Old September 1st, 2018, 08:56 AM   #1
pb3
Motorcycle(s): 09 n250, 14 n300, 22 n400
carb pod filter brace?
hi all, thought I'd ask before wrapping my head around the idea of bracing the carb/ K&N pod filter assembly to the frame- has anyone else seen a solution?
my immediate throughts are:
1. cut up OEM airbox to utilize existing frame mounting?
2. I do not want to support from below (engine/ trans= heat source).
tia,
parker
pb3 is offline   Reply With Quote
Old September 1st, 2018, 05:00 PM   #2
gantt
gantt's Avatar
Motorcycle(s): 2019 Ninja 400, Sold 2012 Ninja 650, Sold 2009 Ninja 250r, Sold 2007 DRZ400s
I wondered the same thing. My carbs bounced around like jello on a washing machine.
I recently shoved the stock airbox back in and couldn't be happier. I took the snorkel out too.
gantt is offline   Reply With Quote
Old September 2nd, 2018, 02:52 AM   #3
maverick9611
"a legend in my own mind"
maverick9611's Avatar
MOTM - Feb '18
i did this on my zrx 1200
pods don't work. i tried for 11 straight months and got nowhere. sure you can give it fat jets to cover fuel transitions/holes but it's not right. i tested my theory by pulling godzilla's stock factory clean carbs(plus a couple of shims under needles)and mounting them on red bike with pods. ran like total crap. left carbs in place and installed airbox. ran completely normal.
"trying not to get old"
Old September 2nd, 2018, 04:30 AM   #4
So you confirmed that lean AFR doesn't run well by adding more air with a pod filter and not changing the fueling of a factory carburetor.
Thanks, captain obvious.
Old September 2nd, 2018, 05:36 AM   #5
maverick9611
MOTM - Feb '18
i got it to run with 100's but had to put fp needles at max gas plus shims. problem is transitions between mid to mains and cruise mod. 9000 rpm. this holes can be covered put it takes 108 or higher to do it. our needle profile needs to be custom made. i tried for 11 months straight with the help of dannoxyz but never got something stable. he pushed hard to put godzilla's factory carbs on red bike to get a base line i finally did it last week. ran terrible.
Old September 2nd, 2018, 06:00 AM   #6
I do know what you're talking about, I just don't think it's as dramatic as you seem to because it can easily be tuned out. I will admit, there's a good chance that the pregen needles were more accepting of pods in their taper profile than newgen needles, so maybe my experience base is off a little. I'm willing to admit that.
Have you played with spring rates in the slides? This seems like one of the very few scenarios where fiddling with the spring rate might improve things. If you want to change the lift of that needle under certain dynamic scenarios (read: shimming it out isn't right here) because you want to perfect the transition rather than just broadly add fuel to the whole mid range, that might be the way to go. Time to science what spring rate and relaxed length the spring is now, then see about changing it a little. See if you can get a couple springs that are 5-10% either direction stiffer or softer and see how the slides respond in that transition. Make sense? Danno seems like the type of guy where this might be right up his alley.
The other thing you can do is get creative with some aluminum sheeting and a pop rivet gun and make a 5 sided "airbox" around the pod filter that mounts on the same clamps that the filter itself uses to at least get the filter breathing out of an air cavity that has a little more consistent airflow. The issue here isn't the pod filter itself, the issue is that the flow/mixing isn't consistent like it is in the airbox.
Old September 2nd, 2018, 11:42 AM   #7
maverick9611
MOTM - Feb '18
good idea, i thought about a house to help smooth air but i’m taking a break and enjoy red. it’s been down more than up.
Old September 20th, 2018, 04:49 PM   #8
CrazyCanuckGoat
Motorcycle(s): 2003 ZX12R (sold), 2012 250R, 1975 Honda XL250, 1980 XJ650
I went the simple route and linked I believe 4 zipties together and ran it from both sides of the frame to support the carbs. Been working well the last 2 years.
CrazyCanuckGoat is offline   Reply With Quote
Old September 20th, 2018, 05:26 PM   #9
pb3
hey thanks for that. had you experienced ride-ability issues prior to doing that?
Old September 21st, 2018, 10:02 AM   #10
CrazyCanuckGoat
None whatsoever. I just figured since I was in there rejetting and stuff, I might as well support the carbs. I believe I had put the K&N filter on a month or 2 earlier. If memory serves me, I believe this was fall 2016
I get zip ties free from work, so it was quick, cheap, easy and pretty much an endless supply.
Old September 21st, 2018, 11:08 AM   #11
mgentz
Board Member
I have a screw in the frame cross member right above the pod, with a length of twisted safety wire holding up the carbs. I left a little slack to allow for vibration, but at least the carbs cannot fall out of the boots!
Old September 22nd, 2018, 03:16 AM   #12
maverick9611
MOTM - Feb '18
pic?
Old October 15th, 2018, 04:54 AM   #13
mgentz
Board Member
sure! just give me a couple days
Old November 3rd, 2018, 09:00 AM   #14
pb3
here's what i did on my '09. just 1 large zip tie around the filter flanges, and another to lift that to the upper frame. I'll likely use the opposite side of that frame half next time just to clear where the fuel line and vacuum tap go into the tank. but on second thought the other side is the electrical connector for the gauge reading so use your own judgement.
Pod or replacement filter vmax 2008 - 2012 Ninja 250R Tech Talk 4 August 4th, 2014 09:30 PM
K&N Pod filter mwirrick Ninjettes At Speed 13 January 10th, 2014 05:57 PM
POD filter, rejet, carb sync... lots of vibration now? fierostetz 1986 - 2007 Ninja 250R Tech Talk 3 September 25th, 2012 02:55 PM
K&N Filter or Pod jonthechron 2008 - 2012 Ninja 250R Tech Talk 6 February 17th, 2010 12:07 PM
Which pod filter do you use? null0 1986 - 2007 Ninja 250R Tech Talk 13 December 1st, 2009 12:36 PM
