Old May 2nd, 2011, 01:09 PM   #1
Blackwidow
Unhappy my baby is sick
I haven't turned on my bike for almost two months, its been sitting in my car port for that long. Yesterday I went out to turn it on to show it off to my cousin and it had a hell of a time starting, once I got it to turn on, keeping it on was impossible. Now I can't get it to stay on, when I roll the throttle it dies on me. What happened?
sometimes I aim to please, but mostly I shoot to kill
Blackwidow is offline   Reply With Quote
Old May 2nd, 2011, 01:16 PM   #2
rceezy
Lean Me
rceezy's Avatar
Motorcycle(s): 2008 Ninja 250
Poor baby. She might be mad at you. Could bad gas be a culprit? (I am by no means an expert, I just hear stuff from around the way)
rceezy is offline   Reply With Quote
Old May 2nd, 2011, 01:18 PM   #3
The two most likely candidates are low battery causing hard starting and potentially weak running until it charges back to a reasonable level; or your carbs are gummed up from the gas deteriorating in the tiny passages (often in the pilot jet). For battery, the fix is to fully charge it with a battery tender or similar gadget. But unfortunately, that's the less likely scenario. The more likely scenario is described to a T right here in kkim's thread.
/moved to new-gen tech
Old May 2nd, 2011, 01:18 PM   #4
randomwalk101
self wrencher
randomwalk101's Avatar
follow kkim's guide to clean out carb.
Old May 2nd, 2011, 01:21 PM   #5
HKr1
IC2(SW)
HKr1's Avatar
Would try new gas before tearing stuff apart.
Old May 2nd, 2011, 01:26 PM   #6
Doesn't hurt anything to try the easy stuff first.
Old May 2nd, 2011, 01:32 PM   #7
petiteninja
Motorcycle(s): '09 Ninja EX250J
This may sound like the obvious, but did you have the choke on?
I once went into a panic when my bike wouldn't start and my husband asked if I remembered the choke...oops!
petiteninja is offline   Reply With Quote
Old May 2nd, 2011, 01:33 PM   #8
trying some fuel system cleaner before ripping the carbs apart is mentioned in the DIY. The assumption is (and maybe it's a bad one) that the fuel cleaner would be used in a fresh tank of gas.
There are a few remedies such as a fuel cleaner/additive (seafoam, berryman's) that you might be able to get by with that will clean the clogged jets, if you're lucky, but if not, removing the carbs and cleaning out the jets is the only way to be 100% sure your jets are clean and crud free.
Old May 2nd, 2011, 07:07 PM   #9
randomwalk101
self wrencher
Put your bf to work...bike no run = no sex. Woot!
Old May 3rd, 2011, 01:21 PM   #10
TenaciousD
TenaciousD's Avatar
Motorcycle(s): 2009 250R
Did you put any stabilizer in the fuel before you parked the bike? Welcome to one of the major downsides of carburetors.
Kevin
2009 Ninja 250R
TenaciousD is offline   Reply With Quote
Old May 10th, 2011, 06:27 PM   #11
arnette
Motorcycle(s): 2011 Ninja 250R Pearl White/Ebony SE
Same exact scenario is happening to me. I dumped a can of that Seafoam in there but haven't seen much improvement. I can ride around with the choke full bore but that will have me idling at 6K!
This is Seafoam with half a tank of 'bad' gas. Perhaps I'll try topping off with fresh gas.
arnette is offline   Reply With Quote
Old May 10th, 2011, 11:57 PM   #12
Cuongism
Cuongism's Avatar
Did you dump a whole can in there? I think the ratio is 1 oz Seafoam per 1 gallon gas.
Old May 11th, 2011, 06:44 AM   #13
kamikaze
ex-ninjette.org guru :o
kamikaze's Avatar
Motorcycle(s): 2003 SV1000 S
even with stabil in the tank and a battery tender all winter mine was tough to get going this spring. what I did was get it going with the choke until it would run without stalling, and then just let it idle for about 15-20 min. don't touch the throttle at all. starts up every time now with no issues.
kamikaze is offline   Reply With Quote
Old May 11th, 2011, 07:32 AM   #14
CC Cowboy
CC Cowboy's Avatar
MOTM - Mar '13, Jun '14
Let this be a lesson not to neglect the things you love.
Old May 11th, 2011, 09:47 AM   #15
Snake
Snake's Avatar
I have a hard time believing that you can't turn anyone or anything on let alone keep them turned on.
Old May 11th, 2011, 10:51 AM   #16
arnette
Old May 12th, 2011, 09:45 AM   #17
Blackwidow
Yes I had the choke on the whole time, it starts up and i let it run for a few minutes, as soon i rolled the throttle it died. I think i'm going to have to take things apart and clean it out. I just have a hard time believing within two months crap could build up so quickly.
Old May 12th, 2011, 11:09 AM   #18
TnNinjaGirl
Ms. Personality
TnNinjaGirl's Avatar
Mine did the exact same thing at the beginning of the season. I ran it around the neighborhood a few times and put some fresh gas in it. She runs like a champ now!
Old May 12th, 2011, 01:09 PM   #19
HKr1
IC2(SW)
HKr1's Avatar
Dam, its only been 10 days
Old May 12th, 2011, 08:47 PM   #20
headshrink
headshrink's Avatar
Mine always starts a little harder after only 2 days of rest.
Old May 13th, 2011, 10:24 AM   #21
Blackwidow
its hard to run it around town when i can't even roll the throttle without having it die
Old May 13th, 2011, 12:40 PM   #22
kamikaze
kamikaze's Avatar
how long will it run with the choke full on if you keep off the throttle?
Old May 14th, 2011, 09:01 PM   #23
RedCromwell
RedCromwell's Avatar
Motorcycle(s): '10 Ninja 250
Curious... why'd you let it sit for two months?
Now, another silly question. When you rolled on the throttle, were you doing it slowly, gradually bringing up the RPMs versus trying to do quick WOT twists?
Maybe your baby just needs to be gently coaxed to wake up fully. Once she's wide awake and purring, then you can get her to roar.
RedCromwell is offline   Reply With Quote
Old May 14th, 2011, 09:42 PM   #24
Havok
Internet Slut
Havok's Avatar
Motorcycle(s): 04 FZ1, 07 FZ6
So does this mean you are going to start riding her?
Havok is offline   Reply With Quote
Old May 14th, 2011, 09:52 PM   #25
thurt88
thurt88's Avatar
Motorcycle(s): 2014 Honda CRF250L, 2010 ninja 250r
Mine did the exact same thing at start of the season. Problem was gummed up carbs compounded by the seafoam I used to stabilize my fuel.
Two lessons were learned from that:
1- Start the bike at least once a week.
2- Do not use Seafoam, use a dedicated fuel stabilizer.
I should add a third:
3- Buy a bike with FI.
thurt88 is offline   Reply With Quote
Old May 16th, 2011, 09:00 AM   #26
Blackwidow
between 30 seconds to a minute.
Old May 16th, 2011, 09:02 AM   #27
Blackwidow
We were having crappy weather here, when the ground is even slightly wet I won't ride. Also, I had back problems. So I didn't want to risk anything.
I tried both, I rolled the throttle slowly and gently, it dies..when I open the throttle full blast, it dies.
I was going to take apart the bike using KKims DIY this past weekend but again, the weather sucked.
Old May 16th, 2011, 09:12 AM   #28
nattygirl
nattygirl's Avatar
Motorcycle(s): 2010 Kawasaki Ninja EX250 Special Edition Red/Black
If you're going to take your bike apart anyways, shim the carbs at the same time. You'll like the improvements.
'10 Ninja 250R SE Red/Blk
Mods: Projekt D FE, Protons, HB Blk Windscreen, HIDs, TBR Blk Series Slip-On, Shogun Sliders, Solo Cowl, Integrated Tail Light, Gls Blk Rear Fender, Red Accents
nattygirl is offline   Reply With Quote
Old May 16th, 2011, 03:51 PM   #29
ally99
Ninja chick
ally99's Avatar
MOTM - Dec '13, Feb '15
I hope your baby feels better soon! I get pissed when mine is sick for a single day!
Postwhores are COOL! ~Allyson
Old June 13th, 2011, 11:15 AM   #30
Blackwidow
took your advise girly..
http://www.ninjette.org/forums/showt...321#post308321
Old June 13th, 2011, 04:32 PM   #31
RaceBikeRentals
Pimpin
RaceBikeRentals's Avatar
Motorcycle(s): Bunch of em
Cali gas will plug your pilot jets after sitting for about a month. As others have said, you really need to start it once every week or two and let it idle for 5 minutes or so. If not, you're going to have to tear it apart and clean the carbs. I've found no way to get around that.
-Richard
MotoList.com <<<List your stuff!
RaceBikeRentals is offline   Reply With Quote
Old June 13th, 2011, 04:53 PM   #32
armatt06
Motorcycle(s): None right now. Had a built sportster.
I work on a lot of atv's for people and I get this a lot. I always remove the carbs, disassemble them, soak all metal parts in a gallon of carb cleaner (you can get it at NAPA for $15 and its reusable and has a basket to hold your parts in), reassemble and they fire right back up everytime. Just be sure not get any gaskets, seals, or rubber parts in the carb cleaner as it will deteriorate them. Its a little bit of work, but it'll run great and carbs should be cleaned every once in a while anyways.
Also, when you do it, keep track of how many turns out your jets were and it'll save you a headache later.
armatt06 is offline   Reply With Quote
Old June 20th, 2011, 02:52 PM   #33
Blackwidow
i think i spoke too soon!!! i'm so pissed! My bike keeps freaking dying! it starts and gets going, but as soon as I click it to 3rd gear it dies..i mean literally dies!! everything shuts down and I have to restart it again. i'm so freaking irritated already. i cleaned the jets, i cleaned the entire carberator, i even shimmed the needles, now what could be wrong with it?
Old June 20th, 2011, 03:29 PM   #34
Snake
Snake's Avatar
Is the bike still under waranty? If so I would take it back to the dealership and have them troubleshoot it and fix it.
Old June 20th, 2011, 03:48 PM   #35
Blackwidow
i was thinking about that, but now what i'm nervous about is them knowing i took apart my bike thus making my warranty null and void.
Old June 20th, 2011, 03:48 PM   #36
headshrink
headshrink's Avatar
Dies like it originally did when you rolled on the throttle, or instantly when you click into 3rd (as if 3rd were a kill switch)?
It may be a long-shot, but I was wondering if the safety switch on your tranny & kickstand were somehow malfunctioning (like when you put it in gear with your kickstand down). Like I said, a long-shot, but thought I would brainstorm a bit.
Old June 20th, 2011, 03:54 PM   #37
Blackwidow
initially it would die when i would pull the clutch in at 3rd to down shift, after the first incident everytime I pulled in the clutch it died. so getting out of 1st is impossible.
Old June 20th, 2011, 03:54 PM   #38
Blackwidow
i'm thinking maybe I didn't fasten something tight enough.
Old June 20th, 2011, 04:04 PM   #39
headshrink
headshrink's Avatar
Hmmmm.... that would make me wonder about those switches. You may want to go through the trouble-shooting steps in the service manual for them. If nothing else, it may rule them out as the culprit.
Old June 20th, 2011, 04:06 PM   #40
No warranty becomes void just because you did your own work. If a problem is discovered, they need to link the problem directly to the work performed (i.e. - did you break it), in order to deny any warranty claim.
My baby is sick! =( vman1313 1986 - 2007 Ninja 250R Tech Talk 16 June 28th, 2015 04:38 PM
sick again alex.s Off-Topic 14 May 2nd, 2014 12:34 PM
Sick Apex Off-Topic 6 February 22nd, 2011 12:12 PM
[topix.net] - Harley Baby Clothing: Buying Harley Davidson Baby Clothes Ninjette Newsbot Motorcycling News 0 August 6th, 2009 10:50 PM
