Old May 19th, 2013, 03:30 PM   #1
lilmitchy777
lilmitchy777's Avatar
Motorcycle(s): 2004 ninja 250
Weird push start issues
Hello, this is my first post. i read these forums a lot but i just recently made an account. (today actually) i was wondering if someone could address the issues i am having. so my battery died today on my way to work, my bike was running fine when i left. then i tried push starting it. when i got it going in 2nd my engine idled at 5k and my rpms shot up to 10k when i hit the brakes. (back and front did it) when i pulled in the throttle it did not do anything.
lilmitchy777 is offline   Reply With Quote
Old May 19th, 2013, 05:39 PM   #2
FvnnyL3tt3r1ng
FvnnyL3tt3r1ng's Avatar
Motorcycle(s): Ninja 250 2001
Ummm....... if it's shooting up that high you def. wanna check your accel/decel cables and your carb's butterfly spring.
Have you messed with those recentlY?
Old May 19th, 2013, 05:41 PM   #3
I'm not understanding why the revs shot up when you hit the brakes. Any way you could rephrase what is happening a different way? Not sure what you mean by pulled in the throttle either.
Old May 19th, 2013, 05:48 PM   #4
FvnnyL3tt3r1ng
How do you know your battery is shot btw?
Old May 19th, 2013, 06:39 PM   #5
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
Your tachometer malfunctions when the battery is dead. It'll bounce around but that's not actually what your rpms are at
AFM #676
Supersports are for n00bs
Old May 19th, 2013, 06:46 PM   #6
FvnnyL3tt3r1ng
Oh lol. Noob. Did the engine yell or didn't it?
Old May 19th, 2013, 07:25 PM   #7
lilmitchy777
when i ride around in 2nd once i get it started if i pull the front brake in my bike will accelerate like as if i were opening up the throttle and the engine will yell. i used a multimeter to determine the battery was shot btw. i have not messed with the cables recently as well.
Old May 19th, 2013, 07:52 PM   #8
Jiggles
Jiggles's Avatar
MOTM - Apr '13
Well first of all, get a new battery
AFM #676
Old May 19th, 2013, 07:53 PM   #9
lilmitchy777
that i will do! i will post how the bike reacts once i get a new battery on it. thanks for all the replies!
Old May 19th, 2013, 08:33 PM   #10
FvnnyL3tt3r1ng
Something must be caught for that to be happening. Go to the right side of the bike and follow your brake lever down to the brake rotor. It's a very short path and if anything is connected you should be able to tell.
You sure this doesn't happen when you turn the bars? This would be because the throttle cable is too tight.
Old May 19th, 2013, 10:39 PM   #11
Jiggles
Jiggles's Avatar
MOTM - Apr '13
Someone else had this issue before. Can't remember if a new battery fixed it for him
AFM #676
Old May 20th, 2013, 08:37 AM   #12
lilmitchy777
so i put in a new battery and it does not do that anymore. now the issue i am having is that when i turn the choke all the way down it idles at 5k rpms with no throttle or choke.
Old May 20th, 2013, 08:38 AM   #13
lilmitchy777
btw i like your motorcycle description jiggles
Old May 20th, 2013, 08:48 AM   #14
FvnnyL3tt3r1ng
After you warm the bike up fully turn your idle adjust knob all the way down. This would be counterclockwise facing the left side of the bike. Then turn it back until you hit 1300 +/- 50 rpm (or whatever you want your idle at). If it has trouble maintaining a low idle then your carbs a dirty fyi.
Old May 20th, 2013, 09:06 AM   #15
lilmitchy777
it was the idle knob i just fixed it. it was somehow stuck at 4k. i used a monkey wrench and some good ole man power to twist it back haha.
Old May 20th, 2013, 09:33 AM   #16
FvnnyL3tt3r1ng
Sounds rusted?
Mine turns with two fingers....
Old May 20th, 2013, 07:27 PM   #17
lilmitchy777
no idea what it was. but it worked haha.
Old May 26th, 2014, 08:08 PM   #18
https://www.ninjette.org/forums/show...ighlight=weird
Originally Posted by CZroe View Post
Obviously, the only thing shared between the front brake and the rear is electrical (switches wired to the tail/brake light).
Edit: This is my friend's bike, once again. The same one that had the "battery tested good but will not start without a jump start" issue. I can't take a look at it in person because he lives clear across the country.
Never figured out why, but do know that replacing the battery fixed it.
weird voltage/no start issue thedrewski86 2008 - 2012 Ninja 250R Tech Talk 8 April 16th, 2014 09:47 PM
Weird Cold Start Noise Joshorilla 2008 - 2012 Ninja 250R Tech Talk 2 October 14th, 2012 02:07 PM
Push start EFI? Jiggles General Motorcycling Discussion 8 July 17th, 2012 01:10 PM
[topix.net] - On Two Wheels: Snowfall, sub-zero temps may push the start of riding se Ninjette Newsbot Motorcycling News 0 February 10th, 2011 06:50 PM
[crash.net - WSBK] - Haslam re-issues plea for Suzuki factory push Ninjette Newsbot Motorcycling News 0 July 10th, 2010 01:40 AM
