Old July 8th, 2018, 08:29 AM   #1
04Ninja25
04Ninja25's Avatar
Motorcycle(s): 2004 Ninja 250
Carburetor don't close by itself
Hi
Took my carburetor out to clean, which I have don't it a few times before.
After cleaning it and leaving it in a bag overnight the carb doesn't close by itself.
Before when I turn the butterflies and let go it would snap back and close. Now if I open the butterflies it stays where it is.
How do I fix this?
04Ninja25 is offline   Reply With Quote
Old July 8th, 2018, 12:17 PM   #2
Do yiu have both cables hooked up?
Before attaching to cables to carbs, did cables move freely?
How much play do you have in cables?
Old July 8th, 2018, 12:28 PM   #3
04Ninja25
04Ninja25's Avatar
as of right now the cable are not hook up. I just took it out to clean and have not put the carb back on to the ninja 250.
I didn't remove any of the outer springs.
Old July 8th, 2018, 12:36 PM   #4
04Ninja25
04Ninja25's Avatar
It's just stays open
Old July 8th, 2018, 02:17 PM   #5
Shaft needs cleaning and oiling.
Old July 8th, 2018, 03:38 PM   #6
04Ninja25
04Ninja25's Avatar
Has there already been a write up on how to clean the shaft?
Old July 8th, 2018, 04:36 PM   #7
See where shaft enters and exits carb bores? Spray those 4 areas with PB-blaster
Old July 8th, 2018, 04:42 PM   #8
04Ninja25
04Ninja25's Avatar
Ill try that. Thanks
Old July 8th, 2018, 04:53 PM   #9
Also squirt some where it leaves on outside at centre of big wound spring.
What's that green stuff on butterfly plate?
Old July 8th, 2018, 06:25 PM   #10
04Ninja25
04Ninja25's Avatar
I'll spray it on and leave it overnight and see if it will work.
Not sure what that green stuff is. It's been there since the first time I cleaned it a few years back. Didn't bother the ninja 250.
carburetor skip 2008 - 2012 Ninja 250R Tech Talk 9 June 5th, 2017 12:39 PM
[motorcycledaily.com] - Team Hero EBR close in on Tissot-Superpole progression at Don Ninjette Newsbot Motorcycling News 0 May 24th, 2014 03:10 PM
[kropotkin thinks...] - 2013 Mugello Moto2 Race Result: A Close Race Leads To A Close Ninjette Newsbot Motorcycling News 0 June 2nd, 2013 04:20 AM
SaddleBags. How close is TOO close to the exhaust? Seattle_Chris Cargo Space 9 February 20th, 2010 06:55 PM
[crash.net - MotoGP] - Hayden: Close don't count! Ninjette Newsbot Motorcycling News 0 October 25th, 2008 10:33 AM
