Old June 1st, 2018, 08:49 AM   #1
nikeeric86
nikeeric86's Avatar
Motorcycle(s): 1992 fzr600 2010 ninja 250 2006 cbr600rr
Tire tread and Tech inspection
Heading to Thunder Hill next week for the first time and trying to get one more track day out of this Alpha 13 front for my Ninja 250. I'm nearly down to the wear bars on the edges, think i'll get by tech inspection?
Also, the rear still has plenty of tread left, is it normal for the front to wear faster than the rear? For a track bike, do any of you just change one tire at a time or both?
nikeeric86 is offline   Reply With Quote
Old June 1st, 2018, 11:21 AM   #2
Should be fine.
Which day are you at TH? I've got spare wheel with good Alpha-13SP if you want to swing by and pick it up just in case. I'm north-east of S.F. off hwy-80.
I usually use newer tyres for races and move older ones to track-day practice. Get about 35-40 days @ track out of a set and they wear pretty evenly for me. If you use more throttle and keep front-wheel off ground more, you'll even out the wear...
Old June 1st, 2018, 11:36 AM   #3
The general rule is 80% of the tire tread but.....
Guys that work tech (normally the coaches) will make a spot judgment call. If they know you and your a track vet, it will pass. If you got tape on your lights, maybe not and you should have a plan to do a tire swap at some point.
Good luck, have fun!
Old June 1st, 2018, 12:41 PM   #4
nikeeric86
nikeeric86's Avatar
Should be fine.
I'll be there Tuesday. I have new sc1 i'm taking with me just in case but thanks though.
35-40 track days!? i have 5 on this one?
Front tire tread direction Spaghettiknight 1986 - 2007 Ninja 250R Tech Talk 10 March 29th, 2018 12:04 PM
[motorcyclistonline] - What Is Antenna Tread? | Motorcycle Tire FAQs Ninjette Newsbot Motorcycling News 0 December 30th, 2014 09:50 AM
[motorcyclistonline] - Continental Tire Recall Announced For Possible Tread Separatio Ninjette Newsbot Motorcycling News 0 September 17th, 2014 09:30 AM
tire tread direction alex.s General Motorcycling Discussion 26 April 29th, 2014 04:57 AM
Tire tread Toph 1986 - 2007 Ninja 250R Tech Talk 7 September 7th, 2009 02:30 PM
