Old August 1st, 2009, 06:39 PM   #1
voodoomaster
VooDooMaster
voodoomaster's Avatar
Motorcycle(s): 2008 Blue EX250, 2007 Yamaha Virago 250
Hard to start after sitting in 100 deg heat all day
My machine is a bee-ach to turn over after sitting outside in the sun. It seems like vapor like, because it takes me a good 15 seconds of cranking to finally get it going. Any suggestions team?
VooDooMaster
I love the smell of Blue Octane in the morning.....
voodoomaster is offline   Reply With Quote
Old August 1st, 2009, 06:50 PM   #2
have you tried starting with and without choking the bike?
Old August 2nd, 2009, 07:35 AM   #3
voodoomaster
VooDooMaster
Chock is useless.
Yes. I think that I have tried all the standard start operations; choke on, choke off, throttle on, throttle off, etc. Just as soon as the system cools down, say after moving into the garage, the creep starts up OK. In the morning, after sitting pretty in the garage, temps arounf 80 deg F or so, she cranks over in 2 seconds. I gave the mixture screws a bit a a turn, richer, but it didn't do anything for the "vapor lock" symptoms. I will say that after she heat soaks in the sun, it takes a good 20 seconds of cranking to kick over, then runs like nothing was the matter.
VooDooMaster
Old August 2nd, 2009, 07:45 AM   #4
rockNroll
rockNroll's Avatar
Motorcycle(s): black
Try opening then closing your fuel cap, before you stab the starter button, next time you feel you're in the right conditions for this problem to occur.
Old August 2nd, 2009, 09:06 AM   #5
randomwalk101
self wrencher
randomwalk101's Avatar
last time my ninjette threw a tandrum like that with me, i peed on it...it never did it again.
Old August 2nd, 2009, 09:16 AM   #6
tjkamper
tjkamper's Avatar
I've had the same problem. I open the gas cap for a few seconds and then start w/o the choke and it works like a charm.
Old August 5th, 2009, 05:09 PM   #7
voodoomaster
VooDooMaster
I will give the cap operation a go. Seems like it should cure a vapor lock squeeze. Thanks all for the suggestions.
VooDooMaster
After LONG winter sitting, bike wont start RedNinja09 General Motorcycling Discussion 44 January 20th, 2018 02:34 PM
Hard to start sometimes? SwagenGTI 2008 - 2012 Ninja 250R Tech Talk 3 May 7th, 2013 08:38 PM
Bike has been sitting for 9 months and won't start FerociousNINJA 2008 - 2012 Ninja 250R Tech Talk 11 February 8th, 2012 05:39 PM
Hard to start Sfor6285 2008 - 2012 Ninja 250R Tech Talk 11 August 28th, 2011 09:43 AM
hard to start conchwanab 2008 - 2012 Ninja 250R Tech Talk 4 May 7th, 2009 02:30 PM
