Old December 29th, 2014, 01:19 AM   #1
arncliffe
Motorcycle(s): Ninja 250r 2012
Oil filter o-ring different sizes??
Hi guys, got a bit confused about subject. I have 3yo ninja, all this time I`ve changed oil myself, and everytime I bought oil filter and o-rings from the shop I got my bike-original Kawasaki parts. Last time I decided to save some money and got I think Emgo filter and o-rings. When I started fitting I found out the big o-ring is much thicker then original . Original is about 2.5 mm, and Emgo was 4 mm. Original just slips in a channel, Emgo doesn`t want to go in.Is it normal to have o-ring this thick? I re-used old one, but not sure -for next oil change I would like to get K&N set from ebay- what o-rings they have?Thanks.
arncliffe is offline   Reply With Quote
Old December 29th, 2014, 01:28 AM   #2
Linkin
Down Under
Linkin's Avatar
Motorcycle(s): Kawasaki ZXR250C Ninja
I bought a box of goodies from Motorcycle Superstore including a K&N 401 which came with the correct o-ring. Just get the K&N part, can't go wrong really.
Which oil are you planning on using? For my next oil change I'll be using Delo 400 (for diesel engines mainly but suitable for bikes & wet clutches)
Linkin is offline   Reply With Quote
Old December 29th, 2014, 01:37 AM   #3
arncliffe
Linkin-thanks for replay) I`m using Delo 2 oil changes already- very happy with it. Gear changes so much smoother then with motul.
Old December 30th, 2014, 12:36 PM   #4
Flying
Motorcycle(s): 2010 Ninja 250
The K&N 401 kit comes with the correct o-ring, but there have been a quite few kits circulating around that have o-rings that don't fit. Try the WIX filter.
Old December 31st, 2014, 06:18 AM   #5
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
All my filters came with the O-Ring, but I just get the Kawasaki filter.
TEAM ALFALFA
www.apexassassins.com
Oil filter crosses over with Honda filter smokinsingle 2008 - 2012 Ninja 250R Tech Talk 4 April 19th, 2014 08:47 AM
Mystery o-ring on oil screen? chadh92 1986 - 2007 Ninja 250R Tech Talk 12 May 17th, 2013 04:16 PM
Loss of oil and Air filter soaked in Oil 08ninja250 2008 - 2012 Ninja 250R Tech Talk 19 August 9th, 2010 05:35 PM
change oil filter, without draining oil? peter330 2008 - 2012 Ninja 250R Tech Talk 5 May 30th, 2010 01:08 PM
