Old July 2nd, 2018, 04:33 PM   #1
Frank06
Motorcycle(s): many!
Clip-Ons and brake lines with ABS
Hi Everyone,
I've started doing track days whenever I can using a 2015 which was built to Canadian Lightweight specs. It has good suspension parts, stock engine internals with PCV and slip-on. The PO tucked the front end at Mosport (turn 5) and the stock handlebars are tweaked. It's been okay up to now but I'm thinking that clip-ons would be a nice addition and help me in my learning process. The bike has Hot Bodies race bodywork.
I think others have had an issue with brake lines (too short?) but what I'm wondering is whether or not anyone has identified exact replacement parts? My difficulty is that the bike is not close to my primary residence so any work of this nature requires that I have exact parts on hand before I leave to work on the bike, so I'm looking for help in this area. Any thoughts or ideas would be much appreciated!
Frank06 is offline   Reply With Quote
Old July 2nd, 2018, 05:10 PM   #2
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
clip-ons lower the bars, so if anything the brake lines will be long.
TEAM ALFALFA
www.apexassassins.com
Old July 2nd, 2018, 05:55 PM   #3
jrshooter
Motorcycle(s): ninja 300
you probably going to run the banjo bolt into the dash.
move the dash and dremmel the hot bodies and the clip ons will go anywhere. if not your going to run them high. and not have much adjustment. for a 300 anyways.
Old July 2nd, 2018, 06:19 PM   #4
Frank06
I was wondering about clearance to the fairing. I might replace the handlebar with a stocker...
Here's where I read about the brake lines: https://www.kawasa***************/fo...ons-w-abs.html
Old July 2nd, 2018, 07:57 PM   #5
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
if you get vortex and put them up against the triple, they lower a little, but not enough to have to cut anything.
TEAM ALFALFA
Old July 3rd, 2018, 04:35 AM   #6
Frank06
Do you mean Vortex works with the HB fairing?
Old July 3rd, 2018, 06:55 AM   #7
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
yes
TEAM ALFALFA
Old July 3rd, 2018, 08:20 AM   #8
Frank06
Thanks, I'll look into these some more. There's about 2" difference in height between what's on there now. You can't really tell when riding but I noticed the difference when towing the other day. I thought the front wheel was cocked over but it was in a chock!
Front Brake Cable issue w/ Driven Clip-ons Sirena 2013 - 2017 Ninja 300 Tech Talk 9 April 2nd, 2015 11:08 AM
Questions for those with SS brake lines on their ABS Ninja 300 tfkrocks 2013 - 2017 Ninja 300 Tech Talk 3 November 5th, 2013 04:34 PM
Woodcraft clip-ons V.S. Kitaco clip-ons tjb0012 2008 - 2012 Ninja 250R Tech Talk 41 June 20th, 2011 05:35 PM
