Go Back   ninjette.org > General > !%@*#$%!)@#&!%@ I crashed!
Old September 20th, 2018, 03:09 AM   #1
Scorp65
Scorp65's Avatar
Motorcycle(s): 1992 Yamaha XJ600, 2009 Ninja 250R
June 8th I crashed my ninja
The crash was 100% my fault. I was fatigued with a million and one things on my mind. Which means I should not have been on the bike. I even left out without my jacket.
I ended up running wide on an entrance ramp to a bypass.I was running about 70 on speedometer (63 +/- actual) as I left asphalt onto grass and chert. I made a second mistake at that point and grabbed me a bunch of brake. The front wheel tucked under and the bike went down hard. I on the other hand tumbled about 75'. I would hear a whack as my head, shoulder and right arm made contact..then I would see sky, then whack. Its one of those turns that keeps getting tighter. I use this ramp regularly at the same speeds with no problems.
I and the bike came out much better than we could have. I had a broken finger two broken ribs and some road rash and assorted bruises. Probably would have lost finger if not for gloves.
The bike ended up with a bent right handle bar, broken right peg mount, brake lever broken, brake pedal mangled, and several breaks on all plastics on right side
Scorp65 is offline   Reply With Quote
Old September 20th, 2018, 10:07 AM   #2
CaliGrrl
CaliGrrl's Avatar
Motorcycle(s): Ninja650
Sucks that you crashed, but I'm glad you weren't badly hurt. How you feeling?
Old September 20th, 2018, 04:28 PM   #3
Scorp65
Scorp65's Avatar
I'm good now. Actually I've been healed up and bikes been on the road more or less for about 3 weeks. Didn't want to post until I had most of the adjustments made.
Here is a picture of my finger less than 2 hours after the crash and the helmet I was wearing. The face shield came off on about the third or fourth impact.
[IMG][/IMG]
[IMG][/IMG]
Old September 20th, 2018, 04:41 PM   #4
Snake
Snake's Avatar
Glad to heat you are ok. One of life’s lessons to learn by.
Old September 20th, 2018, 05:16 PM   #5
snot
sammich maker
snot's Avatar
MOTM - Apr '15
Helmet did it's job. Glad it wasn't worse.
Old September 20th, 2018, 10:17 PM   #6
CaliGrrl
CaliGrrl's Avatar
Yep- that's why we wear gear. And full-face helmets. Mine had scratches on the visor- would have been my face in a beanie-helmet.
Old September 21st, 2018, 03:03 AM   #7
Scorp65
Scorp65's Avatar
Thanks I am very thankful I wasn't injured any more than I was. Helmet definitely did its job very well. I am pretty sure I will stick with Scorpion brand for my helmets. I wish I had been wearing my jacket, I have left out on bike maybe three times without it on. Was not a good day to run off without it. I have had a few surgeries on my hands, I firmly believe if I hadn't been wearing good gloves I would have had another at the least. My right hand was between the handle bar and ground when the bar was bent.
[IMG][/IMG]
Old September 21st, 2018, 04:56 AM   #8
Z1R rider
Z1R rider's Avatar
MOTY - 2018, MOTM - Oct '16
Glad your healed up. Just wondering, was it your little finger that broke?
Old September 21st, 2018, 05:10 AM   #9
Scorp65
Scorp65's Avatar
Yes it was
Old September 21st, 2018, 03:55 PM   #10
Koala
Koala's Avatar
Motorcycle(s): 2017 Ninja 300 Winter Test Edition
MOTM - May '18
Happy to hear that you at least wore your helmet and gloves that day. Looks like they definitely helped you out.
Unregistered now go away or I shall taunt you a second time!
"To ensure you're giving your very best, blind yourself of all negativity, relax your mind, put inhibition to rest and drive hard toward your goals like it's the last thing on earth." - csmith12
Koala is offline   Reply With Quote
Old October 29th, 2021, 08:52 PM   #11
IndestructibleNinja
IndestructibleNinja's Avatar
Motorcycle(s): 08' ninja 250 and Honda XL600
Ah yes, the dreaded footpeg mount. For some reason it's 80 frickin dollars. But the pegs? Both 5$ on ebay
IndestructibleNinja is offline   Reply With Quote
Old October 31st, 2021, 05:07 PM   #12
Misti
Misti's Avatar
Dang, glad you are ok!
I appreciate that you opened with the fact that it was 100% your fault- many riders blame outside conditions, cold tires, the bumps on the road, other people when a lot of times it's a mistake that they made entirely. I also appreciate you saying that you shouldn't have been on the bike in the first place as it may help someone make the right decision in the future to not ride when they are not feeling 100%. Anyway, I appreciate your honesty and am glad you weren't hurt worse. Heal up!!
superbikeschool.com
www.motomom.ca
Darling Ninja crashed today. Alex !%@*#$%!)@#&!%@ I crashed! 15 May 7th, 2018 05:50 AM
Not a Ninja, Still Crashed. thisisbenji !%@*#$%!)@#&!%@ I crashed! 11 June 7th, 2016 11:30 AM
Crashed....not on the ninja chef !%@*#$%!)@#&!%@ I crashed! 8 November 13th, 2013 01:49 AM
Crashed my ninja 300:( waffles666 !%@*#$%!)@#&!%@ I crashed! 20 April 9th, 2013 02:25 PM
2012 Cal24 Announcement! June 8th - 10th Alex Ride Reports 9 June 11th, 2012 09:25 PM
