Old May 24th, 2018, 03:32 PM   #1
MrMushroom86
MrMushroom86's Avatar
Motorcycle(s): 1994 Kawasaki Ninja 250R, 2009 Kawasaki Ninja 250R Limited Edition
Carbs blowing mixture out front
So about 2 months ago I bought a Ninja EX250F8 for a couple hundred bucks because it needed a new timing chain. Fast forward about 2 months, timing chain is installed, bike is timed, lots of new parts and labor (that I did myself cause it was cheaper) and its now running. Only problem is when its running, it keeps blowing a mist of fuel/air mix out of the carbs where the air filter attaches (no air filter box when I bought it, just a bolt on K&N filter). Anyone have any idea why it would be doing that (filter is off right now)? If I can get a picture (or short video of it doing it I will post that so you can see what I mean)
MrMushroom86 is offline   Reply With Quote
Old May 24th, 2018, 03:44 PM   #2
MrMushroom86
Here is a video of what its doing. You can barely see it but you will notice it if you watch the electrical connection.
https://youtu.be/pSUNWl_rcwU
Old May 24th, 2018, 04:33 PM   #3
Hey, good job on doing your own repairs!
Sounds like some possible causes:
1. Cam & valve-timing may be off
2. Ignition coils reversed. That is... trigger wires are crossed.
Old May 24th, 2018, 04:48 PM   #4
MrMushroom86
Initially I had the coil wires backwards, left on the right and visa versa, but Ive corrected that. Timing shouldn't be off unless the chain slipped which it was a pain to get on in the first place since it was new. My neighbor adjusted the idle on it yesterday because it was constantly stalling unless you gave it throttle or kept it choked but he said it sounded like a valve needed to be adjusted or a valve was sticking, and recommended I put some Lucas injector cleaner in it or some seafoam. I put the Lucas in it today and started it to let it run a bit to try to clean up (and lubricate) the valves and fuel system, and thats when it started blowing it back out both carbs. Dont know if the Lucas would have anything to do with it. Really just want it to run reliably so I can ride it. First bike Ive ever owned so its a bit frustrating.
Old May 24th, 2018, 05:05 PM   #5
Needles and carb adjustments won’t blow back mixtures. You put the Lucas in gas tank right?
Blow-back is coming from inside engine. Interaction between valve-timing and piston motion. Unless you poured the Lucas into your cylinders. In which case, you may have hydrolocked and cracked pistons.
1. Take pictures of your crank-position mark at TDC.
2. Take pictures of your cam-timing marks
3. Measure all your valve clearances
4. Do compression check
5. Measure your ignition-timing at idle.
Post results here. You’d be surprised at how many things are off when you have concrete numbers and data.
Old May 25th, 2018, 06:02 AM   #6
As Danno suggested - double check your cam timing.
That's fairly common on some bikes, but not the Ninja.
Old June 24th, 2018, 01:31 PM   #7
MrMushroom86
Valves were sticking so I replaced them and re timed everything. I know the crank timing is hard to see but thats 2T at the white line. Havent had a chance to fire it back up yet, right as I finished it started to storm pretty bad and I dont have a garage, just a carport so I had to just pickup the tools and cover the bike until it stops.
Headlight fuse keeps blowing iangee 2008 - 2012 Ninja 250R Tech Talk 5 May 26th, 2012 01:00 AM
No More Blowing Your Nose! HKr1 Off-Topic 29 December 17th, 2011 04:55 PM
Headlight bulb keeps blowing caps 2008 - 2012 Ninja 250R Tech Talk 11 August 31st, 2011 06:17 AM
Keep blowing headlight fuse! Hexdex 2008 - 2012 Ninja 250R Tech Talk 8 October 26th, 2010 07:01 PM
how tighten mirrors? keep blowing back dimeified 2008 - 2012 Ninja 250R Tech Talk 8 March 20th, 2010 11:41 AM
