Old July 2nd, 2018, 07:19 PM   #1
wordstunner
Motorcycle(s): 2004 Ninja 250
Question Engine work at 10,000 miles
I have a 2004 Ninja 250 that has been sitting for over two years. I am about to CafeŽit with a Blue Collar Bobber kit. I have it apart and currently changing the oil, replacing the air filter with a K&N, replacing all fuel lines, bleeding the brakes, replacing clutch fluid, cleaning the carbs, replacing the chain, replacing front sprocket with a 16T and cleaning the crap out of the bike. It has a little over 10,000 mile on it. Any suggestions on what I should do with the engine, if anything? Is there maintenance that needs or should be done? Thanks in advance!
wordstunner is offline   Reply With Quote
Old July 3rd, 2018, 05:22 AM   #2
cbreater
cbreater's Avatar
Motorcycle(s): 16' S1000RR, 04' CB919, CRF150/230, 07' 250R
If you're going to the trouble of the front sprocket and chain, i'd add $20 and buy a rear sprocket too. Flush the radiator fluid. Check brake pads over and replace as needed. Valve clearance check is probably the only in motor thing to check, at least for now. New plugs probably wouldn't hurt if you're going that far. You can skip the clutch fluid as it's cable operated. That should get you pretty well squared up with what you plan below.
cbreater is offline   Reply With Quote
Old July 3rd, 2018, 06:59 AM   #3
Sounds like you've got a pretty good handle on the situation, but look thorough this section for more ideas and tips - https://faq.ninja250.org/wiki/Ninja250_Howto
My first 10,000 miles Sulman General Motorcycling Discussion 6 September 23rd, 2016 09:42 AM
50,000 miles.... bdavison General Motorcycling Discussion 7 October 2nd, 2015 04:30 AM
45,000 miles and it finally got me backinthesaddleagain !%@*#$%!)@#&!%@ I crashed! 34 November 18th, 2014 07:07 AM
Is 33,000 too many miles? XurXes General Motorcycling Discussion 10 August 25th, 2012 06:58 PM
After 11,000 miles... RyderRider15 Ride Reports 9 April 10th, 2012 06:06 PM
