Old November 15th, 2012, 12:30 PM   #41
It's a fuel tap, not a petcock.
Fuel won't get into the engine unless the fuel rail is pressurized and the injector is powered. So you're likely good there.
I'm just using the word everyone else is using. Are you saying that the kit replaces the petcock?
FWIW, fuel is getting in the engine for others with a bad petcock. It seems to happen to F and J bikes.
Edit: I recall seeing pictures that I'll look for. Until then:
On closer inspection I found the problem. The diaphragm is fine.
Inside the petcock is a small metal piston with an O-ring around the end of it. The piston is mounted in the center of the rubber diaphragm. The end of this piston is held against a circular opening inside the petcock by a spring. Fuel flows through this opening, from the tank to the engine.
When engine vacuum is applied, the piston is pulled away from the opening and fuel flows. When the vacuum goes away, the spring pushes the piston back into place and the flow stops.
Here's the defect:
At the base of the opening is a ring of white packing material that looks like teflon. This is what the end of the piston seals against.
On mine, this white ring is defective, preventing the piston from seating.
This is not a replaceable or repairable part. You need to replace the entire petcock.
Old November 15th, 2012, 12:33 PM   #42
Yes, the kit replaces the vacuum operated petcock with a fuel tap that has 2 nipples; 1 for fuel out, and one for a return line.
Yes, I know that happens with the petcock. It happened with mine. I just ended up buying a new petcock for $60 and never had problems again.
Old November 15th, 2012, 12:37 PM   #43
lolibater
lolibater's Avatar
Motorcycle(s): 2005 ZX6R, 2011 Sprint GT
To anyone who is about to install this kit, do yourself a favor and get 2 dual disconnects from Motion Pro. You'll thank me later when you don't have to drain your tank.
"The enemy is fear. We think it is hate, but it is fear." - Gandhi
lolibater is offline   Reply With Quote
Old November 15th, 2012, 12:40 PM   #44
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
Or you know, get a CA bike so that you don't have to replace the petcock
AFM #676
Supersports are for n00bs
Old November 15th, 2012, 12:40 PM   #45
Yeah, I'll have to drain my tank in spring when I do a valve adjustment
Old November 15th, 2012, 01:19 PM   #46
lolibater
lolibater's Avatar
Lol mine IS a CA bike! My bike had no petcock when I bought it though. Another thing to add to the long list of PO shortcomings.
On a lighter note (from the mayhem in the other thread): Is it saturday yet?! I just wanna have my bike back so I can check the o2 >> harness >> injector wiring
Old November 15th, 2012, 01:34 PM   #47
I have a CA tank. What is different that lets be get away with not replacing the petcock?
Old November 15th, 2012, 01:46 PM   #48
flynjay
flynjay's Avatar
CA tanks have a return line plumbed into them from the factory. For pregens, the petcock will have to be modified to allow fuel to flow without vacuum (I believe removing the little o-ring on the vacuum line will allow this.
Old November 15th, 2012, 02:29 PM   #49
lolibater
lolibater's Avatar
Interesting. Well if I ever EFI another 250, I'll make sure to grab a CA model and/or CA tank. The disconnects are pretty cool, but always drip a bit out the end when first disconnected.
Mmmmmmm............gas fumes
Old November 15th, 2012, 06:58 PM   #50
The ones I tried never stopped dripping. MMMMMM gas fumes indeed
Old November 15th, 2012, 07:16 PM   #51
Jiggles
Jiggles's Avatar
MOTM - Apr '13
Yea with the CA tank you have all these annoying emissions crap plugs in the tank that you have to plug/filter when you take the crap off. The cool thing about these ports though is that you can just attach the return line to one and keep your stock petcock. Easy and simple
AFM #676
Old November 15th, 2012, 07:17 PM   #52
Anyone here besides me ever taste gas accidentally? Bleh. Dreadful stuff. idk how these ninjettes can drink that stuff straight. At least add some mixer or something
Old November 15th, 2012, 07:36 PM   #53
Jiggles
Jiggles's Avatar
MOTM - Apr '13
Haven't tasted it but the endorphins given off from when I'm tuning have mixed with the smell of gas so that when ever I fill my tank I end up needing to change my panties as well
AFM #676
Old November 16th, 2012, 05:21 AM   #54
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
I have been racing and hot rodding for my entire life. Yes I have tasted gas. The worst is when you syphon gas with a garden hose. Done wrong you get a mouth full. Nothing worse. the taste is there for a week. O there is worse. Don't get gasoline in your ear.! That hurts bad.
Worlds fastest 250 ninja
Old November 16th, 2012, 08:44 AM   #55
lolibater
lolibater's Avatar
I've drank it straight on the rocks. Puts hair on your chest.
Old November 16th, 2012, 08:59 AM   #56
ai4px
ai4px's Avatar
Motorcycle(s): 650r 2009 Vulcan 800 2005
A guy I work with is from up north. Years ago, he had an old pickup with the fuel tank behind the seat. The water in the bottom of the tank froze and plugged the fuel line, so he pops the fuel line off the pump and blows really hard into the line to force the ice off. It did... and oh by the way, he didn't take the cap off the tank, so it just pressurized the tank and as soon as he quit blowing the pressure pushed gas back into his mouth before he knew it. Just too funny to not tell.
It's all about the curves. If you ride, you understand. If you have a stick skinny g/f and ride, you're 1/2 way there.
ai4px is offline   Reply With Quote
Old November 16th, 2012, 09:00 AM   #57
ai4px
ai4px's Avatar
So was the solution here that the O2 sensors and injectors were crossed up?
Old November 16th, 2012, 09:09 AM   #58
lolibater
lolibater's Avatar
I get the bike back in my possession from where it broke down tomorrow morning. I'll definitely keep you guys updated.
Old November 17th, 2012, 01:22 PM   #59
lolibater
lolibater's Avatar
Bike is en route to my tampering facility lol.
Old November 17th, 2012, 01:55 PM   #60
EMSRacer07
EMSRacer07's Avatar
nice let us know how it goes
Old November 17th, 2012, 04:32 PM   #61
lolibater
lolibater's Avatar
The wiring was all correct. I wiped the ECU again and the bike started up perfect. It started to idle kind of funny; lower and lower like it was running out of gas. I looked down and noticed that the worm clamp on the feed line to the pump was loose and spraying out some gas there.
Maybe this was also causing that weird idle a little while ago. Either way, got a new clamp on it, and the bike ran perfectly for the 20 min that I idled it. I tried to start it immediately after that, while still hot, but the battery was dead from all the cranking (from the other day) and not being run at high rpms. Now I get to test my new battery tender out for the first time!
Seems like an improvement though
I also plan to leave the stock cans on until I am 100% sure that everything is running properly.
Old November 18th, 2012, 07:04 AM   #62
n4mwd
n4mwd's Avatar
Its best not to use worm clamps on high pressure fuel injection hoses. Use FI clamps which you can get at most auto parts places.
My Ninja Blog
Old November 18th, 2012, 08:50 AM   #63
lolibater
lolibater's Avatar
That's what I meant by worm clamp, my mistake.
Old November 18th, 2012, 01:19 PM   #64
lolibater
lolibater's Avatar
The bike ran great on my 20 min ride today. No weird idle, no idle hunt, nothing weird at all. It even started right up 5 min after turning it off from being hot. Feels better than it ever has too.
Not going to let the bike troll me again; I'll give it a month before I call it good to go.
Old November 18th, 2012, 06:56 PM   #65
Lychee
sail away
Lychee's Avatar
Awesome!
Old November 19th, 2012, 09:08 AM   #66
lolibater
lolibater's Avatar
Just got to work on it this morning. Everything running great.
Hopefully it doesn't rain lol.
Old November 19th, 2012, 11:32 AM   #67
Lychee
sail away
Lychee's Avatar
It's not gonna rain. I rode as well. Are you running the learning mode?
Old November 19th, 2012, 11:34 AM   #68
lolibater
lolibater's Avatar
Yep, haven't used Rich mode in a long time. How long do you usually leave yours in Eco to learn?
Old November 19th, 2012, 11:47 AM   #69
Lychee
sail away
Lychee's Avatar
I have the carburetor. I know plenty about electronics, but this thing is a mystery to me. Seems simple enough though. My first tear down will be during thanksgiving day.
Old November 25th, 2012, 08:11 PM   #70
Mine has been on and off learning mode all summer. But it was pretty darn good after a week of commuting and twisty riding.
Old November 25th, 2012, 08:12 PM   #71
lolibater
lolibater's Avatar
I'll have to give it a week. I fear that the weather will be rather ****** once this bike actually is good to go
Old November 25th, 2012, 09:10 PM   #72
<--- Ohio.
Just sayin.
Old November 25th, 2012, 09:17 PM   #73
lolibater
lolibater's Avatar
You ride rain or shine? I mean ****, I got the rain gear, but I'm just lazzzzzzzzzzzzzzy. The front wheel bearings on my car are completely shot, and I have to wait until Saturday to get those fixed. No rain forcasted for tomorrow though!
Old November 25th, 2012, 09:20 PM   #74
nononono that's not it at all. I mean I'm having the same issue. The bike is running well, but the weather is finally acting like winter. Bike is in storage until May when I get out of school.
Old November 25th, 2012, 11:11 PM   #75
lolibater
lolibater's Avatar
I guess I should count my blessings that I actually have some decent weather days year round in CA
Old November 26th, 2012, 09:15 AM   #76
lolibater
lolibater's Avatar
Coldest day the bike has ever seen today. Bike fired right up, drove perfect to the gas station (where it has historically had lots of problems), and started right back up after the fill up. Quite the varying starting situations today.
On another note, riding in fog that has nearby airports grounded SUCKS.
Old November 26th, 2012, 12:15 PM   #77
Yepp, keep the headlight on low and pray that your tail light isn't out
Do you notice that your after-start/warm-up mix is a bit rich at cold temps? I started it at 40F (cranked and started right up, WOOT!) and it was great once it warmed up and whatnot, but when it was idling after starting, it was idling awful low. That says to me that the mix is too rich there. It normally idles a touch over 1500, and idles at like 1300 at startup, but it was at like 1100 and it was fine, but it was annoying. I want it perfect at 1300 no matter the temp I guess I just need to play with those values a little bit.
Old November 26th, 2012, 12:29 PM   #78
lolibater
lolibater's Avatar
mine idled at my set idle perfectly while cold. The bike was in a heated garage though, so I'm not sure if that had any effect.
Old November 26th, 2012, 12:31 PM   #79
I likely did. Mine was in a cold garage with the door open. The whole engine was the same temp as the outside air haha. I'm still impressed with how well the bike adjusted to the cold, even in open loop mode. It ran well.
Old November 26th, 2012, 12:44 PM   #80
lolibater
lolibater's Avatar
Yeah, if it was that cold out, I could see it being an issue.
Just to contrast, it also started up and idled the same exact way after it was warm as it did when it was cold. I was used to having it idle a bit lower, and then move up when it's warmed, but it's seemed to just idle perfectly from the get go. Can't complain.
ECOTRONS EFI Kit Question patriots21 2008 - 2012 Ninja 250R Tech Talk 20 October 3rd, 2015 09:19 AM
DIY: Installing the Ecotrons EFI Kit on a Pregen n4mwd Videos 174 May 10th, 2013 08:48 AM
Interest in 2nd GB for Ecotrons EFI kit choneofakind Motorcycle-related 54 June 11th, 2012 04:04 PM
