Old June 14th, 2018, 03:54 PM   #1
jrshooter
Motorcycle(s): ninja 300
315 spears racing
anybody running the spears racing 315 kit or his +4 kit ?
thinking of doing this, close your ears jackryan, i need a cheater bike to keep up with you.
Old June 15th, 2018, 05:34 PM   #2
Are you doing all work yourself? Do realize you won't be able to race in 250 classes any more? Well, I guess if no one protests. One guy snuck in a 600 into 250 class last year at Sears Point. That wasn't too obvious! Some related threads:
https://www.ninjette.org/forums/showthread.php?t=187321
https://www.ninjette.org/forums/showthread.php?t=257420
https://www.ninjette.org/forums/showthread.php?t=263401
Personally I would sleeve it and use ZX6 pistons... Not sure what to do about shorter pin-height on 300 piston. Maybe make it up with thicker base-gasket.
Old June 15th, 2018, 07:36 PM   #3
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
I wanna cheater bike, but have they got one to run good yet?
Old June 15th, 2018, 08:18 PM   #4
jrshooter
spears has the 335 kit, might try it next season. thanks for the threads.
Old June 15th, 2018, 09:54 PM   #5
Check out all of Bruce’s builds, they’re monsters! Don’t see why you can’t do same thing with 300 engine.
Old June 15th, 2018, 09:55 PM   #6
I guess Spears kit is a plug & play solution. Simpler and easier. With PC-V for tuning, you’re looking at least another +10-15 bhp. Watch out 400s!
Last futzed with by DannoXYZ; June 17th, 2018 at 09:08 AM.
Old June 15th, 2018, 10:40 PM   #7
jrshooter
I guess Spears kit is a plug & play solution. Simpler and easier. With PC-V for tuning, you’re looking at least another +10-15 bob. What out 400s!
as much as i would like a 400, might as well jump to a 600. all the goodies on my 300 wont go on the 400, so build the 300 up.
dan with the kit, compression goes up to 13 to 1, what octane gas am i looking at ?
Old June 16th, 2018, 06:19 AM   #8
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
They require a lot of maintenance, and most riders I know that raced with them, did not maintain their own bikes. I said most, not all.
TEAM ALFALFA
www.apexassassins.com
Old June 17th, 2018, 04:23 AM   #9
JohnnyBravo
I wouldn't mind some extra streetable power.
I was looking at the crazy most power ever builds where they kept breaking parts an blowing engines
(Edit)
Last futzed with by JohnnyBravo; June 17th, 2018 at 04:35 AM. Reason: P.S.
Old June 17th, 2018, 09:53 AM   #10
Probably will be fine in the 94-95 range depending upon cam settings. A stroker motor doesn't have as gentle or as much piston dwell time at TDC, so it's more knock-sensitive than 250 engine using those same pistons. A 50/50 blend of pump-gas and 100-oct race gas should work. That's what i was using on my high-boost auto engines before moving to E85.
Did you make it to round-3 at Thunderhill? Thought I saw your son's bike at TH-West couple weeks ago before Laguna. Are you doing TH 5-mile with Z2 next weekend? With Keigwins in 2-weeks?
I say use money for upgrades on track-days instead. Personally I get more enjoyment out of it that way.
Last futzed with by DannoXYZ; June 17th, 2018 at 07:51 PM.
Old June 18th, 2018, 08:26 AM   #11
jrshooter
racing is out of the question this year, will be making a return in 2019,
going to run a few cvma events with my son also, would be cool if you could join us, will be at thill aug 25 bolth days with ptt, hope to see you there.
Old June 18th, 2018, 04:49 PM   #12
bruce71198
bruce71198's Avatar
How does 354cc sound....
Old June 18th, 2018, 05:45 PM   #13
OOoohhh Aaaahhh... 68mm....
'03-06 ZX6R?
Old June 18th, 2018, 06:46 PM   #14
Dave Wolfe
CCS Amateur #501
Dave Wolfe's Avatar
Motorcycle(s): '09 250 SE 'Booger'
Tryin to keep up with Jody??
Dave Wolfe is offline   Reply With Quote
Old June 21st, 2018, 02:46 PM   #15
Count me in for aug25-26 w/PTT.
CVMA definitely possibility this winter. I got really rusty taking winter off. It's about 1/2way between us and in-laws in Phoenix. So would be a good stopping point in between.
Old June 21st, 2018, 04:12 PM   #16
bruce71198
bruce71198's Avatar
He typically woops up on me with a stock shitpile 300 we have laying around!
Old June 21st, 2018, 04:13 PM   #17
bruce71198
bruce71198's Avatar
'03-06 ZX6R?
1mm over ZX6 pistons
[roadracingworld.com] - MotoAmerica: Spears Enterprises/Spears Racing To Field Nate M Ninjette Newsbot Motorcycling News 0 March 7th, 2018 11:01 AM
[roadracingworld.com] - Brian Bartlow To Ride Spears Racing Entries In 2013 AFM And W Ninjette Newsbot Motorcycling News 0 January 4th, 2013 04:10 PM
shoei rf1100's for $315 shipped gt_turbo Gear-related 4 February 24th, 2012 09:41 AM
[roadracingworld.com] - Moto2 Race Margin Of Victory Is 0.315 Second At Motegi Ninjette Newsbot Motorcycling News 0 October 3rd, 2010 02:50 AM
[roadracingworld.com] - Spears Racing To Debut New Sponsorship Deal With Dickies Thi Ninjette Newsbot Motorcycling News 0 April 22nd, 2010 07:00 PM
