Old November 7th, 2013, 07:20 AM   #121
FvnnyL3tt3r1ng
FvnnyL3tt3r1ng's Avatar
Motorcycle(s): Ninja 250 2001
Originally Posted by quarterliter View Post
Displacement and horsepower are not what caused this engine harm. Any wet sump engine would have experienced the same issue. But for real, a buel blast would be your best bet.
What I was getting at is the engine requires more revs for the same hp
Mods: Offset clutch pressure plate
Old November 7th, 2013, 08:36 AM   #122
quarterliter
Motorcycle(s): 2004 Ninja 250
I'm not convinced you are correct. That piston looked like it had experienced very high heat caused by oil starvation. I have heard of the oil light coming on during heavy breaking, but I think that the time spent doing a stoppie is relatively small compared to time doing a wheelie. Justin do you do stoppies for extended periods of time?
Old November 7th, 2013, 01:17 PM   #123
n4mwd
n4mwd's Avatar
The oil pickup is in the rear of the engine so a wheelie would cause the pickup to be under more oil and not less.
Like I said, running on its side is the biggest threat - say after a failed wheelie.
Justin was experiencing high engine temps from an unknown cause prior to his rebuild. The engine also had a rolled bearing. I don't know if it was the same cylinder or not. Ironically, the high engine temps forced a rebuild before he damaged his crank. He was definitely quite lucky in that respect.
But because he uses full synthetic oil, I don't believe the problem was positional. I believe that something clogged up an oil passage and that was what did him in.
I have seen other bikes where the oil filter is installed incorrectly which crams debris at high pressure into the bearings and crank passages. I don't know if this was a factor with Justin's bike or not. It could have happened prior to him getting it even if he did everything correctly.
As far as I know, the piston and wrist pin are splash lubricated rather than pressure lubricated. The rods are solid and not hollow like some engines so there is no oil passing through them.
My Ninja Blog
Old November 7th, 2013, 04:16 PM   #124
fast1075
Motorcycle(s): 2006 Ninja 250, 2004 Buell XB12s, Honda 110 Elite
Could be foam related. The KZ-650/700/750 series would fail rod bearings if overfilled even slightly and run hard. I ran a windage tray and a sump baffle in my 810 turbo/nitrous drag bike successfully when others were killing cranks and rods.
Spinning a rod bearing in a stock motor is going to be a lube failure. There "should" be a spray notch in the rod to direct some oil towards the underside of the piston for cooling and lubrication.
Although it is a possibility the cylinder overheated causing it to seize. That will also destroy rod bearings. I built a 740 motor with MTC 13.5 forged pistons once that would tighten up and spin a bearing. Turned out the piston clearance needed to be quite a bit more than was specified. The pistons were "old school" forgings with very little silicon. They really expanded a lot with a 50 horse shot. Once I figured that out and set it up loose, it ran like a raped ape for two full seasons, but eventually broke a skirt from being loose.
"They don't pay me enough to ride this thing!" Kenny Roberts after winning the Indy Mile on the TZ750 powered Grand National bike.
fast1075 is offline   Reply With Quote
Old November 7th, 2013, 07:12 PM   #125
FvnnyL3tt3r1ng
The brakes on this bike don't stoppie well, so no; not a chance.
In both my engines the issues are in cylinder one. Is it a coincidence that it is last in line to be fed oil in the camshafts? What happens when you overfill anyways?
Old November 7th, 2013, 08:01 PM   #126
If the level is high enough the oil will become aerated (foamy/filled with air) and the engine will lose oil pressure.
Old November 16th, 2013, 07:30 PM   #127
The_big_dill
The_big_dill's Avatar
Motorcycle(s): 1987 Ninja 250 custom gold
This is because the crank comes into contact with the oil.
The_big_dill is offline   Reply With Quote
Old November 17th, 2013, 03:18 PM   #128
FvnnyL3tt3r1ng
ahhh didnt know that
Help!!!!!!!! - bike won't start auntymunga 2008 - 2012 Ninja 250R Tech Talk 5 August 18th, 2014 06:54 AM
Bike won't start !HELP! carterdenny 2008 - 2012 Ninja 250R Tech Talk 7 June 5th, 2014 08:40 AM
bike won't start... nebraskan 2008 - 2012 Ninja 250R Tech Talk 4 May 11th, 2011 01:48 AM
