Old September 9th, 2018, 12:21 PM   #1
thumper64
porting the 250 head
I'm going to be taking the head off my bike, I have a tick coming from the top end and the CCT cleaning and valve adjustment didn't fix it, so I found another head and timing chain tensioner as well as guide on eBay reasonable.
I don't expect a surge of power, but from what I've been reading, if you bump the compression and timing and maybe advance the intake cam a tooth, it could liven the bike up a bit more and add a little mid range and top end. I've already stripped what weight I can, put pod filters and a 2-1 Area P exhaust on and rejetted it. The carb tuning doesn't scare me and I've built a couple car engines, so I think I can tackle this. I have a GSXR 750, I'm just tinkering with the 250 because it's less expensive if I ruin a head, which I expect, so I'm buying a couple used ones.
Where do I work the head? I've read to leave the exhaust alone, but cleaning up casting lines and sharp edges where the bolt and runner meet shouldn't hurt. It looks like the intake side gets a little work widening the floor of the short side radius and the bowl hangs over the valve seat a bit, probably from core shift, so that could be cleaned up, though I'm not sure if I should leave a little bump in the bowl, necking down just a bit, right below the seat. Do you sand down the short side radius just a bit, or at all? That should help flow at higher RPMs. It looks like the heads I've seen have all been left with just a sandpaper finish, no polishing. For a street bike, I don't want to ruin the low end, but that's part of why I want to advance the timing a bit and bump the compression a little, even if I need to run 89 or 91 octane. I just can't find anything over 91 reliably if I'm somewhere unfamiliar.
I know the engine is about 12.4:1 compression in stock form. If I deshroud the valves, how much volume will I be able to remove again by removing the base gasket? It's 62mm wide for the bore, but how thick is the gasket? Or is there any point on this head besides just eliminating hot spots? I don't have a complete engine to assemble and clay, so I'm not sure how far I can go without P2V clearance issues. I can mill the head at work and modify cam gears to be able to adjust the valve timing back in spec.
Motorcycle noob, feel free to ignore me.
thumper64 is offline   Reply With Quote
Old September 9th, 2018, 01:40 PM   #2
What type of riding are you doing?
Where do you want improvement in powerband?
Pre-gen is already optimised for top-end power; it makes max HP pretty close to redline. All that's left is higher-lift cams with adjustable gears. One-tooth advance is too large and rough of adjustment, you'll lose all gains for all mods combined and more.
What is done in many cases like this is to narrow down the ports to improve mid-range torque. Latex is poured into port and pulled out to model its shape, then extra metal is welded in to narrow ports. Then blended in with grinding and polishing.
In end, you'll have something similar to new-gen head.
Old September 9th, 2018, 02:19 PM   #3
thumper64
It's just a street bike, to and from work, grocery store, a little fun ripping around when I find a good road on my path.
I'd like to improve mid and top end, but porting sounds like it will hurt bottom end a bit, so that's why I already plan to increase compression and timing a bit.
Old September 9th, 2018, 03:15 PM   #4
Z1R rider
Z1R rider's Avatar
MOTY - 2018, MOTM - Oct '16
Old September 9th, 2018, 03:31 PM   #5
One of the things I like about my 250 is its use of regular gasoline. I'd hate to have to use premium just for a very small HP gain.
Old September 13th, 2018, 04:27 PM   #6
thumper64
With it taking just over 4 gallons when I fill up, and premium being about 30 cents more a gallon, another $1.30 or so to fill it isn't a big deal to me. My car and other bike both take premium also. Whether I were to put an ex500 engine on or ride my other bike, I'm still going to pay more for fuel. If you expect to make more power off a motor, you're generally going to be upping compression and timing, and sometimes that means needing a little higher octane to prevent preignition. It's generally been a good bike, but I have a tick from the left cylinder that won't go away with adjusting valves or the cam chain tensioner, so I'm digging in farther and pulling the head off. While I have it off, I just figure I'll just go through another head to throw on and while I'm at it, why not just clean up the ports a bit and see if there's any free power to be gained?
I'm not expecting giant gains, but in essence it should accomplish the same end goal as putting a higher lift cam in. It'll shift the power band up a bit, but with 1st gear being as low as it is, I'm not really concerned. I'm doing this to practice a little before attempting a head for my car. If I ruin a head or two for this bike, they're $30-50 shipped for a used one off eBay and if it's a total failure of an idea then I'll have a stock head to toss back on. Hopefully I can learn a little and make my mistakes on this rather than my car's cylinder head that costs 10x as much.
Old September 13th, 2018, 07:06 PM   #7
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
You can’t move the timing a tooth. Just a couple deg.
Worlds fastest 250 ninja
Old September 13th, 2018, 10:01 PM   #8
Head porting is combination of CFD science and black-magic. Must do it incrementally in baby-steps in conjunction with flow-bench and dyno. That way it won't be too far gone if you make a tiny mistake. Can make flow-bench with automobile MAF-sensor.
It is extremely unlikely that any mods you make to pre-gen head will carry over to auto's head.
Old September 21st, 2018, 03:08 PM   #9
thumper64
In the world of CNC ported heads and such, I was hoping for measurements at different points, like below the valve seats, at the dividers... or something better than just "buy a dozen heads and swap it out over and over until you find how far to go before you ruin it". Why waste the time and money if someone has something that works and isn't afraid of sharing some insight? I know CFM isn't everything. A full on race ported head isn't going to perform right on a street motor that sees 3-8k RPM 99% of the time, and 14k RPM just that .1% of the time, or at least a similar situation with car cylinder heads where a head ported for a 1000hp dedicated race engine isn't going to work right on a 275-350hp street car. I could keep hogging a head out and then add modeling clay to see where I went too far, but again, a flow bench doesn't tell you everything.
Old September 21st, 2018, 04:13 PM   #10
Racer x
Racer x's Avatar
I can show you photos of my professionally ported head. I don’t know how much help it would be. But maybe it’s a start.
Old September 21st, 2018, 04:18 PM   #11
Racer x
Racer x's Avatar
My advice is to just clean up the casting and deshroud the valves. The idea is air velocity moves more air if it is moving faster in a small pipe. Rather than slower in a big pipe. Because we are dealing with a 12000 rpm engine we need fast moving air so big ports are not the best.
Old September 30th, 2018, 02:50 PM   #12
thumper64
I deshrouded the valves a bit, cleaned up the casting lines and just rounded over / smoothed the transitions from the runner to the bowl and sanded / wire brushed everything. It looks shiny but it's not polished.
Next I need to bring it to work to clean it again and make sure the valves seal well.
Old October 2nd, 2018, 11:06 AM   #13
bruce71198
bruce71198's Avatar
Remove the base gasket to reduce cylinder deck height, it is excessive from the factory. Mill the head to increase compression. Youn will feel the gains from this alone.
Old October 2nd, 2018, 11:54 AM   #14
Nice work! Would be interesting to see the gains when you get it all back together!
I'm following in RacerX's footsteps with these mods. Absolutely nothing I've learned from building my own flow-bench to porting numerous Porsche heads at my shop in past 20-yrs applies to these small high-revving engines.
As he mentioned, flow-velocity is key. I sent head from my CBR600RR to an outfit in UK to get head ported. Here's result with narrower ports to increase flow velocity:
CBR600RR ports
And ports from an R1 head:
Also note that flow-velocity is 2nd-order function, so profile should be spherical or parabolic in shape, not cones like original ports (linear function).
Last futzed with by DannoXYZ; October 6th, 2018 at 01:10 PM.
Old June 11th, 2022, 04:08 PM   #15
HeadPorterX
Motorcycle(s): cbr600rr
Why settle for that? There is substantial power to be found in the ex250 cylinder head.
HeadPorterX is offline   Reply With Quote
DIY porting cylinder head and valve lapping Motofool General Motorcycling Discussion 8 April 27th, 2016 09:20 AM
Inside your head: Porting cuong-nutz 2008 - 2012 Ninja 250R Tech Talk 4 July 18th, 2014 07:35 AM
Cylinder head photos - Before porting tubarney 2008 - 2012 Ninja 250R Tech Talk 1 January 25th, 2013 05:29 AM
Anyone tried porting cbr 250rr's engine in ninjette? Joule General Motorcycling Discussion 23 September 15th, 2012 08:38 PM
