Old June 3rd, 2009, 02:56 PM   #1
Broom
Track Junkie
Broom's Avatar
Motorcycle(s): '08 Ninja 250r Track Bike, DR350 commuter, KDX220 woods bike
tach replacement
i don't know much about how the tach and stuff works, but if i go down to the mc junkyard and pick up a little analog tach and wire it up to the stock wiring, will it work?
i also need a temp gauge. if i remember right the new 250 only has a dummy light, so i'll probably just wire up an aftermarket temp gauge myself and skip the stock wiring altogether.
any suggestions on how to get these two jobs done cheaply?
Las Escobas -- Track Bikes Save Lives
JonBroom.com
Broom is offline   Reply With Quote
Old June 3rd, 2009, 03:12 PM   #2
randomwalk101
self wrencher
randomwalk101's Avatar
where's your stock ones? let us know if it'd work or not...should cost too much doing it that way i think.
Old June 3rd, 2009, 03:14 PM   #3
Broom
Track Junkie
Broom's Avatar
sold the stock dash... good place to make some cash!
JonBroom.com
Old June 3rd, 2009, 03:39 PM   #4
ztrack157
The Sportisi Master
ztrack157's Avatar
Motorcycle(s): 2008 Ninja 250
Broom I picked up a Faze temp gauge off ebay for like $11. It works great wiring is fairly simple as well.
Sportisimoto USA is born.
ztrack157 is offline   Reply With Quote
Old June 3rd, 2009, 03:51 PM   #5
HKr1
IC2(SW)
HKr1's Avatar
Tach gets its signal from one of the igntion coils. Long as the bike you get the new tach from is wired the same, using the same type signal. Should work............
GL
Old June 3rd, 2009, 04:49 PM   #6
Banzai
Psychic war veteran
Banzai's Avatar
Just make sure whatever tach you use is for, or can be set up for, a 2 cylinder. For most aftermarket tachs, that means either cutting some wires inside or on the back of the tach, or setting jumper pins. Stock tach takes a feed from the CDI/coil BLACK wire, but the GREEN wire to the other coil will work as well.
Old June 3rd, 2009, 06:27 PM   #7
HKr1
IC2(SW)
HKr1's Avatar
Originally Posted by Banzai View Post
Just make sure whatever tach you use is for, or can be set up for, a 2 cylinder. For most aftermarket tachs, that means either cutting some wires inside or on the back of the tach, or setting jumper pins..
Wouldnt that be a 1 cylinder? Your only getting a signal from one of the two coils. If there was one coil getting fired twice, for cyl's 1 & 2..... wouldnt that be a setting for a twin
What do you think?
Old June 4th, 2009, 04:13 AM   #8
Banzai
Psychic war veteran
Banzai's Avatar
What do you think?
Nope! He needs a motorcycle specific product.
Each cylinder fires only ONE time for each revolution of the crank (which is what the tach is keeping track of), so you only need one timing reference. The internal workings of the tach keep track of everything else. Since we have two coils, each has a trigger wire coming from the CDI, and fires only one time per revolution. Thus, you only need a sense from either, but NOT both.
If you were to take two signals and route them to the tach, it would double count, and you'd get TWICE the RPMs indicated that the engine was actually turning.
Most tachs have only 4 wires. 1 power +, 1 ground, 1 backlighting power +, 1 RPM coil sense. Aftermarket tachs usually either have a series of wires that you cut to set the cylinder count, or jumper plugs that you have to put in place.
For cars, they pretty much come standard set up as 8 cylinder and assume ONE coil, in which case for each 8 triggers counted, it indicates ONE RPM. If the car has multiple coils (like one coil for every two cylinders or one for each), you have to either compensate with your set up or get a different tach). For motorcycles, they usually come set up for 4 cylinders, and you adjust them from there.
Old June 4th, 2009, 05:14 AM   #9
HKr1
IC2(SW)
HKr1's Avatar
That was my question to you You first mentioned needing a tach for a twin(two pulse). Being 250r is using two coils, thats 1 pulse each... Like a 1 clyinder tach
Guess were all on the same page now
Old June 4th, 2009, 05:34 AM   #10
Banzai
Psychic war veteran
Banzai's Avatar
Delayed Tach 07_25_stl 1986 - 2007 Ninja 250R Tech Talk 8 January 13th, 2015 07:21 PM
Digital Tach wanarace94 2008 - 2012 Ninja 250R Farkles 11 May 7th, 2014 07:23 AM
Tach does not exceed 4k bryzenga 1986 - 2007 Ninja 250R Tech Talk 4 October 18th, 2013 06:59 PM
Help me fix my tach! corksil 2008 - 2012 Ninja 250R Tech Talk 7 October 1st, 2013 04:53 PM
Another tach issue Cosmos 2008 - 2012 Ninja 250R Tech Talk 2 July 19th, 2013 06:04 AM
