Old December 5th, 2014, 07:13 AM   #1
Jetfoi
Jetfoi's Avatar
Motorcycle(s): 2013 zx6r and 1995 250r
New Issue...
Hello All
Recently I had an issue with my carb which the members on here helped me narrow down. Well after getting my bike running and after a test drive I came back home parked it and this morning there was a gas leak. So it seems at the tank on the petcock the little clamps are on all the hoses correctly and the hoses are in good condition yet the main hose that goes from the petcock to the carb just streams out gas where it connects to the petcock. It is almost as if the tube is bleeding out gas...
Has anyone had this issue? Could it just be that the tube is old and needs to be replaced or am I looking at a diaphragm issue in the petcock?
spend all the spare time on two wheels
Jetfoi is offline   Reply With Quote
Old December 5th, 2014, 08:24 AM   #2
Ghostt
Ghostt's Avatar
Your petcock is shot, save your time, and money and get a new one, the cost of rebuilding it isn't much cheaper, due to you need two separate kits, as they for some reason don't make just one.
New one cocost about $65.00
http://www.partzilla.com/parts/detai...1023-1139.html
Also be sure to order the orings and new bolts, trust me you'll be better off in the long run.
Rebuilding kits are about $60 total.
K&L Supply Diaphragm Only for Fuel Petcock Repair Kit 18-6638 https://www.amazon.com/dp/B0055DWO60..._s1CGub1W9N3PH
K&L Supply Fuel Petcock Repair Kit 18-2723 https://www.amazon.com/dp/B001KO2JRW..._U1CGub05DT5NT
IMHO not worth it rebuilding, also be sure to check vacuum and fuel lines for wear, holes, and cracks, if in doubt replace them.
violente et ignorantia
ZX-2R BLOG
Old December 5th, 2014, 09:23 AM   #3
Jetfoi
Jetfoi's Avatar
Awesome! Thanks I was looking into getting a new one anyways and found full kits on kawasaki parts store and revzilla so i'll go ahead and get it.
Old December 5th, 2014, 08:12 PM   #4
Originally Posted by Jetfoi View Post
........... Has anyone had this issue? Could it just be that the tube is old and needs to be replaced or am I looking at a diaphragm issue in the petcock?
Does this happen for any position of the handle?
You could try tightening the two little screws on the flat washer around the handle.
If you wrap toilet paper around the petcock and hose, you will be able to see the source of the leak.
Please, read this:
http://faq.ninja250.org/wiki/Rebuild...tcock/fuel_tap
Old December 5th, 2014, 08:19 PM   #5
Ghostt
Ghostt's Avatar
True, but I'm figuring the age of the petcock, I'm better it's just wore out being 19 years old
ZX-2R BLOG
Old December 8th, 2014, 05:16 AM   #6
Jetfoi
Jetfoi's Avatar
Please, read this:
Oh I can def see the leak from the main line from the petcock to the carb...its at the top of the hose and the hose literally looks like it is bleeding
Old December 19th, 2014, 03:19 PM   #7
pale horse
Does your bike still have the stock, wire hose clamps?
I had a similar leak, same fuel line. I thought I was going to need to replace the petcock also but I pulled the stock wire clamps and replaced them with a regular hose clamp and that stopped the leak. For a couple bucks, its worth a check.
First post.....guess I should make my way over to the intro section and stop lurking
pale horse is offline   Reply With Quote
Old December 19th, 2014, 03:24 PM   #8
dcj13
Participant
dcj13's Avatar
Motorcycle(s): '94 K75 std
Welcome, Art! Good suggestion for a first post!
Clutch issue ZX-Dominance 1986 - 2007 Ninja 250R Tech Talk 8 July 2nd, 2013 10:23 PM
Has anyone ever actually has an issue with Fram? 2fidyswag 2008 - 2012 Ninja 250R Tech Talk 3 June 30th, 2013 02:40 PM
Got an issue Mizono General Motorcycling Discussion 29 June 29th, 2011 12:27 PM
[superbikeplanet.com] - Suzuki: Haslam's Wrist Issue Should Not Be An Issue Ninjette Newsbot Motorcycling News 0 May 11th, 2010 07:50 AM
Have a lean issue with my bike, issue with coasting enricher. twiggy2cents 1986 - 2007 Ninja 250R Tech Talk 7 February 24th, 2010 06:54 PM
