Old October 11th, 2013, 08:53 AM   #121
FvnnyL3tt3r1ng
FvnnyL3tt3r1ng's Avatar
Motorcycle(s): Ninja 250 2001
Originally Posted by cuong-nutz View Post
That tool I have is plenty strong and big enough. Unless you're clamping down very tight or have to cocked at an angle, I can't see how you would break anything.
How is the tool not big enough? Can you elaborate?
I couldn't get it to fit over the hub with enough distance to hold when I clamped down.... I must be doing something wrong. w/e the case the nut is back on via impact wrench.
I broke a piece of the hub off a few days ago after I wedged something in between it and the outer basket to keep it from spinning as I attempted to torque with a breaker bar. Not a good idea.
Mods: Offset clutch pressure plate
Old October 11th, 2013, 10:10 AM   #122
FvnnyL3tt3r1ng
Rebuilt engine is on. Starts up but won't go into gear. Can feel it kick into first but doesn't move when I release clutch...
Old October 11th, 2013, 10:28 AM   #123
cuong-nutz
cuong-nutz's Avatar
Check to see if your shifter claw is attached properly to the shift drum thing.
When I had reinstalled my shift drum washer, it fell out of alignment and it wouldn't shift into second.
You put the shift forks back in correctly?
HalfFast Racing Team
Old October 11th, 2013, 11:30 AM   #124
FvnnyL3tt3r1ng
I'm positive on the shift forks. I was looking at the shift arms on the shift drum and I wasn't exactly sure if they were on right. From what I remember they pretty much just latch on in one position without any adjustment though......
Old October 11th, 2013, 04:43 PM   #125
FvnnyL3tt3r1ng
Played with the clutch tool tonight. Was able to get it fit but the tips of the tool are like next to each other on the hub. I dont think you can actually fit it on opposite sides as depicted.
Have to find a store that carries the engine mounting bolt's nut. M10 x1.25 I believe. Both hardware stores I went to were out of them.
Old October 11th, 2013, 05:17 PM   #126
n4mwd
n4mwd's Avatar
http://www.lowes.com
They don't have them at Royal Palm, but the other ones have them.
My Ninja Blog
Old October 11th, 2013, 05:40 PM   #127
FvnnyL3tt3r1ng
@n4mwd
Any idea why my bike doesn't wanna put power to the rear wheel in gear?
Old October 11th, 2013, 06:26 PM   #128
n4mwd
n4mwd's Avatar
No idea. Could be a million reasons. Did you test the tranny when you had it apart to make sure it was back together right? I think Racerx put out a video showing how to test it. They all have to be in there just right. I had a problem with mine, but figured it out before final assembly.
My Ninja Blog
Old October 11th, 2013, 08:32 PM   #129
cuong-nutz
cuong-nutz's Avatar
@n4mwd
Clutch releasing all the way?
Old October 11th, 2013, 08:42 PM   #130
The_big_dill
The_big_dill's Avatar
Motorcycle(s): 1987 Ninja 250 custom gold
Check this along with everything else you can before pulling that thing apart again, hopefully you won't have to resort to taking it apart again.
The_big_dill is offline   Reply With Quote
Old October 12th, 2013, 07:52 AM   #131
FvnnyL3tt3r1ng
This is how I finally resorted to putting this tool on. It definitely will not open wide enough to fit on opposite sides. I'm still not sure on how the tool was intended to be used because I can't get the tool on how you are describing it or how it is depicted.
Old October 12th, 2013, 07:54 AM   #132
FvnnyL3tt3r1ng
Yeah I wouldn't even be convinced I needed to pull it apart again until checking 100 other things. I suspect something in the clutch assembly.
I played with the clutch a little yesterday so I doubt that is it but I'll re check as it does seem symptomatic of a tight clutch cable.
Old October 12th, 2013, 08:32 AM   #133
cuong-nutz
cuong-nutz's Avatar
Attachment 27151
Back the adjuster all the way out, and pull open the "jaws", and readjust the adjuster so the jaws stay locked in position like a vice grip.
Old October 12th, 2013, 09:20 AM   #134
mgentz
Board Member
that tool should be able to fit on opposite sides. I have one just like it and mine did...?
As for the not going into second, did you ever remove your transmission fully? Including the positive neutral bolt on top of the motor?
I recommend taking the clutch hub off, reinspecting everything per the manual for fit and then using an allen key to turn your transmission through the gears. Up and down about four or five times. once completed, ENSURE that the plate that bolts to the shift drum is in proper alignment and that your shift forks (external) are in properly. Then try it with the gear shift lever before putting on the clutch hub. Does it work?
I say all this because I had an issue with mine getting stuck and I believe it to have been caused by the positive neutral finder. The above procedure is how it fixed itself.
Old October 12th, 2013, 10:55 AM   #135
FvnnyL3tt3r1ng
Interesting. I just pulled the clutch basket off of my spare engine which I hadn't been into before and I saw the washer/spacer that goes against the case behind the basket was put on reverse of how I put it on. Now I was told to put it on with the larger side facing outward, which engine is wrong?
Yes I did take the transmission out fully. I didn't take it through the gears with an allen key though.
Part no. 92026 http://www.motosport.com/motorcycle/..._-EX250/CLUTCH
It really seems it should go on with the larger/untapered side butted up against the case but even that diagram has it the opposite/counterintuitive way.
Old October 12th, 2013, 10:56 AM   #136
FvnnyL3tt3r1ng
Yeah my tool is just too small I think. There's no way it will go on opposite sides even if I back the adjuster all the way out. I think how I have it should work though.
Old October 12th, 2013, 11:47 AM   #137
n4mwd
n4mwd's Avatar
The beveled washer points to the engine. The larger end touches the basket. That's how it fits up against the bearing. If the new engine had it wrong, then somebody was in there before you were and put it in backwards.
My Ninja Blog
Old October 12th, 2013, 12:27 PM   #138
mgentz
Board Member
Bevel in first. Its in the manual.
Old October 12th, 2013, 12:29 PM   #139
mgentz
Board Member
There is no way that will be strong enough. The torque required for that nut is a lot for tension to hold.
Old October 13th, 2013, 02:29 PM   #140
FvnnyL3tt3r1ng
Ok so first, I am retarded. ^^^ You were right when you said it wouldn't hold enough torque. I simply had to pull the jaws open wider after I had backed the adjuster bolt....D'oh.
Now, I took of the clutch basket, everything was installed right.'
I spun the rear wheel as I took the tranny through all the gears several times. There was no problem doing this, and I didn't have to mess with anything.
I put the basket back on, torque the hub to 100#, put the discs back on, button everything back up.
Start the bike, goes into gears as I walk the bike down the street shifting quickly. If I stop the bike in gear it doesn't stall, not even stumble.
I loosened the clutch cable all the way, same thing! WTF am I doing wrong here lol. I'm positive I put the shift forks back in their spots correctly.
I tried this as well: I put the bike on the rear stand and quickly shifted it into first, the rear wheel spun and even seemed to be putting out a bit of power for idle......
Do I have to put the shifter arms on the drum in a certain gear or something??????? I have no clue what is going on..... Puzzled
I'm sure someone on here knows something I don't, they just haven't commented yet......
@Racer x @n4mwd @choneofakind @Motofool
Who am I missing
Old October 13th, 2013, 03:02 PM   #141
n4mwd
n4mwd's Avatar
Its hard to say without seeing it. Did the top half of the case fit properly over the gears without having to be torqued? Does the clutch feel right?
My Ninja Blog
Old October 13th, 2013, 03:06 PM   #142
FvnnyL3tt3r1ng
The clutch pulls and releases normally, I don't feel the clutch plates meshing whatsoever though....
The case went on fine I made sure all the bearings and dowels lined up. That's why I did it about 10 times. I even pulled it the last time to double check the shift forks were on correctly......
Old October 13th, 2013, 04:37 PM   #143
@Motofool
Sorry Justin, excuse my retardation but I cannot understand what the problem you are trying to solve is.
Old October 13th, 2013, 04:39 PM   #144
FvnnyL3tt3r1ng
Is it remotely possible the fiber plates are backwards and that's the issue????
Old October 13th, 2013, 04:39 PM   #145
FvnnyL3tt3r1ng
Just trying to figure out why my clutch doesn't seem to be engaging....
Old October 13th, 2013, 05:01 PM   #146
n4mwd
n4mwd's Avatar
Are you sure you put back the correct number of plates? Should have fiber to start and fiber to end. Also, I assume you latched the clutch actuator properly when you reinstalled the clutch cover. Clutch springs put on correctly?
My Ninja Blog
Old October 13th, 2013, 05:21 PM   #147
FvnnyL3tt3r1ng
Fiber to start fiber to end yes. 5 fibers, 4 metals so it's hard to mess up.
I put the actuator on right yeah.
I put the springs over the final piece that covers the clutch plates followed by the bolts....
Old October 13th, 2013, 05:22 PM   #148
Check this old post and schematic:
http://www.ninjette.org/forums/showp...6&postcount=31
Do you feel the resistance and movement of the springs in the clutch lever?
Old October 13th, 2013, 05:25 PM   #149
FvnnyL3tt3r1ng
Yeah the lever pops back if you let it....The bolts had the bottomed out feeling when I installed them over the springs.
And everything is installed correct!
Old October 13th, 2013, 05:35 PM   #150
.....And everything is installed correct!
Then 13187 is pressing all the plates together and against 13087.
Then 13095 is dragged and becomes a solid part with the crankshaft and its rear gear makes the transmission rotate.
Can you see actually happening through the oil refill hole?
Old October 13th, 2013, 05:40 PM   #151
FvnnyL3tt3r1ng
Spoke w/ a bike mechanic and we narrowed it down to this ^^^^^ D'oh!!
Old October 13th, 2013, 05:42 PM   #152
FvnnyL3tt3r1ng
I could see this when the cover was off. However, the bike was not actually running and putting out power yet!
Old October 13th, 2013, 05:43 PM   #153
The_big_dill
So that was your problem, the plates were on backwards?
Old October 13th, 2013, 05:46 PM   #154
FvnnyL3tt3r1ng
Haha. I'm pretty sure I saw them facing the wrong way earlier today. Didn't hit me they had to be facing a certain direction. Was in too much of a rush...
Old October 13th, 2013, 05:49 PM   #155
Just for the record: I disagree with that being the cause of a lack of power transmission.
Old October 13th, 2013, 05:59 PM   #156
FvnnyL3tt3r1ng
We shall see tomorrow. Come to think of it the fiber plates have markings on them which I believe I faced inwards..... D'oh
Just for reference, page 5-7 in the kawi manual is what led me to this conclusion.
Old October 13th, 2013, 08:49 PM   #157
n4mwd
n4mwd's Avatar
I don't think the plates direction makes much of a difference. There is an optimal way to install them, but it should still work if they are installed backwards.
If the problem is the clutch not grabbing, something is preventing it from compressing. You aligned the notches on the outer pressure plate right?
My Ninja Blog
Old October 14th, 2013, 04:26 AM   #158
FvnnyL3tt3r1ng
Hmm, notches you say?
Old October 14th, 2013, 04:47 AM   #159
mgentz
Board Member
Or someting further in like aligning and fully engaging the crank gear?
Old October 14th, 2013, 06:01 AM   #160
n4mwd
n4mwd's Avatar
Clutch Alignment marks
Alignment marks
My Ninja Blog
Racer X engine rebuild. Racer x 1986 - 2007 Ninja 250R Tech Talk 14 April 21st, 2018 04:26 PM
Engine Teardown and Rebuild Rustitution 1986 - 2007 Ninja 250R Tech Talk 77 February 27th, 2017 09:17 PM
Need Help Oil,engine rebuild meggyewill 1986 - 2007 Ninja 250R Tech Talk 10 July 22nd, 2014 02:39 AM
Two quick engine rebuild questions jayman87 1986 - 2007 Ninja 250R Tech Talk 16 March 3rd, 2013 07:26 AM
Engine Rebuild Question jayman87 1986 - 2007 Ninja 250R Tech Talk 16 December 21st, 2012 09:30 PM
