Old September 12th, 2018, 02:11 PM   #1
Darksik
Darksik's Avatar
Motorcycle(s): 2010 Kawasaki Ninja 250R, 99' Suzuki Katana 600 (RIP)
Ride on rain and now won't start
How it says in the tittle, I ran my bike the Saturday in a heavy rain and now my bike won't start, the battery is OK, the cranck too, the fuel gauge is on the 2nd line, I don't think could be a gas problem, I don't know where to start I was thinking If I dry the carbs and try to start
Somebody had that problem with his ninjette?
Darksik is offline   Reply With Quote
Old September 12th, 2018, 02:29 PM   #2
taz
taz's Avatar
MOTM - May '17
check for spark then make sure there is gas getting to the carbs.
Old September 12th, 2018, 02:36 PM   #3
Darksik
Darksik's Avatar
If the problem could be the spark, how i would realize?
I want to open the drain hole of the carbs and see if the gas is leaking from that hole to discard one option
Old September 12th, 2018, 02:49 PM   #4
taz
taz's Avatar
MOTM - May '17
if you have a spare spark plug, unplug one of the wires and plug the spare into it and lay it on a good grounding spot on the bike and crank it over and and see if you see a spark. careful not to get zapped your self it smarts a fair amount.
Old September 12th, 2018, 03:29 PM   #5
Snake
Snake's Avatar
I would check the air filter to make sure that water did not get to it and is now clogged blocking sufficient air from getting to the engine. Also check your engine oil and make sure it doesn’t look milky.
Old September 12th, 2018, 10:15 PM   #6
Darksik
Darksik's Avatar
I already checked and the bike still with out start
Old September 13th, 2018, 02:39 AM   #7
Use hair-dryer on all wiring
Old September 13th, 2018, 08:21 AM   #8
Darksik
Darksik's Avatar
Even if the bike is trying to start? Because yesterday y realize the fuel filter is empty an even switching to PRI it don't fill, I think the problem could be some vacuum issue
Old September 13th, 2018, 08:26 AM   #9
or out of gas?
Old September 13th, 2018, 08:29 AM   #10
Is the tank clean inside?
Can you see the screens on the petcock to confirm they look good?
Old September 13th, 2018, 08:46 AM   #11
Darksik
Darksik's Avatar
or out of gas?
The tank is 30% full, I don't think the water can pass where you put gas
Old September 13th, 2018, 09:16 AM   #12
Darksik
Darksik's Avatar
I don't understand about the screen on the petcock
Old September 13th, 2018, 09:38 AM   #13
There are some photos in this section that show it - https://faq.ninja250.org/wiki/Rebuil...tcock/fuel_tap
They are strainers that stop any large particles in the tank from continuing on to the carbs.
Also check for this - https://faq.ninja250.org/wiki/How_do...fuel_filter%3F
The small inline filter (about 1/2 way down on the page) that is inside the fuel line at the carb inlet.
If either are restricted you won't get adequate fuel flow.
Old September 13th, 2018, 10:17 AM   #14
direction of small in-line filter is important.
The open-end is aimed towards gas-tank.
The closed pointy end is aimed towards carb.
If you put it in backwards, it will get crumpled and inverted by flow.
It will then block fuel flow
Old September 13th, 2018, 09:06 PM   #15
Darksik
Darksik's Avatar
Well, the weird thing is i put correct the fuel filter, but now won't pass gas inside the filter, maybe i need to reemplace?
Old September 13th, 2018, 09:55 PM   #16
Filter is probably coated with debris.
As test, try without filter. Does it work?
Replace with new filter.
I prefer to use small VW Bug style filter. Buy 10 for about U$D 2.00
https://www.aliexpress.com/item/Car-...846566568.html
Old September 13th, 2018, 10:11 PM   #17
Darksik
Darksik's Avatar
I Dont think is a petcock problem, i would try to make a "jump start" because i already ccleaned the air filter, sparks, drain the air filter box and the bike won't start
Old September 15th, 2018, 04:28 PM   #18
Darksik
Darksik's Avatar
UPDATE
The problem was the spark plug, the mechanic says the problem was the spark, because i put irridium spark plugs cr8eix, and the mechanic told me, that irridium spark plugs are bad for the ninja because the bikes are "old" and the mechanic put a normal spark plug and the bike work fine
Bike won't start and backfires when trying to start TrickyTriggs General Motorcycling Discussion 30 April 16th, 2018 08:35 PM
Won't start... :( HELP! deeno415 1986 - 2007 Ninja 250R Tech Talk 59 August 31st, 2013 05:53 PM
help i tried to ride home and bike won't start BlueHairSar 1986 - 2007 Ninja 250R Tech Talk 21 May 4th, 2013 09:07 PM
Rain Drenched Bike Won't Start DCBenson 2008 - 2012 Ninja 250R Tech Talk 24 April 23rd, 2012 06:19 PM
Bike won't start after the rain >_< Zombiphone 2008 - 2012 Ninja 250R Tech Talk 8 March 27th, 2011 06:30 AM
