugalNinja250's Avatar
Motorcycle(s): Several
My profs used to say, the only silly (stupid, etc) questions are those that go unasked...
Anyhow, to tire sizes. The stock rear tire was a 130/80-16 which works out to being 24.19" (nominal) diameter. Going to a 130/90-16 increases the diameter to 25.21" (nominal), which raises the axle by half the difference, 0.51", since half that extra diameter is above the axle. The seat is about 1/3 of the way from the rear to the front axle, so the seat would have risen about 3/8" more or less.
The stock front at 100/80-16 is 22.3" (nominal); going to a 100/90-16 increases the diameter to 23.09" (nominal), thereby raising the axle 0.4". The seat would go up about 1/3 of that, a little less than 1/8".
The net result is that it would be a little taller, but not that much and likely not enough to affect how your feet plant at a stop. Your speedo will read slower, so depending on how accurate it was before you'll need to be aware of its inaccuracies. The odometer will be more accurate.
Tire sizes broken down: 100/90-16. 100 is the tire width across the sidewalls in millimeters. /90 is a percentage of the width used to describe how tall the tire is from the bead to the tread. A /100 tire would be as tall as it is wide. A /50 would be half as tall as it is wide. -16 is the tire bead diameter, not the overall rim diameter. The recessed part of the rim where the tire rubber bead actually seats is the bead diameter.
Oh, most people perceive the height increase as much more than that typically because they're replacing a worn out tire missing a lot of tread thickness with a new tire that's larger in size. The axle very well could move up almost an inch in that case, but much of that lift is just replacing the worn away old tread thickness.
FWIW...
Tire question MustangDroid 1986 - 2007 Ninja 250R Tech Talk 18 October 25th, 2012 11:47 AM
Tire Question Malicious Logic 2008 - 2012 Ninja 250R Tech Talk 6 September 21st, 2012 04:05 AM
tire question xMoises831 General Motorcycling Discussion 2 April 24th, 2012 10:26 PM
My tire question.... (Yes, again) Soujyu 2008 - 2012 Ninja 250R Tech Talk 14 June 27th, 2010 07:54 PM
tire upgrade question: front tire? stryder 2008 - 2012 Ninja 250R Tech Talk 1 April 5th, 2010 07:40 AM
