Go Back   ninjette.org > General > !%@*#$%!)@#&!%@ I crashed!
Old December 17th, 2017, 11:08 AM   #1
NaturalFlavored
Motorcycle(s): 250r
So it finally happened
I was out for a cruise and I was coming down a hill picking up some speed so I went to slow down and my tires just started screeching and the bike lost traction and I went down.
Unfortunately it fell pretty hard and messed up quite a bit of things, still working on the cosmetic parts but the bike still turns over. Haven't tried firing it up yet though, had to Bondo the gas tank and replace a couple of things.
NaturalFlavored is offline   Reply With Quote
Old December 17th, 2017, 06:42 PM   #2
Sorry to hear... we see how the bike is, but how about the rider? Are you ok?
Old December 17th, 2017, 07:01 PM   #3
NaturalFlavored
Motorcycle(s): 250r
I'm fine I had a few scratches nothing severe. It kinda drug me a bit, if it didn't i wouldn't of had much done.
I think the engine might need to be worked on, it turns over but won't start.
Old December 17th, 2017, 07:09 PM   #4
I'm glad you're not too banged up. My first guess is that there is something simple wrong that's causing the engine not to start. Maybe it's flooded, or maybe a wire got knocked off of something.
Old December 17th, 2017, 08:06 PM   #5
NaturalFlavored
Motorcycle(s): 250r
Well I let it sit for a month before trying to start it at all. I cleaned the carbs and replaced everything that was broken or messed up. I took every thing off except the engine and nothing seemed messed up that I didn't already replace. I replaced left handlebar/controls, clutch sensor, peg, centerstand, and new Spark plugs. It is getting gas to plugs, battery is not dead.
Old December 17th, 2017, 08:12 PM   #6
You should be able to determine if it has spark and if fuel is getting into the cylinders. I can't imagine an internal engine problem if there is no visible damage to it.
Old December 17th, 2017, 10:15 PM   #7
NaturalFlavored
Motorcycle(s): 250r
True tomorrow I will see visible Spark them go from there.
Old December 18th, 2017, 07:32 AM   #8
Betting on a wire that's not connected right or something electrical (switch), but let us know what you find.
Old December 21st, 2017, 11:42 PM   #9
CaliGrrl
CaliGrrl's Avatar
Motorcycle(s): Ninja650
Sorry you crashed. Glad you're (mostly) ok (crashing is never fun). I hope you figure out what's wrong so you can ride again soon.
So this happened, finally adouglas Ninjettes At Speed 31 February 5th, 2017 02:35 PM
It finally happened Drdoonta !%@*#$%!)@#&!%@ I crashed! 10 September 28th, 2012 08:23 PM
It finally happened RyderRider15 !%@*#$%!)@#&!%@ I crashed! 13 April 15th, 2012 10:55 AM
it finally happened delcoco_ninja !%@*#$%!)@#&!%@ I crashed! 8 February 15th, 2012 05:05 PM
It finally happened... Beast !%@*#$%!)@#&!%@ I crashed! 35 April 19th, 2009 12:16 PM
