Old July 6th, 2018, 08:59 PM   #1
sh123469
Motorcycle(s): EX250, Suzuki Savage, 76 Goldwing restoration project, 71 CB350, 73 Yamaha GT1,
right cyl cutting out above 4000
Just started today. 05 Ninja 250 with 17k miles. Been running great and all of a sudden, it cuts out on the right side above about 4000 rpm. It will rev way past that in neutral and go past that very quickly and then sputter when taking off. You can't keep the throttle where the engine will run above 4k once you get moving or it runs on 1 cyl.
Anybody have any ideas where to look?
I'm thinking and for some reason not enough fuel is getting into the right carb. That cyl kind of sputters and dies just like it ran out of gas. You will hear it sputter a little sometimes on the road. As soon as you let off the gas and get back below about 4k or stop at a light, it is running on both cylinders again. I tried going up a hill at about 3k and opening the throttle, it sputtered and the cyl died at just above 3k with a well opened throttle. Again sounds like a fuel issue.
I have checked the little fuel filter inside the carb inlet and it is not clogged either. My guess is something either got shook loose or made it through and is clogging the fuel flow past the float valve.
Somebody give me some inspiration. I guess I'll be pulling carbs tomorrow.
Steve
sh123469 is offline   Reply With Quote
Old July 6th, 2018, 09:10 PM   #2
Hmm, might be vacuum leak and slide's not moving enough.
Might be sticky slide.
Clogged fuel-circuits inside carb.
Old July 6th, 2018, 09:14 PM   #3
sh123469
Yeah...looks like i'm pulling carbs tomorrow instead of going riding.
I don't mind helping someone else with their bike but I HATE wrenching on mine.
Old July 6th, 2018, 09:15 PM   #4
Just for the heck of it, take a look at the spark plugs.
New Kawasaki 4-cyl 250 in the works?! CZroe General Motorcycling Discussion 53 September 14th, 2022 05:20 AM
300 front rotor, caliper, master cyl with lover. old3 Motorcycle-related 4 June 8th, 2015 07:43 PM
area p - cyl running lean at idle cory jordan 2008 - 2012 Ninja 250R Tech Talk 12 November 12th, 2012 02:54 PM
4000 miles servicing. seldom 2008 - 2012 Ninja 250R Tech Talk 5 August 22nd, 2011 09:33 PM
4000 Mile Maintenance.. have you done it? paterick4o8 2008 - 2012 Ninja 250R Tech Talk 29 July 3rd, 2009 06:37 PM
