Old November 23rd, 2010, 11:18 PM   #1
arcman
Love to ride
arcman's Avatar
Motorcycle(s): 2011 ZX10-R
Unsheathed wires?
'09 Ninja non EFI.
Took the left hand side fairing off today to clean the build up of Motul Factory cahin lube which lovingly makes it's way onto the fairings and noticed a unsheathed wire sitting on bare metal.
In the photo below, just to the right of the idle screw there is a black connector attaching to green and black wires, to the right of the black connector this cable routes down towards the vent hoses:
what's got me worried is that where this cable currently routes down, it's sitting on bare metal (looking top down from the left hand side of the bike almost where the seat is):
close up:
I tried pulling the sheathing up but there's no slack.
Anyone know if this is the correct route for this cable or where it should go if this isn't?
Many thanks,
A.
arcman is offline   Reply With Quote
Old November 24th, 2010, 03:21 AM   #2
randomwalk101
self wrencher
randomwalk101's Avatar
You can wrap some plastic hoses & electric taped around it to protect it. I think that's the signal wires.
Old November 24th, 2010, 04:43 AM   #3
g21-30
g21-30's Avatar
Nope, that's the connector to the side stand switch. I think the angle of your view is misleading you. Does your side stand switch work?
The blue arrow in the following picture points to the connector (disconnected on my bike) that you are looking at:
Old November 24th, 2010, 05:45 AM   #4
arcman
Love to ride
arcman's Avatar
Yep, the side stand switch works fine, according to the service manual that's what that cable is for...if you trace from where your disconnected block in blue is towards the back of the bike, where does it route through? I can't see in the service manual exactly where it should route...think it must have been routed incorrectly during a service as I don't think Kwaka would have unsheathed wires sitting on a metal bar.
Ty,
A.
Old November 24th, 2010, 06:04 AM   #5
randomwalk101
self wrencher
sorry about the mis-id of the wire/plug..but doesn't matter..just re-route it, and may beb ziptie it somewhere so it won't rub...wrap some electrical tape/plastic or rubber hose around would be good too.
Old November 24th, 2010, 07:58 AM   #6
g21-30
g21-30's Avatar
Ty,
A.
It's routed correctly, just like mine and it's pulled tight and tie-wrapped. Have you looked really close to see if any wiring is exposed? It doesn't look like it in your pics. I will look at them again. If the side stand works, then it maybe the ground wire shorting to ground and that would not be a problem!
Update: In this pic, it looks like the insulated wire is behind the metal frame. Pull it away and look at the wire. If it is cut, then wrap it with electrical tape and forget about it.
too many wires on the battery eddiekay 2013 - 2017 Ninja 300 Tech Talk 5 May 12th, 2014 08:07 PM
What are these wires for? djjontran 1986 - 2007 Ninja 250R Tech Talk 8 July 3rd, 2013 12:01 PM
My new Blinkers have 3 wires Graugaard 2008 - 2012 Ninja 250R Tech Talk 5 May 6th, 2012 08:30 PM
help me map gauge wires into harness wires Kangxi 2008 - 2012 Ninja 250R Tech Talk 9 April 18th, 2012 06:08 PM
Unconnected wires jola 1986 - 2007 Ninja 250R Tech Talk 12 July 10th, 2009 07:23 AM
