Old June 26th, 2018, 02:15 PM   #1
stefstefs
Motorcycle(s): 06 Ninja 250
Issue with left turn signal wiring on my 06 ninja 250
Hi guys, I just purchased a ninja 250 yesterday and I couldn't be more happy with the bike.
I'm having an issue with my left turn signal wiring. The wiring on both front turn signals match up but the connector piece from the wiring harnesses doesn't match up. The left side has two connectors that have two pieces inside. The right side has two singular connectors that directly connect that work fine.
I can try to connect it but it will just stay solid on, even in the off position of ignition. Or if I connect it a different way it doesn't even work. If I try to use the left signal, the back works but it blinks very fast.
The first picture attached shows the right side and the second picture shows the left side. The pictures were taken from inside the fairing. I attached a picture of my new bike for fun too.
I'm hoping someone here can help me out because I'm stuck now.
stefstefs is offline   Reply With Quote
Old June 26th, 2018, 02:37 PM   #2
taz
taz's Avatar
MOTM - May '17
on your left side issue that is not the left turn signal wires the ones you want to connect to should be farther back and look just like the right ones.
Old June 26th, 2018, 02:41 PM   #3
taz
taz's Avatar
MOTM - May '17
nice looking bike and look by the radiator like the other side for them
Old June 26th, 2018, 03:21 PM   #4
CaliGrrl
CaliGrrl's Avatar
Motorcycle(s): Ninja650
Welcome!
Old June 26th, 2018, 05:36 PM   #5
Hi and welcome!!! Easy way to find connector is to trace wiring from where it leaves back of light. Some some tests to troubleshoot:
1. Check that bulb is good. Remove bulb from light and connect to battery with jumper cables. If bulb lights, it’s good and problem is wiring. Put bulb back.
2. Once you find correct wiring-connector unplug light from it. With key ON, and blinkers on,measure for voltage on both connector terminals on harness. One should be at battery voltage.
Last futzed with by DannoXYZ; June 26th, 2018 at 08:15 PM.
Old June 26th, 2018, 07:08 PM   #6
stefstefs
Thank you so much! This was my issue and it is now fixed.
Old June 27th, 2018, 06:02 AM   #7
taz
taz's Avatar
MOTM - May '17
awesome
Old June 27th, 2018, 09:14 AM   #8
What was the problem? Something unplugged?
Old June 27th, 2018, 09:29 AM   #9
stefstefs
The issue was that I thought those two connectors were the connectors for the turn signal while they were not. The actual wires were right by the radiator like taz said.
Old June 27th, 2018, 10:47 AM   #10
What did you do to fix it?
Old June 27th, 2018, 11:18 AM   #11
taz
taz's Avatar
MOTM - May '17
he had the turn signal connected to wrong set of wires, he hooked the up to the right ones.
Left Turn Signal Issue Giggling_Donkey 2008 - 2012 Ninja 250R Tech Talk 16 August 12th, 2016 07:39 AM
WTB: Ninja 250 turn signal wiring CGNY87 Items Wanted 10 January 22nd, 2010 01:32 AM
