Old December 15th, 2017, 06:15 PM   #1
maverick9611
"a legend in my own mind"
maverick9611's Avatar
MOTM - Feb '18
el cheapo radiator guard install
why the newgen 250 has no guard to protect radiator is quite strange. buying one is worse. they are overpriced and selection is few and far between. so i made my own. i used shock absorber mounts(1/4-20 thread) i just cut into two pieces. the rubber is resting on the core. i have slight overhang widthwise into the tanks. horn relocated to coil support.( i run sticks so it was a free mount) the material is plastic 1/8"
perforated.
"trying not to get old"
Last futzed with by maverick9611; December 16th, 2017 at 04:19 AM.
Old December 15th, 2017, 06:20 PM   #2
maverick9611
MOTM - Feb '18
its winter in georgia, so cooling will be fine. summer will be true test on airflow thru guard.
Old December 15th, 2017, 06:30 PM   #3
My pregen has a nice black screen in front of the radiator. I wonder if you can put one of those on a newgen.
Old December 15th, 2017, 06:48 PM   #4
maverick9611
MOTM - Feb '18
the ones i saw were at least $60. jim do you have a pic of your screen?
Old December 15th, 2017, 07:59 PM   #5
It's the stock screen. This is about the clearest photo I have at the moment. You can just about see that it mounts to the frame of the radiator separately from the four radiator mounting bolts. They're not expensive: https://www.ebay.com/itm/87-07-KAWAS...dYCNg3&vxp=mtr
Old December 15th, 2017, 08:04 PM   #6
maverick9611
MOTM - Feb '18
nice
Old December 15th, 2017, 09:08 PM   #7
EffaMoulton
EffaMoulton's Avatar
Motorcycle(s): 2010 Ninja 250r SE
I like this, I think I’m going to make one for my bike.
EffaMoulton is offline   Reply With Quote
Old December 15th, 2017, 09:27 PM   #8
The thing that's surprising to me is that newgens don't have a screen.
Old December 15th, 2017, 10:45 PM   #9
What material is it?
Old December 16th, 2017, 03:04 AM   #10
maverick9611
MOTM - Feb '18
perforated plastic 1/8"thick. color black. my local machine shop gave a piece. i did see it being used as a return exhaust cover for ventilation.
Old December 16th, 2017, 03:07 AM   #11
maverick9611
MOTM - Feb '18
nice to have horn hidden, i never liked it there anyways. besides it sounds weak. need to find the same kind i put on my zrx1200. it was quite loud.
Old December 16th, 2017, 03:32 AM   #12
Ram Jet
Ram Jet's Avatar
https://www.ebay.com/itm/OEM-FACTORY...dYDXt6&vxp=mtr
Bill
Old December 16th, 2017, 07:05 AM   #13
The stock one is expanded steel in a thin steel frame.
Bill, the one in your link is about twice the price of the one in my link in post 5 above.
Old December 16th, 2017, 07:38 AM   #14
Ram Jet
Ram Jet's Avatar
Yep.
Bill
Old January 12th, 2018, 12:09 PM   #15
fred smoot
fred smoot's Avatar
Motorcycle(s): 1996 Ducati 900SS/SP 45k miles
guard....
check out mc-master-carr for perforated metal sheets.....you still want max airflow, not reduced airflow...overheating, bad.
Fred
'09 Ninja 250R track only SOLD
"If everything seems under control, you're not going fast enough." -Mario Andretti
fred smoot is offline   Reply With Quote
Old January 12th, 2018, 02:45 PM   #16
maverick9611
MOTM - Feb '18
Fred
link?
Old January 12th, 2018, 06:37 PM   #17
fred smoot
fred smoot's Avatar
guard....
www.mcmaster.com will get you there.....
Old January 30th, 2018, 04:57 AM   #18
tgold
Motorcycle(s): 2006 1050 Speed Triple, 2010 250 Ninja racebike, YZF320RR? Racebike
MOTM - Nov '15
Fred
This is on a better path, but these radiator guards can be highly restrictive with regard to airflow. My issue with the OP's guard is twofold: First, the holes are too large and can still let rocks through, and second, there aren't enough holes which will cause turbulent airflow which would significantly reduce the heat transfer efficiency of the radiator. All of these guards will reduce airflow. The question is how much before it becomes a problem. I would put a stock guard on my bike before an aftermarket one.
tgold is offline   Reply With Quote
Old January 30th, 2018, 05:35 AM   #19
Ram Jet
Ram Jet's Avatar
Thumbs up
Agreed.
Bill
Old January 30th, 2018, 02:12 PM   #20
maverick9611
MOTM - Feb '18
the new gen doesn't have a guard at all. if it overheats I'll drill more holes it it. a aftermarket guard is $50 plus.
Old January 30th, 2018, 02:33 PM   #21
yeah!
https://www.revzilla.com/motorcycle/...SABEgKAa_D_BwE
Ouch!!!
Old January 30th, 2018, 02:37 PM   #22
Ram Jet
Ram Jet's Avatar
Oh. Well, it might not be too difficult to adapt a pre-gen guard. Maybe easier than starting from scratch. Just sayin'.
https://www.ebay.com/itm/2003-KAWASA...!US!-1&vxp=mtr
Bill
Old January 30th, 2018, 03:59 PM   #23
maverick9611
MOTM - Feb '18
that's not el cheapo for sure. come springtime, i'll drill it to death.
Old February 24th, 2018, 08:27 AM   #24
maverick9611
MOTM - Feb '18
more holes
Old February 24th, 2018, 08:38 AM   #25
Ram Jet
Ram Jet's Avatar
more holes
Well, since Ninja's run much cooler engine temperatures than is healthy (my guess is about 130-150 degrees. You'll at least get your engine closer to a healthy operating temperature.
Bill
Old February 24th, 2018, 10:14 AM   #26
maverick9611
MOTM - Feb '18
the real question bill is why on new gen did they leave off the radiator guard?
Old February 24th, 2018, 10:23 AM   #27
I imagine it was to save a buck or two.
FS: 08-12 250R Radiator Guard DJK Motorcycle-related 2 June 10th, 2015 08:02 PM
Radiator guard DEXSPEED 2008 - 2012 Ninja 250R Farkles 17 March 18th, 2013 02:41 PM
[motorcyclistonline] - Cox Racing Radiator Guard Ninjette Newsbot Motorcycling News 0 January 25th, 2011 01:40 AM
