June 12th, 2013, 09:56 PM | #1 |
Join Date: Dec 2012 Motorcycle(s): 2008 Ninja 250R Posts: 263
Bent front lever
June 12th, 2013, 10:06 PM | #2 |
not an actual panda
Join Date: Aug 2012 Motorcycle(s): 2008 Ninja 250, 2009 CBR600RR (Sold) Posts: A lot.
Put it in a vise, heat it, bend it back carefully.
Don't use your hands to bend it. |
June 12th, 2013, 10:35 PM | #3 |
Gear crash test dummy
Join Date: May 2011 Motorcycle(s): 2010 Ninja 250 race bike, 2014 ZX-636r Posts: A lot.
They're $10 on eBay...
CVMA #531 |
June 12th, 2013, 10:59 PM | #4 |
June 12th, 2013, 11:11 PM | #5 |
impact driver or a #3 phillips head and a mallet.
I had the same problem... just about sold the bike to not have to deal with it. Heat sometimes breaks up the red loctite on it. GOD SPEED.
CVMA #531 |
June 13th, 2013, 06:21 AM | #6 |
Fast-Guy wannabe
MOTM - Jan '13
Try the #3 and a mallet with some heat. If that doesn't work just do what I did and drill the mother F***ing head off then slid the bar end off. Next use the heat then grab the exposed threads of the bolt with and pair of vise grips and it should come out easy.
June 13th, 2013, 12:45 PM | #7 |
Join Date: Jul 2011 Motorcycle(s): 2009 Ninja 250R Posts: 86
Same **** happened to me the other day ... torch the center of the phillips head for a few minutes, then try to work the screw off.
June 13th, 2013, 06:29 PM | #9 |
Ok, bent lever is easy. Put it back on the bike, and either just bend it back by hand or use a short length of pipe to bend it back Wrap a little tape around the spot of actual bend, use the pipe, put the lip of the pipe at the bent spot, then bend. These lever are really soft. The last time I straightened one I just bent it by hand. Do not use heat! That will lead to a mess.
Bar end. Use a propane torch to heat the screw, move the tip of the flame around the screw head. This will soften the loctite that's holding the screw in place. After a minute or two, try with proper JIS screwdriver. If it doesn't budge, more heat. Once the loctite is melted the screw just comes out. Attempting removal without heat will lead to severe disappointment! |
Front brake = left lever; Clutch = right lever | cadd | Riding Skills | 27 | October 7th, 2014 08:29 AM |
Lowside- bent clutch thrust rod and possibly bent shift fork? | Klondike1020 | General Motorcycling Discussion | 3 | April 1st, 2014 02:29 AM |
Bent Front Wheel =[ | xsnugglebear | 2008 - 2012 Ninja 250R Tech Talk | 11 | November 14th, 2013 04:25 PM |
[roadracingworld.com] - Video: The OTT Crew Removes The Bent Front End From Their Pro | Ninjette Newsbot | Motorcycling News | 0 | October 26th, 2010 09:20 AM |
[roadracingworld.com] - Video: OTT Removes The Bent Front End From Their Project Yama | Ninjette Newsbot | Motorcycling News | 0 | October 26th, 2010 08:10 AM |
