Old April 1st, 2012, 06:51 AM   #1
Ranor
Ranor's Avatar
Motorcycle(s): 2011 Ninja 250R Pearl White EFI
Does tire need replacing?
Came back home and noticed a wierd spot on the rear tire. Turns out theres a piece of glass stuck in it as seen in the pictures below. Looks like a very small shard of glass and the tire has not lost any pressure. The wear on the rear tire is still very low do you think the tire still needs replacing?
Pics:
http://www.dropbox.com/gallery/16823...0Pics?h=dc7b93
Ranor is offline   Reply With Quote
Old April 1st, 2012, 07:18 AM   #2
Gorilla25
Dakine...
Gorilla25's Avatar
Motorcycle(s): 2009 Ninja 250R (Sold) | 636 (hopefully soon)
looks like the glass just took a piece of your tire out. is there any more glass in there? if not, i'd say it should be fine. but you may want to wait until someone with more tire experience to chime in.
Gorilla25 is offline   Reply With Quote
Old April 1st, 2012, 07:22 AM   #3
Ranor
Ranor's Avatar
There is still a small piece stuck in the tire, not sure if I should try to remove it...
EDIT: If you look at the first picture that thing in the middle of the hole is the piece of glass, it didn't really show very clearly in the pictures for some reason.
Old April 1st, 2012, 07:32 AM   #4
Gorilla25
Dakine...
Gorilla25's Avatar
in that case, it probably be safer to just replace the tire. but, like i said, you may want a second opinion. esp if they have more experience with tires than i do.
Old April 1st, 2012, 07:41 AM   #5
Lew360
Bueller
Lew360's Avatar
Motorcycle(s): '09 250R
If you pull the glass out and it still holds air it should be fine. If it won't hold air it has probably damaged the cords and needs to be replaced. You could plug it, but i wouldn't chance it,
Lew360 is offline   Reply With Quote
Old April 1st, 2012, 08:18 AM   #6
NathanUc
B-Town Ninja
NathanUc's Avatar
Motorcycle(s): Black 2013 Ninja ZX6R ABS
I would always recommend being safe than sorry with a motorcycle tire, but are those the stock tires? If so you should really consider upgrading to some pirellis anywho.
Downgraded to a 2013 636. Previous owner of a 2010 250r
My moto-vlog YouTube channel http://www.youtube.com/bloomingtonninja
NathanUc is offline   Reply With Quote
Old April 1st, 2012, 09:03 AM   #7
Ranor
Ranor's Avatar
They are the stock tires, but considering the amount of thread left on them I would hate to discard them prematurely. I will probably first try to pry the small shard of glass out of the tire. Am I correct in thinking that if i take the piece of glass out and there is not a leak the tire is perfectly safe?
Old April 1st, 2012, 12:55 PM   #8
Ranor
Ranor's Avatar
Small Update: Cant seem to get the shard of glass out of the tire it's too small and if i try to nab it with some needle nose pliers it goes in deeper not sure what to do next. I put some soapy water on it and still no bubbles are showing up. I'm thinking of just riding it to the shop and getting it replaced :/ thats like a 25 mile ride since it's not really leaking it should be fine for that long
Old April 1st, 2012, 06:05 PM   #9
Whiskey
Looks like there's a good depth of thread there, you tested it & saw no bubbles so it should be ok. keep an eye on the pressure, if it holds I wouldn't rush out to buy new tyres just yet (upgrade if you had planned to).
Small chunks of glass tend to break/be ground off rather than dig in deeper
Old April 2nd, 2012, 11:16 AM   #10
NathanUc
B-Town Ninja
NathanUc's Avatar
It's probably safe by the looks and sounds of it. The only reason I would highly recommend replacing it is what IF it isn't? A blowout at speed is probably something low on your wants list. The stock tires really are awful to begin with so you'd benefit from a swap in the first place. Seems like all signs point to replace!.. but you probably don't HAVE to
Old April 2nd, 2012, 11:26 AM   #11
cbdallas
cbdallas's Avatar
Motorcycle(s): 2007 Ninja 650R
I got lucky a few weeks ago & pulled a nail out of my front tire and it's still at the same pressure it was then. But....if I hadn't removed it, it would continue to get pushed further in until it penetrated the inner liner, and then...there goes the air.
I know it feels like a waste, but get rid of that tire. After dodging that bullet, I pulled another nail out of my rear, and it started leaking. So...a practically new OEM tire went into the trash.
Yours COULD be fine, but what if it isn't? It could really go either way...be ground down as the tire wears, or get driven in further. I don't believe it'll lead to a blowout, but it could very easily lead to a dangerously low tire while riding. It's just not worth it.
cbdallas is offline   Reply With Quote
[motorcycle.com] - Michelin Replacing Bridgestone as New MotoGP Tire Supplier Ninjette Newsbot Motorcycling News 0 May 23rd, 2014 08:40 AM
Replacing front tire on your own? Bones85 2008 - 2012 Ninja 250R Tech Talk 9 June 20th, 2013 01:43 PM
[sportrider - latest stories] - Replacing Suzuki Cams and Street vs. Track Tire Press Ninjette Newsbot Motorcycling News 0 August 27th, 2011 01:40 PM
Replacing Rear Tire Only? AgentCircus 1986 - 2007 Ninja 250R Tech Talk 11 July 27th, 2010 02:27 PM
Replacing Chain headshrink 2008 - 2012 Ninja 250R Tech Talk 35 March 18th, 2010 01:27 PM
