June 22nd, 2018, 11:48 AM | #1 |
Join Date: Jun 2018 Motorcycle(s): '07 Ninja 250r Posts: 2
Warped head shaving
Just bought an 07 for 200 dollars thinking it was a blown head gasket issue... Turns out it was a warped head, probably 0.020-0.030 out of square. Is it safe to shave it square that far without having valve clearance issues? Would the compression be too high?
Also, if anyone knows if it is possible to get a thicker gasket, that would solve my problems I think but I would just like some opinions. Thanks! |
June 22nd, 2018, 01:03 PM | #2 |
Hi and Welcome!
Simplest would be stacking up thicker/multiple base-gaskets to make up for shaving. Cometic makes single-layer gasket in 0.012" (C8828). They can probably custom make you multi-layer steel gasket in any thickness you want. Make sure both surfaces are smooth with RA around 30-60 max Don't use copper gasket, it seals great for high-compression & boosted applications, but not for very long. Would require stronger head-studs with more clamping. It doesn't have spring-loaded feature of steel gaskets to accommodate regular minute head-lifting. |
June 22nd, 2018, 01:13 PM | #3 |
MOTM - Sep '18, Feb '16
That is to much to machine. A good machine shop can twist and heat the head and get some of The warp out. .019 is the service limit I think.
June 22nd, 2018, 04:05 PM | #4 |
Or find a cheap head on eBay.
June 22nd, 2018, 07:04 PM | #5 |
Thanks, fellas. I really appreciate the advice. I think I may just take the easy route and get a cheap one off of eBay and save me some effort and maybe make the warped head a winter project.
June 22nd, 2018, 10:33 PM | #6 |
Be sure to have block checked out as well. Deck should be flat. Make sure threads for head bolts are good and not stripped. Might be cause of original blown head-gasket and resultant warped head.
Help. Shaving off key hole?? | AceOfHeartless | 2008 - 2012 Ninja 250R Tech Talk | 14 | December 1st, 2017 06:46 AM |
too short to ride =( seat shaving anyone? | Alisha_Ardella | 2008 - 2012 Ninja 250R Tech Talk | 103 | June 23rd, 2014 05:24 AM |
Warped rotor | The_big_dill | 1986 - 2007 Ninja 250R Tech Talk | 4 | August 11th, 2013 04:13 PM |
How to know if rotors are warped? | 2fidyswag | 2008 - 2012 Ninja 250R Tech Talk | 16 | June 30th, 2013 11:07 AM |
[topix.net] - American Choppers kicks off head shaving campaign | Ninjette Newsbot | Motorcycling News | 0 | February 8th, 2011 12:10 PM |
