Old February 4th, 2018, 10:15 AM   #1
Ninjas
Motorcyclist
Ninjas's Avatar
Motorcycle(s): Kawasaki ninja 250r
2005 kawi ninja 250r vacuum not sucking fuel from petcock
Ok, so here's what's been done. We've had to replace a piston, as we all know, rockers, cams, etc all had to be removed for this. Everything was put together again after the new piston and rings were installed.
The issue is this, my carbs are not pulling fuel through the vacuum supply line. It seems to be positive vacuum instead of negative vacuum.
Does anyone know or have any ideas? My brain is racked, I've checked about everything I could, except the carbs, which is my next task. The bike was running completely fine up until #2 piston had a dime sized hole directly in the center. Im hoping it's just something that I overlooked due to being tired.
At one point while checking sparks on the plugs it decided that my hand was a better earth than the frame.
Ninjas is offline   Reply With Quote
Old February 4th, 2018, 11:19 AM   #2
Hose reversed at petcock?
Or hoses at carbs?
Measure vacuum coming from carbs, needs at least 10 in.Hg.
Last futzed with by DannoXYZ; February 4th, 2018 at 02:28 PM.
Old February 4th, 2018, 11:24 AM   #3
Ninjas
Motorcyclist
Ninjas's Avatar
Measure vacuum coming carbs, needs at least 10 in.Hg.
I'll do that as soon as I find a place that has a vacuum gauge. Aside from that, it's blowing air(it shouldn't be blowing) rather than sucking air, keeping my petcock vac diaphragm shut. Hoses are in the same positioning as when the bike was running fine before the piston fragged.
Old February 4th, 2018, 11:36 AM   #4
Check your valve-clearances and cam-timing if it's puffing air instead of sucking.
Old February 4th, 2018, 11:41 AM   #5
Ninjas
Motorcyclist
Ninjas's Avatar
Because of having to replacing the piston, that's basically what I was fearing. I'll have to see if I can find any additional info than the (not so clear) manual.
Thank you for your suggestions.
Old February 4th, 2018, 04:50 PM   #6
That is odd.
Re-check the cam timing to make sure the valves are opening at the proper time.
Make sure you have the correct hose from the carb connected to the petcock - https://faq.ninja250.org/wiki/File:Annotated_1.jpg
When you said - " my carbs are not pulling fuel through the vacuum supply line ... " - what do you mean? There shouldn't be fuel in that line - just vacuum to open the petcock.
Old February 4th, 2018, 05:28 PM   #7
Ninjas
Motorcyclist
Ninjas's Avatar
we've checked The timing, etc. Should be spot on. Yet the carbs vacuum for the fuel supply is still blowing air instead of sucking. Something isn't right..
Old February 5th, 2018, 06:04 AM   #8
Z1R rider
Z1R rider's Avatar
MOTY - 2018, MOTM - Oct '16
intake valves bent, pieces of piston stuck under intake valve? Is it running now or are you just cranking it?
Old February 5th, 2018, 06:06 AM   #9
Ninjas
Motorcyclist
Ninjas's Avatar
We got it. Timing was off 180°. Thank you guys for your input. Much appreciated!
Stay safe!
Old July 4th, 2018, 08:48 PM   #10
Ninjas
Motorcyclist
Ninjas's Avatar
Originally Posted by jkv45 View Post
That is odd.
I didn't mean fuel through the vac line, I should have worded that differently. But it was the timing, 180° off. Fixed and is doing excellent. IG ninja_biker1_phx_az I have a few videos and photos there of after the repairs.
Old July 4th, 2018, 09:22 PM   #11
How did you determine it was 180-degrees off?
Old July 5th, 2018, 12:07 AM   #12
Ninjas
Motorcyclist
Ninjas's Avatar
There was positive vacuum instead of negative vacuum. IF memory serves, positive vacuum pushes, while negative pulls(sucks) which indicated there was something very wrong with the timing. After checking the timing after noticing this the markings on the cams werent lining up correctly. I figure when i put tension on the timing chain i may have rotated the cams by mistake.
Old July 5th, 2018, 12:25 AM   #13
maverick9611
"a legend in my own mind"
maverick9611's Avatar
MOTM - Feb '18
when you rotate cams to get your phasing make sure you keep your thumb pressed up against cam chain guide via cam chain tensioner housing. this will keep your chain chain from jumping teeth while setting your time
"trying not to get old"
Old July 5th, 2018, 12:29 AM   #14
Ninjas
Motorcyclist
Ninjas's Avatar
Thumbs up
Thank you for that advice, maverick. I'll keep note of that for the next go around. The timing was corrected 6 months ago and she's ran fine since
Old July 5th, 2018, 06:28 AM   #15
Ah, so the marks were off by 180? I was wondering if it's possible to be off but have the marks look ok.
Vacuum-Less Petcock ninjunk 1986 - 2007 Ninja 250R Tech Talk 14 August 24th, 2023 11:30 AM
2005 kawi ninja 250r Running issues. Ninjas 1986 - 2007 Ninja 250R Tech Talk 61 September 23rd, 2017 09:55 PM
2005 250 NInja Petcock-Fuel Filter thjo0712 1986 - 2007 Ninja 250R Tech Talk 9 May 3rd, 2016 02:08 AM
Removing the vacuum spring from the petcock. berserk81 General Motorcycling Discussion 5 November 5th, 2013 08:07 PM
Vacuum nipple came off petcock - fix or replace petcock? fierostetz 1986 - 2007 Ninja 250R Tech Talk 3 November 24th, 2012 11:03 AM
