Old June 27th, 2018, 06:46 PM   #1
juanphatsun
juanphatsun's Avatar
Motorcycle(s): Ninja 250 2007
Fork maintenance question
I was recently servicing my forks and noticed a difference between the two tubes. With the springs out:
- one tube will collapse by itself without external forces (excluding gravity)
- the other won't collapse unless assisted, very little force is required to collapse by hand
Both tubes move easily up and down other than the fact that one will collapse on its own.
Anyone had a similar experience and know if it's something i should look into?
juanphatsun is offline   Reply With Quote
Old June 27th, 2018, 07:55 PM   #2
Seals not sealing on fork that's dropping?
Old June 27th, 2018, 08:23 PM   #3
Or the assembly that drops on its own just has a little more wear on its seal and dust shield. If you change the seals, the difference should go away, since the new seals will have a lot more friction. In any case, that in itself is not a problem but as Danno was suggesting, leaking oil would be.
Old June 27th, 2018, 08:26 PM   #4
juanphatsun
No leaking of oil seen, but i'll keep a close eye on it and make plans to replace fork seals in near future as a precaution.
Old June 27th, 2018, 09:07 PM   #5
dcj13
Participant
dcj13's Avatar
Motorcycle(s): '94 K75 std
I wouldn't worry about it.
I also wouldn't change fork seals if they're not leaking.
Old June 27th, 2018, 09:14 PM   #6
Agreed, I didn't mean to suggest the seals need changing.
Fork oil question MattP3 2008 - 2012 Ninja 250R Tech Talk 7 April 10th, 2015 10:20 PM
Question about Fork Oil thisisbenji General Motorcycling Discussion 16 February 23rd, 2015 08:40 AM
fork oil question mikedabike64 2008 - 2012 Ninja 250R Tech Talk 16 August 19th, 2014 06:40 PM
Chain Maintenance Question dcj13 General Motorcycling Discussion 10 January 27th, 2014 04:08 PM
600 Mile Maintenance Question 2fiddy 2008 - 2012 Ninja 250R Tech Talk 6 May 9th, 2011 01:18 PM
