Old January 19th, 2010, 11:40 AM   #1
kevlarorc
noob motovlogger
kevlarorc's Avatar
Motorcycle(s): Black 2009 250r
Replacement Fairings and Painting
Ok, so I laid my bike down yesterday and I want to get it back up and purty as soon as possible so I need some expert help from the best 250 forum ever!
As far as insurance goes, should I file with them? My deductable is $500. I think it would just end up giving me a bunch of hassle and I wouldn't end up saving any money in the long run.
I need a new right turn signal. Really the only parts I need are the "stalk" that leads to the black plastic housing as well as the clear front cover. However, it appears that I can't buy just the "stalk" part so it would be more cost-effective to buy some cheap LED signals off of ebay. My real question for the turn signals is the problem of mounting them. The stock signals mount with that oval rubber grommet with two holes but the turn signals on ebay just show a screw on the end of the signal. How would I go about mounting these? (example: ebay link)
Second, I need help deciding whether to repaint the right fairing or just replace it (replacement is $235). Should I try repainting it myself or just bring it to a shop? My DIY projects don't usually end up how I want them but I might do it myself if the cost difference is massive. I've checked it all over and it has no cracks, just lots of scratches. Also, I'm pretty sure it's just the flat black not the metallic flake paint they added on one of the black 09 versions.
Lastly, I need to replace the right rear fairing tail piece due to cracks. I believe it's part #36040O. The description on kawasakipartshouse.net is
Code:
36040O  SKU: 36040-0062-15Q COVER-TAIL,RH,M.D.BLACK
Can anyone confirm this so I don't order the wrong thing? Here's the parts diagram. The only thing confusing me is that the M.D. in the description I think stands for Metallic Diablo, though I didn't think I had that paint.
Here are some pics of the damage if that affects your advice at all.
Rear Fairing cracks
My Motovlog
"Damn, either shimming the needles fixes 90% of any problems with the 250Rs, or kkim owns stock in a washer manufacturer." -DmbShn41
kevlarorc is offline   Reply With Quote
Old January 19th, 2010, 11:58 AM   #2
austexjg
austexjg's Avatar
Motorcycle(s): '09 zx6r Green/Black, (ex-)Diablo Black '09 Ninja 250r
That is about what mine looked like - the fairings are being repaired - I have the metallic paint, so DIY was out. Shop is waiting for the weather to clear for final paint - the first coat is done, but more sanding before the final paint.
I am hoping it turns out okay, because I have the extended warranty and don't want any hassles about a minor slide. I was also debating on going the new route, but figured I would have these repaired and if they look bad, use them until "it" happens again.
austexjg is offline   Reply With Quote
Old January 19th, 2010, 12:02 PM   #3
kevlarorc
noob motovlogger
kevlarorc's Avatar
So does your paint look a lot different from what I have in the pictures? I honestly can't tell if I have the metallic paint or not even though it's a 2009.
My Motovlog
Old January 19th, 2010, 12:06 PM   #4
austexjg
austexjg's Avatar
You can definately tell in person when the sun is out - from a yard away it appears plain black.
Old January 19th, 2010, 01:14 PM   #5
divingtigger
Pedal Power
divingtigger's Avatar
Motorcycle(s): 2008 Ninja EX250R
There is one ebayer that I've used for all my parts...it was tampa something or other. Dom is a great guy to do business with. As for those signal parts... I can sell you those if you want. I went to some flush mounts
Using Pedal Power
divingtigger is offline   Reply With Quote
Old January 19th, 2010, 02:50 PM   #6
Betlog
Betlog's Avatar
Motorcycle(s): 2009 250r
Your thread got me curious as to the cost of fairings for my '09 SE. From the site you linked to above, it's insane how each of the side fairings are over 490, whereas the regular colors are just over 230. LOL! I can just buy two green '08 cowlings for the price of one '09 SE side cowling.
Betlog is offline   Reply With Quote
Old January 19th, 2010, 04:03 PM   #7
jonthechron
Motorcycle(s): magHitVE
woah 490 pretty cheap! My dealer checked and he told me it was 750 per fairing + tax! (850 lol) That's 820 USD, per fairing.
Old January 19th, 2010, 04:30 PM   #8
Betlog
Betlog's Avatar
LOL, that's like a third the cost of the bike for 1 fairing. I'm not sure how reliable kawasakipartshouse.net is though. Anyone have any experience with them?
Old January 19th, 2010, 09:35 PM   #9
kevlarorc
noob motovlogger
kevlarorc's Avatar
That would be awesome if you're willing to sell them. Like I said above all I really need is the right "stalk" part that sticks out of the bike and the clear lens for the housing.
My Motovlog
Old January 20th, 2010, 08:33 AM   #10
divingtigger
Pedal Power
Send me an offer via PM and we can work it out. I have one inside the house that I can take the parts off of
Using Pedal Power
Old January 20th, 2010, 09:00 AM   #11
PitBull
PitBull's Avatar
Motorcycle(s): 09 Ninja 250
I had a fairing repainted at a shop and in all honesty, it looked better than the factory paint job!
PitBull is offline   Reply With Quote
Old January 20th, 2010, 11:06 PM   #12
Small Ninja
Small Ninja's Avatar
Motorcycle(s): 2008 Ninja 250 Candy Plasma Blue
What Color Is Your BIKE?
Small Ninja is offline   Reply With Quote
Old January 21st, 2010, 09:09 AM   #13
tiburonsita
tiburonsita's Avatar
Motorcycle(s): 2009 black Ninja 250R
yes, I got mind from them prepainted for $235 I believe. Matches the rest of the bike exactly since they are kawi parts. (mine is metallic black also)
Last futzed with by tiburonsita; January 21st, 2010 at 09:15 AM. Reason: forgot to specify color
tiburonsita is offline   Reply With Quote
Old January 21st, 2010, 09:29 AM   #14
divingtigger
Pedal Power
There is a shop here that will make any colour paint that you want. They will match a piece if you bring it in...they are really good and fairly cheap too. I'm sure there is one close to you as well. They will put it in a spray can too.
Found the stem and the clear piece and new condition.
Using Pedal Power
Old January 21st, 2010, 10:43 AM   #15
eddiekay
eddiekay's Avatar
Motorcycle(s): 300, WeeStrom
Hey Kev....in all seriousness...well placed scratches...depending on how you look at riding...are a definite "badge of courage". I mean, these bikes are sooo pretty but, depending on who you hang with, how you ride, how you feel about appearances you could just leave them there. I mean, really, anytime you pull up to a group I can almost guarantee you'll be asked to tell the story. It's up to you but the price of plastics is always very high and if the damage in no way affects the performance or safety...you could spend the money on stuff that does...like the signal...and sliders.
Old January 21st, 2010, 06:57 PM   #16
MKlein3004
Fighting Texas Aggie '08
MKlein3004's Avatar
Motorcycle(s): 2008 Ninja 250r (Race), 2005 Kawasaki Ninja ZX-6R 636 (Track), 2005 Ducati Monster 620 (Street)
i will agree with eddiekay. if i come ride with you sometime you will see my bikes battle scars. cracked fairing where yours is scrapped and slide maks on the other side. only parts i replaced where the tank, got a dent somehow that i can't figure out hoew, the front fairing, had a gigantic whole in it, and now the rear left courtesy of triggen becuase it was too good of a deal to pass up. I honestly believe that replacing the fairings right now on my bike is a waste of money and time. I am not a seasoned rider by any means so i feel that it might happen again. I have confidence in myself but i am still a new rider so things can happen. its all up to you and your pride and how you feel about riding around on a scraped bike. You could easily take a rattle can to it and clean it up a bit to hide the marks and save your money for sliders or other pieces for the bike that can protect it when you get new fairings.
MKlein3004 is offline   Reply With Quote
Old January 21st, 2010, 09:56 PM   #17
kevlarorc
noob motovlogger
kevlarorc's Avatar
you know what? I think y'all are right. I'll just replace the necessary things and leave the scratched up fairing there. I also had the idea that if I ever lay it down on the other side then I'll just take both and paint them white and have a sort of Panda bike.
Cycle gear just sent me their catalog and it looks like I'm in the market for some snazzy new leather pants.
maybe it'll make the bike less attractive to steal too lol
My Motovlog
Old January 21st, 2010, 11:44 PM   #18
Betlog
Betlog's Avatar
Cool. Thanks for the feedback. I'll order some parts from them.
Painting? Nathanptak 1986 - 2007 Ninja 250R Tech Talk 2 May 26th, 2013 07:56 PM
Painting Helmets??? ninjamunky85 Motorcycle Gear 23 October 1st, 2012 09:05 AM
Painting Fairings onetruevibe 2008 - 2012 Ninja 250R Tech Talk 35 July 15th, 2012 12:54 PM
What grit to use to sand fairings for painting? LoneRonin 2008 - 2012 Ninja 250R Farkles 5 May 7th, 2012 04:10 AM
Painting rims...?! blink General Motorcycling Discussion 6 June 9th, 2011 04:12 PM
