Old September 20th, 2018, 03:27 AM   #1
Scorp65
Scorp65's Avatar
Motorcycle(s): 1992 Yamaha XJ600, 2009 Ninja 250R
My Ninja Rebuilt by myself
I repaired all the plastics using ABS cement. I painted with Krylon ($3.86 a can at Walmart).
I bought a set of Ebay clip-ons with a lot of adjust ability. I had a master cylinder and clutch perch with new shorty adjustable levers I had bought for my Yamaha. I believe they came off an ER6-N. I have a basket case 2004 ninja I robbed the rearset brackets off of.
And here she is:
[IMG][/IMG]
[IMG][/IMG]
Scorp65 is offline   Reply With Quote
Old September 20th, 2018, 03:58 AM   #2
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
Looks great
Worlds fastest 250 ninja
Old September 20th, 2018, 04:14 AM   #3
Scorp65
Scorp65's Avatar
Originally Posted by Racer x View Post
Looks great
Thanks, it is a 20' or so paint job though. That was only way I could get it back on the road by the time I was healed enough to be back on the road.
Old September 20th, 2018, 06:15 AM   #4
You did a lot of nice work to get that in shape again, congratulations!
If you decide you want the paint to look better close-up, sand it a little with some 400 grit wet and dry, and put a coat of Spraymax 2K on it. It's a very tough 2-part clear that comes in a spray can with a push button on the bottom to mix the two parts. You'd need at least two cans at a bit over $20 per can.
Old September 20th, 2018, 08:16 AM   #5
gantt
gantt's Avatar
Motorcycle(s): 2019 Ninja 400, Sold 2012 Ninja 650, Sold 2009 Ninja 250r, Sold 2007 DRZ400s
nice man. as long as it rides, it looks good enough for me to ride.
better to fix it yourself than not ride
gantt is offline   Reply With Quote
Old September 20th, 2018, 10:06 AM   #6
CaliGrrl
CaliGrrl's Avatar
Motorcycle(s): Ninja650
Nice!
Old September 20th, 2018, 04:37 PM   #7
Scorp65
Scorp65's Avatar
Thanks. If I want to have the paint look better I will probably go ahead and buy a Chinese fairing set. The plastic work is about a 20' job in some places also. There were a total of three pieces missing that I just put duct tape on backside and started pouring thin layers of ABS cement
Old September 20th, 2018, 04:41 PM   #8
Scorp65
Scorp65's Avatar
Thanks. That's the way I feel about it for sure. I don't trust any of the shops around here, so I just learn how to do everything myself.
Old September 20th, 2018, 07:25 PM   #9
maverick9611
"a legend in my own mind"
maverick9611's Avatar
MOTM - Feb '18
most excellent
"trying not to get old"
Old September 21st, 2018, 03:32 AM   #10
Scorp65
Scorp65's Avatar
I wanted to mention that I really like the clip-on's that I got and I absolutely love the way she handles with the one inch drop in the front. And yes I have already maxed her out (105 on speedo so about 95) and no instability at high speed straight-line
Old September 21st, 2018, 06:25 AM   #11
How much riding experience do you have?
Old September 21st, 2018, 06:33 AM   #12
Scorp65
Scorp65's Avatar
About three years. My first bike was the 92 Yamaha Seca II. Not that much experience, but in a little over two and half years I put about 9500 miles on the Seca II
Old September 21st, 2018, 08:42 AM   #13
That's good to hear. I wondered when you said you ran off a ramp and crashed. Take it easy on the top speed runs though. You really should go to a local track for the high speed fun.
Old September 21st, 2018, 09:05 AM   #14
Scorp65
Scorp65's Avatar
I intend to,that top speed run was made at 2:00am on a long stretch of four lane. I wanted to be sure after dropping the front an inch it didn't make the bike twitchy or anything
Old October 3rd, 2018, 11:52 AM   #15
Ceeloo Yello
Motorcycle(s): 250
Where's the before shot?
Old October 11th, 2018, 06:43 AM   #16
motorjunkiematty420
Ninja 250 and beta 300
motorjunkiematty420's Avatar
Motorcycle(s): 2004 Kawasaki Ninja 250
nice paint looks like a yamaha from the blue check out my spray can jobhttps://www.youtube.com/watch?v=CO4vg6W69cs&t=81s
check out the youtube ninja 250 motovlogshttps://www.youtube.com/watch?v=CO4vg6W69cs&t=81s
motorjunkiematty420 is offline   Reply With Quote
Old October 17th, 2018, 03:03 PM   #17
ck.mecha
Motorcycle(s): 1969 Benelli Cobra 125, 1970 Honda CB160, 2009 Kawasaki 250R
I have two areas of concern, if youve already looked these over feel free to disregard.
1) Youve used a front brake master off a bike with two calipers. Your lever "feel" is probably reduced at low braking pressure. Drive safe
2) Looks like a replacement bolt was used on the upper triple clamp, please use high grade bolt there for your safety
ck.mecha is offline   Reply With Quote
Old October 19th, 2018, 12:16 AM   #18
Scorp65
Scorp65's Avatar
The bike the master cylinder came from does have dual brakes in front, but the master cylinder piston is the same as the ninjette oem at 14mm. It actually seems to have better "feel and feedback" than oem. Bolts are grade 8.8
Old November 3rd, 2018, 06:21 PM   #19
Karman
Motorcycle(s): 2010 Ninja 250r Red
Awesone
Karman is offline   Reply With Quote
Old November 3rd, 2018, 07:45 PM   #20
Awesome job on repairs and paint-job. Reminds me of something.. a superhero?
Old November 3rd, 2018, 08:20 PM   #21
Scorp65
Scorp65's Avatar
Originally Posted by Karman View Post
Awesone
Thanks. A few of my friends have commented that she looks like a superhero. That wasn't the intent, but I'll take it I guess. I just wanted her not to look like every other one on the road.
For those who like to see thing rebuilt swarfman64 Off-Topic 6 May 2nd, 2015 10:26 PM
Rebuilt engine in my garage ForceofWill Off-Topic 7 October 12th, 2012 04:50 AM
[topix.net] - One year on, bridge still not rebuilt Ninjette Newsbot Motorcycling News 0 August 9th, 2011 08:10 PM
Rebuilt status HELP! blink General Motorcycling Discussion 7 July 16th, 2011 10:43 AM
