Old October 14th, 2013, 07:20 AM   #161
cuong-nutz
cuong-nutz's Avatar
Did you check to see if your friction disks are within spec? Try spinning the clutch basket and holding the clutch pressure plate with the transmission in gear. The pressure plate should spin without slipping.
HalfFast Racing Team
Old October 14th, 2013, 03:43 PM   #162
FvnnyL3tt3r1ng
FvnnyL3tt3r1ng's Avatar
Motorcycle(s): Ninja 250 2001
Originally Posted by n4mwd View Post
Alignment marks
Wow, I did not know this. The manual doesn't say anything about it as far as I know..... At least my Haynes doesn't!
Mods: Offset clutch pressure plate
Old October 14th, 2013, 06:03 PM   #163
cuong-nutz
cuong-nutz's Avatar
here it is in the FSM in red
Old October 16th, 2013, 05:10 PM   #164
FvnnyL3tt3r1ng
Ok, the dots on the pressure plate were off by about 90 degrees. At least I learned something.
Now, Driving the bike I'm getting smoke out of the exhaust. New oil, new filter, oil level correct..... Is it normal when breaking an engine in??
Temp never broke 190F because of the cool weather......
Old October 16th, 2013, 05:13 PM   #165
mgentz
Board Member
A little smoke is normal from a new motor.
Glad you got the clutch issue fixed.
Old October 16th, 2013, 05:19 PM   #166
FvnnyL3tt3r1ng
Good, now is a steady plume of smoke normal? How often should I change this oil??
Old October 16th, 2013, 05:34 PM   #167
n4mwd
n4mwd's Avatar
A LITTLE smoke is normal. A steady plume is not. Are you sure its oil and not coolant?
So its either your head gasket leaking or your oil rings.
My Ninja Blog
Old October 16th, 2013, 05:47 PM   #168
FvnnyL3tt3r1ng
It only happens at fast speeds it seems. It was dark out but cruising along I see smoke out of the exhaust but when I come to a stop it disappears.....
I'm positive it is oil. I know a little bit is burning off my exhaust because some spilled as I took the side clutch cover off, but the smoke out of the exhaust worries me.
Old October 16th, 2013, 07:15 PM   #169
mgentz
Board Member
If I doesn't go away in 100 miles or less, there is a problem. I only had smoke for one ride.
Old October 16th, 2013, 07:19 PM   #170
FvnnyL3tt3r1ng
Ok. It is making a strange mechanical sounding noise. I just adjusted the valves so I know that's a big percentage of it.
I'll do a little ride tomorrow and see what it decides to do.
Old October 16th, 2013, 08:27 PM   #171
mgentz
Board Member
Noise is bad. Check that over before going too far.
Old October 18th, 2013, 04:28 PM   #172
FvnnyL3tt3r1ng
Smoke went away.
At a stop I saw coolant leaking down my radiator..... I think my head gasket is blown it got too dark to tell. That's what the noise is I believe.... It lags from a stop now too........
Old October 18th, 2013, 04:33 PM   #173
mgentz
Board Member
Normally it would still smoke with a blown head gasket...but not always. Are you losing a lot of coolant? Where is the leak exactly?
Old October 18th, 2013, 04:50 PM   #174
FvnnyL3tt3r1ng
That's what I gotta check out.... I saw a little puddle forming at a stop, bike never got hot but yeah there was steam from the coolant hitting the pipes the smoke out of the exhaust is gone from what I can tell.
I felt around and I saw the coolant leaving from the radiators bottom mounting bracket so I still have to trace is back. The engine is making a strange robotic type noise so I'm leaning towards head gasket. Bike does run, not full compression in my opinion though
Old October 18th, 2013, 06:25 PM   #175
mgentz
Board Member
Do you have a comp tester?
Old October 18th, 2013, 06:34 PM   #176
n4mwd
n4mwd's Avatar
Don't run it like that. You could run out of coolant and warp the heads. A new gasket wont fix that. Only a machine shop can. Sounds like its time to pull the heads and check for level. Then re-assemble with a new gasket.
Is this the engine you bought or the original engine you put back together?
My Ninja Blog
Old October 18th, 2013, 06:39 PM   #177
FvnnyL3tt3r1ng
Original
Old October 18th, 2013, 06:52 PM   #178
mgentz
Board Member
What he said. A small amount of investigation only while keeping tabs on the temps. It might not be the head gasket though based on your initial leak findings but more investigation is needed.
Old October 19th, 2013, 04:50 AM   #179
n4mwd
n4mwd's Avatar
I should also point out that the temp gauge is not going to work right when the coolant is too low. It measures the coolant temperature and not the actual head temperature. If the coolant is too low and doesn't reach it, its not going to read right.
My Ninja Blog
Old October 19th, 2013, 07:39 AM   #180
FvnnyL3tt3r1ng
My vapor tech gauge won't put out a reading unless there is coolant passing over the sensor. Comes in handy!
Old October 19th, 2013, 01:42 PM   #181
FvnnyL3tt3r1ng
Just picked up a laser thermometer can someone shoot me a reading of their cylinder head when you have a chance.
Old October 19th, 2013, 02:37 PM   #182
FvnnyL3tt3r1ng
@n4mwd
I know you have a laser thermo too, if it's not too much to ask for.
Old October 19th, 2013, 04:52 PM   #183
n4mwd
n4mwd's Avatar
I don't have a laser thermometer. I have the infrared kind. I think it was about 160-170F or something like that after a ride.
My Ninja Blog
Old October 19th, 2013, 05:24 PM   #184
FvnnyL3tt3r1ng
Ok, lol this is funny. I think when I was filling the coolant some of it got into the radiator's mount and it's just been sitting there. I'm tracing the coolant back and it's only showing up on the bracket, nothing on any of the hoses or engine is wet....
I'm gonna blow some air in there tomorrow and see what happens, as well as check my coolant level.
I need to run a compression test as well maybe my engine is just acting this way because of the new rings + hone??? It is making a rattle noise like the cam chain is loose (which it isn't). But like I said I just did a valve adjustment there's a good reason it is making a lot of noise...
Also, the head read at 170 F as well..... I shot all around the engine and the only thing higher than 200 was the exhaust.
Old October 19th, 2013, 05:25 PM   #185
FvnnyL3tt3r1ng
One thing that did catch my eye was an empty thread on the cylinder head above & in between the header mounts.... Not the coolant drain bolt but above that about 4 inches or so.....
Old October 19th, 2013, 05:51 PM   #186
n4mwd
n4mwd's Avatar
Huh? I don't understand what you are saying here. Maybe a photo would help?
My Ninja Blog
Old October 19th, 2013, 06:31 PM   #187
FvnnyL3tt3r1ng
There is a (hub is it called?) spot with threads going into the cylinder head, probably look the same as the coolant drain bolt in the front of the engine
It can't be seen from the parts diagrams online so if you'd like I can take a pic tomorrow. It's just threads going into the cyllinder head above the coolant drain and inbetween and a little above the header mounts.
Old October 20th, 2013, 05:09 AM   #188
n4mwd
n4mwd's Avatar
The only coolant drain I am aware of is located on the water pump. A picture would help.
My Ninja Blog
Old October 20th, 2013, 06:55 AM   #189
cuong-nutz
cuong-nutz's Avatar
Does it look like a mirror image of the exhaust header stud holes?
Old October 20th, 2013, 07:09 AM   #190
FvnnyL3tt3r1ng
Best shot I could get with my phone.
And N4mwd, sorry the drain bolt is on the cylinder block, not head. You can see it in this pic too. The threads I'm talking about are above cylinder two's header.
Old October 20th, 2013, 07:11 AM   #191
cuong-nutz
cuong-nutz's Avatar
Attachment 27246
Yeah, those are just mirrored exhaust header stud holes. The left (or in this case the right side looking at the picture) doesn't have them. You'll see the same thing on the bottom left too.
Old October 20th, 2013, 07:18 AM   #192
FvnnyL3tt3r1ng
Ok.
Any ideas as to where the coolant seen leaking on the right side of the radiator bracket could be coming out of? I could only trace it back to the engine mounting bolt on the front of the engine......
Oh, and all the hoses are intact.
Old October 20th, 2013, 07:22 AM   #193
cuong-nutz
cuong-nutz's Avatar
Perhaps you have a sliver of a leak in your radiator? Radiator cap not sealing properly? Leaking from coolant temp sensor?
Old October 20th, 2013, 07:23 AM   #194
FvnnyL3tt3r1ng
No idea.... I guess a pressure tester would come in handy right about now?
Old October 20th, 2013, 07:36 AM   #195
cuong-nutz
cuong-nutz's Avatar
Have you tried looking for the leak while the motor was running?
Old October 20th, 2013, 07:38 AM   #196
mgentz
Board Member
Dye and a flourescent light?
Old October 20th, 2013, 08:00 AM   #197
FvnnyL3tt3r1ng
I have, no luck
Old October 20th, 2013, 08:17 AM   #198
I have, no luck
Wrap toilet paper around the suspicious area of leak.
It may be a little pinhole tha leaks out only under pressure.
Old October 20th, 2013, 09:43 AM   #199
FvnnyL3tt3r1ng
I have, no luck
Meant to type I have no idea.... Not sure if that was my phone correcting or what.
Just ran the bike and noticed a drop of coolant on top of cyl 2 spark plug boot. Took gas tank off and ran bike but of course nothing happened in this time. Thermostats housing was all dry as well as all hoses. I think the radiator fan may be flinging it from the fins somewhere. Will a pressure test show radiator leaks? I can buy a used rad. Assembly for ~$50
Old October 20th, 2013, 10:10 AM   #200
cuong-nutz
cuong-nutz's Avatar
A pressure tester will. I wonder if Autozone loans them out.
Racer X engine rebuild. Racer x 1986 - 2007 Ninja 250R Tech Talk 14 April 21st, 2018 04:26 PM
Engine Teardown and Rebuild Rustitution 1986 - 2007 Ninja 250R Tech Talk 77 February 27th, 2017 09:17 PM
Need Help Oil,engine rebuild meggyewill 1986 - 2007 Ninja 250R Tech Talk 10 July 22nd, 2014 02:39 AM
Two quick engine rebuild questions jayman87 1986 - 2007 Ninja 250R Tech Talk 16 March 3rd, 2013 07:26 AM
Engine Rebuild Question jayman87 1986 - 2007 Ninja 250R Tech Talk 16 December 21st, 2012 09:30 PM
