Go Back   ninjette.org > General > Pictures
Old August 21st, 2017, 12:33 PM   #1
Kool-aid
Kool-aid's Avatar
2007 Ninja 250 pooness
I got this bike for next to nothing. Guy didn't know what he was doing with it.
https://drive.google.com/open?id=0B7...GFuc3ZoMlByQ28
The oil check glass was broke and someone uses jb weld or some kind of epoxy to fix it. But it still leaked. So I had to improvise, a lot of RTV liquid gasket, a washer, piece of tin, and a couple zip ties. I didn't want to waste money on a lost cause.
https://drive.google.com/open?id=0B7...HlTS1luQXp1VjA
I got it home and stripped it down to do a damage assessment. I hooked a lawn mower battery up to it just to see if it would crank. the battery would spark.
https://drive.google.com/open?id=0B7...kNLaHJGZmhlRXM
to check for power
https://drive.google.com/open?id=0B7...VdpeWtpNjQxZUk
So I checked all the wires and fuses. Found that the power terminals on the starter relay were backward and that the 30amp fuse was blown. So I keep looking. A couple wires at the plug for the rectifier looked questionable and the wires for the rear lights were just cut and left there. I fixed the starter relay wiring and unhooked the rectifier as well as spread out all of the wires for the rear lights so they wouldn't ground out. And Great success, she cranked great and started right up with some fresh gas.
https://drive.google.com/open?id=0B7...WhSakphY1pUSVE
So now I will move on to test drives. I have a new proper battery and a used in great shape wiring harness. As soon as I confirmed it drives, I will replace the clutch cover that has the oil glass in it and start getting it road worthy. My plan is for a very very simple street fighter. I think it will look better without the old fairings in the front. I'm also going to trim the side pieces and leave the tail section off.
Kool-aid is offline   Reply With Quote
Old August 21st, 2017, 03:13 PM   #2
awesome work on wiring! Usually where a lot of bikes gets dumped!
Old August 21st, 2017, 06:22 PM   #3
CaliGrrl
CaliGrrl's Avatar
Motorcycle(s): Ninja650
Wow- that sounds like a basket case! I'm glad she found her way to you and will soon feel much better.
Old August 21st, 2017, 08:11 PM   #4
Kool-aid
Kool-aid's Avatar
Will post pics tomorrow. Kentucky is hot when you are working in a garage.
Old August 22nd, 2017, 08:04 AM   #5
A.J.
A.J.'s Avatar
Motorcycle(s): 2001 Kawasaki Ninja 250r(SOLD) 2006 Kawasaki Ninja 250r full Muzzy(my pride and joy)
Well done. I'm still working on some minor wiring issues, I guess you would call them issues. I got a beautiful 2006 for $700. Previous owner had installed a ton of aftermarket LED lighting system. Just left over wires everywhere. Nothing that is bad for me or the bike just something that was completely unnecessary and takes up my precious time. Wiring is a pain. Congrats on your find. Got a good title?
"A car or truck will get you from point A to B. But a motorcycle, that is the point." -unknown
A.J. is offline   Reply With Quote
Old August 22nd, 2017, 09:06 AM   #6
Kool-aid
Kool-aid's Avatar
this is the original wiring. It was a mess
https://drive.google.com/open?id=0B7...nB0TjQ4MTExQlU
Also I was fixing the front sprocket that had a snapped bolt on the keeper. the one I got from ebay has 14 teeth? One I took off the bike is on the bottom with 13 teeth. they look completely different?
https://drive.google.com/open?id=0B7...Fh2aDZndmNPNXc
Any ideas? As far as I know I only have a regular 250, not the 250r
Old August 22nd, 2017, 09:19 AM   #7
Kool-aid
Kool-aid's Avatar
Yup title is good. I am even in contact with the previous previous owner. And ya, they did a rear LED hack job as well. I found a full harness on ebay for 18.99 plus 14.15 shipping. So worth the money. It was in great shape.
Old August 22nd, 2017, 09:19 AM   #8
A.J.
A.J.'s Avatar
the 250 and 250r are the same bikes. 2007 Kawasaki Ninja EX250R
EX250F
Whichever you choose to call it. Not sure what the difference is in the teeth. However there are a ton of guys who can and will answer that for you.
UB any ideas?
@Ram Jet
@Triple Jim
Old August 22nd, 2017, 09:22 AM   #9
A.J.
A.J.'s Avatar
Yeah you probably saved yourself some time buying a new harness. Someone went balls to the wall installing all these "nice" little fashionable lights. Then just removed the lights and left the wires. If I'm selling a bike I'm going to let the buyer know hey there's some wires under there, this is what they're for. Instead most people leave the big puzzle for you to solve. Hell I will take it over engine trouble but it's still a pain.
Great buy on the harness, ebay is awesome.
Old August 22nd, 2017, 10:00 AM   #10
Kool-aid
Kool-aid's Avatar
amen to electrical than engine
Old August 22nd, 2017, 11:55 AM   #11
Ram Jet
Ram Jet's Avatar
The 14 tooth on the top appears correct. You were sent the wrong sprocket. By the way, you'd be NUTS to run a 13 tooth sprocket unless you want to induce whiplash in your neck. I went from a 14 tooth to a 15 - and then from a 45 rear to a 42.
Bill
Old August 22nd, 2017, 01:38 PM   #12
VaFish
VaFish's Avatar
MOTM - Jan '16
Let me know if you need a clutch cover or anything else for that matter. I have piles of parts in the garage, including 3 engines in various states of disassembly. Box of sprockets and chains, wheels, forks, fairing, cables ect......
Old August 22nd, 2017, 07:54 PM   #13
Kool-aid
Kool-aid's Avatar
Got some slack in the chain and installed the 14 tooth. And now there's an oil leak. Looks like it's dripping off the bolt heads on that cover next to the oil drain plug. It's a cover under where the front sprocket is. About 4 or 5 bolts on it. Dripping every other second. Didn't want to risk a short drive.
And I am absolutely interested in a clutch cover. Just send me a price and shipping cost to 42408.
Old August 23rd, 2017, 08:39 AM   #14
A.J.
A.J.'s Avatar
@Ram Jet can tell you exactly what that is. That where the screen is UB? Hope it's nothing serious but Ram Jet had some issues with stripping on his 2007 hopegully thats all your issue is. You check the bolts to make sure they're all in properly and none are stripped?
Old August 23rd, 2017, 10:02 AM   #15
Kool-aid
Kool-aid's Avatar
Looking at the book, it seems thats where the screen is. Hopfully some RTV on it and it will stop leaking. I'll drain and try tonight. She's a little loud idling at 4grand and no muffler. LOL
Old August 23rd, 2017, 11:41 AM   #16
Ram Jet
Ram Jet's Avatar
I would use Permatex High Tack on that screen cover. Works fine on mine. While your at it clean that screen too. I hope to heck it's not your countershaft seal. Not fun to replace.
Bill
Old August 23rd, 2017, 12:32 PM   #17
Kool-aid
Kool-aid's Avatar
Bill
oh lord, what is the countershaft? Is that the gear selector shaft? And I will use Permatex high tack. Autozone looks to have a few different kinds. Also can I forgo a new seal if I use the permatex?
"the field mouse is fast, but the owl sees at night"
Last futzed with by Kool-aid; August 23rd, 2017 at 12:34 PM. Reason: adding verbage =)
Old August 23rd, 2017, 12:42 PM   #18
Kool-aid
Kool-aid's Avatar
With my ninja Googling, I have found this site
https://faq.ninja250.org/wiki/Ninja250_Howto
I will ask less questions. I love being apart of a forum again. You meet people who are great and very willing to help.
Old August 23rd, 2017, 03:02 PM   #19
Ram Jet
Ram Jet's Avatar
The part I was suggesting you use Permatex on is the one pictured. I like Permatex High Tack because when you remove a part that you installed with it it cleans up nicely with just lacquer thinner and a paper towel. No scraping or chipping an old gasket off. You can even use it without a gasket. I even used it once to seal the cylinder heads to cylinder after removing the copper head gasket on my 73' Kaw 500 triple.
The countershaft seal is located directly behind your front or countershaft sprocket. On my Honda 500 you have to remove the engine and split the crankcases to get it out. I don't know about the Ninja - probably the same thing. No, Permatex won't fix that only a replacement seal. You're probably OK though. You would probably have to have something like 200K miles on your bike to wear that out.
Bill
Old August 25th, 2017, 01:33 PM   #20
Kool-aid
Kool-aid's Avatar
Bill
did you mean to say Permatex high "temp"?
Old August 25th, 2017, 02:25 PM   #21
Ram Jet
Ram Jet's Avatar
No it's Permatex High Tack in a four ounce can with an applicator brush built into the cap. Permatex product code #80062.
Bill
Old August 27th, 2017, 01:19 PM   #22
Kool-aid
Kool-aid's Avatar
And Ram Jet, you won. It is leaking from behind the sprocket.
Old August 27th, 2017, 03:07 PM   #23
Ram Jet
Ram Jet's Avatar
Well, it's better to repair it now then when you get it all together and running well. Just remember, "Nothing's so bad that it couldn't be worse." You might be able to replace the seal without splitting the cases. The good news is that the seal is less than $5.00.
Bill
Old August 27th, 2017, 05:45 PM   #24
Kool-aid
Kool-aid's Avatar
Very true.
Old August 27th, 2017, 06:09 PM   #25
Kool-aid
Kool-aid's Avatar
https://faq.ninja250.org/wiki/File:T...ump-to-license
Part 92027?
Old August 27th, 2017, 09:28 PM   #26
Ram Jet
Ram Jet's Avatar
Part #92049
http://www.partzilla.com/parts/searc...ASE/parts.html
I found some kits from All Balls bearing supplier but none specifically for the Ninja. You may want to call or E-mail them.
I don't know where Wiki got that exploded view but it's not accurate by today's standards. I can't even find 92027 on the Partzilla view.
Bill
Old September 19th, 2017, 07:03 AM   #27
Kool-aid
Kool-aid's Avatar
thank you very much. I finally got that part put in. Hmm, I guess this is bad.
Last futzed with by Kool-aid; September 19th, 2017 at 07:07 AM. Reason: change
Old September 19th, 2017, 09:29 AM   #28
Ram Jet
Ram Jet's Avatar
Bearing races? Good God!!!! I'd better check mine the next time my bike is torn down.
Bill
Old September 19th, 2017, 12:53 PM   #29
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
My favorite flavor... Purple
Old September 20th, 2017, 07:06 AM   #30
Kool-aid
Kool-aid's Avatar
That was the countershaft seal behind the front sprocket. And grape is the best. LOL
Old September 20th, 2017, 07:23 AM   #31
Ram Jet
Ram Jet's Avatar
Oh! Duh. Well, it looks like it disintegrated.
Cherry or Jim Beam for me.
Bill
