Old March 23rd, 2013, 07:26 AM   #41
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
haha Timmy is afraidey cat. He is feral and lives in the garage with his sister, They keep the mice out of the bird feed.
http://youtu.be/19Ptn1UoNfQ The don't run when I run the bike any more.
still working on a name,(and not much else)
1 Sleipnir Odens eight legged horse.
2 X or X Machine
3 Deuce. its a twin cylinder and my second bike.
4 The Big Shot. Since I am using a large shot of nitrous.
Worlds fastest 250 ninja
Last futzed with by Racer x; March 24th, 2013 at 08:10 AM.
Old June 9th, 2013, 08:19 AM   #42
Racer x
Racer x's Avatar
Made some progress today. Thanks to Scorch and a generous donation of parts I am now rolling on 17 inch wheels.
I have a 2002 front frame piece. The original 36mm fork and I have a set of clip ons from an old Honda. I don't use front breaks so this is all good . I did have to make a spacer set to fit the 2008 wheel into the 2001 fork.
Out back I just bolted on the 2008 swing arm and mounted a 2008 wheel and break assembly.
Now I need to make the read frame section and seat.
I am probubly not goin to start with a turbo And nitrous. My nitrous bike will be a 250 and this turbo will be as big as 350cc. I will mount an intercooler up front and a big fender.
Old June 10th, 2013, 04:20 AM   #43
Racer x
Racer x's Avatar
I got the rear frame mocked up. I fit the tubing and screwed it together. It is strong enough to lift the bike and sit on. Now I have to make the seat and rear body pieces. I also need to stretch the swing arm four inches.
I have to order the rear bodywork piece $205.00 so that is the hold up now.
Once I get the seat on it I will strip the whole thing and weld it. Also I will ship the swing arm out to be stretched.
Old June 10th, 2013, 04:29 AM   #44
TheDementedDrummer
Present. Somewhat.
TheDementedDrummer's Avatar
Motorcycle(s): 2012 KTM Duke 200, 2011 Ninja 250r, 2011 Ducati Monster 796, 2014 Kawasaki ZX10r
That's awesome
How fast are you expecting to go with this one?
Highest speed on two wheels- 230 km/h
Beat that.
TheDementedDrummer is offline   Reply With Quote
Old June 10th, 2013, 06:33 AM   #45
Racer x
Racer x's Avatar
150 mph at Bonneville . That is the pie in the sky dream. And that is with a full fairings. Without fairings I am looking for 135.
It depends on the power I can get from the engine. And how long I can apply the power. To run on the Salt I need to go full power for three miles. Then turn around and go again. That is hard on a little engine.
Old June 15th, 2013, 05:05 PM   #46
Racer x
Racer x's Avatar
Land speed racing front fender is ready to mount.
Old June 16th, 2013, 11:06 AM   #47
Racer x
Racer x's Avatar
I managed to get a lot done on the cooling system. I have the radiator mounted . I can't weld aluminum. And don't want to make the whole bike out of steel.
At this stage I am assembling the frame with screws. Later I will weld the steel bits together. Then bolt the aluminum parts to the steel tabs.
The radiator is a stock first gen. That way I have an extra when the salt eats it .
I am using an electric water pump. The pump flows 1000 L/H. I hope that is enough. It should be.
Old June 17th, 2013, 06:31 PM   #48
Racer x
Racer x's Avatar
The bike is now officially rolling on its own wheels. Now I will do the first welding on the frame. This will be a bunch if welding on the rear section and adding some gussets. Then I take the whole thing apart and get a new grinder pad and go at the frame with a vengeance. I will remove all the odd tabs and nasty welds and anything else .
Then I will start adding my own tabs to hold stuff like pannels and all the intercooler stuff like that.
Old June 17th, 2013, 11:35 PM   #49
aeroblade
Doh!
aeroblade's Avatar
Under seat radiator mount, Nice! Will you be partitioning the engine bay and the radiator section and fabricating separate vents for them both? Also what do you plan to do with the exhaust?
aeroblade is offline   Reply With Quote
Old June 17th, 2013, 11:40 PM   #50
Racer x
Racer x's Avatar
I plan to use a short piece of two inch of pipe coming out of the turbo for the exhaust.
The rear will get sectioned off with a hugger. Also I will fit pannels to the frame to mount the electronics.
Up front the intercooler will go in place of the stock radiator.
Old June 18th, 2013, 12:08 AM   #51
aeroblade
Doh!
aeroblade's Avatar
Ah, I see... cool...
Old June 22nd, 2013, 02:24 PM   #52
Racer x
Racer x's Avatar
I got the first stage of frame welding done. Now I have to put the bike together and make a bunch of tabs to mount things on.
Old June 27th, 2013, 06:07 AM   #53
Somchai
Freedom for Germany
Motorcycle(s): Ninja 250R-FI
Eric u could contact these guys http://www.youtube.com/watch?v=0_fNYio9NB4
Just found a website (takes long to open) with more informations (note that they're going the good way with lowering the cr to 8:1) http://motor.otomotifnet.com/read/20...uh-Power-69-dk
Old June 27th, 2013, 03:33 PM   #54
Racer x
Racer x's Avatar
Wow!! the bar is raised again. 69.1 HP . I am impressed. But what was that puff of smoke at .29 seconds?
I could not read the web page. But there system has more pipes than I need. But it looks great.
Old June 27th, 2013, 09:45 PM   #55
Somchai
Freedom for Germany
I'd open the 2 websites and copied the infos to a doc-file so you can translate it from indonesian to english.
Old June 28th, 2013, 03:47 AM   #56
Racer x
Racer x's Avatar
This is a universal language of speed. They got 53 HP with half bar and 69.1 with 1 bar. They are running 8.5 to1 compression and using a mega squirt fuel system.
They are really good at this stuff. I feel a bit out of my league. But I don't have the limitation of a street engine. And I only need to ride about fifty miles between tear downs. Lets see how this goes.
Old June 30th, 2013, 01:03 PM   #57
Racer x
Racer x's Avatar
I finished my frame and got things mocked up. Now I need to get some money. Unfortunately this is not a likley thing. So the project will go into a heavy planning phase. I need to find source for lots if little parts. I am set on using Etron fuel injection. But I need to make the rest. Or pay to have stuff made.
Old June 30th, 2013, 01:03 PM   #58
Racer x
Racer x's Avatar
This is the mock up.
Old June 30th, 2013, 04:13 PM   #59
cuong-nutz
cuong-nutz's Avatar
Looking good! Do you plan on using the IHI RHB31/32 turbo?
HalfFast Racing Team
Old June 30th, 2013, 04:33 PM   #60
Racer x
Racer x's Avatar
I plan to use the VZ 21. I also looked at the Garrett t15 . But I think it is to big.The VZ 21 is an exact copy of the RHB 31.
Old July 2nd, 2013, 03:37 PM   #61
Racer x
Racer x's Avatar
I am starting with the hot side of the turbo. First I need to mount the turbo at the proper height. I want it as close to the two cylinders as possible. And I want it well above the oil level.
I am going to use these head pipes with O2 bungs for the EFI and merge them together .
This is the turbo.
http://ecotrons.com/products/turbo_part_pic.php
I am using an old damaged head as a jug to make the header.
Old July 2nd, 2013, 05:09 PM   #62
mheitman
Motorcycle(s): '04 919 / '08 250r / '95 xr100
Awesome build.. you know John? from turbo exchange in Wilmington DE?
mheitman is offline   Reply With Quote
Old July 2nd, 2013, 05:38 PM   #63
Racer x
Racer x's Avatar
No
I know Delaware Chassis works in Townsend Delaware.
Old July 2nd, 2013, 06:11 PM   #64
mheitman
He is or used to be big in the scene.. I think he has a few turbo drag bikes in the shop.. figured like anything else, it's a small world and you might know him.
he is pretty good about sticking turbos where they don't belong.. Helped my buddy do this.
Old July 6th, 2013, 03:50 PM   #65
Racer x
Racer x's Avatar
That is awesome. Is that a street car?
I fiddled with makin some radiator shrouds. This will help keep the air going in one direction. They are carves out of a bar of 3/16 aluminum.
Old July 6th, 2013, 03:52 PM   #66
Racer x
Racer x's Avatar
Lower shot
Old July 7th, 2013, 04:13 PM   #67
Racer x
Racer x's Avatar
This is fun. I need the starter dash ignition system and charging system. I don't need lights kick stand safety switch or clutch switch.
I will be eliminating the key also.
Old July 7th, 2013, 05:29 PM   #68
lgk
are you eliminating the starter?
Old July 7th, 2013, 05:36 PM   #69
Racer x
Racer x's Avatar
No ,I need the starter.
Old July 9th, 2013, 04:01 AM   #70
Racer x
Racer x's Avatar
The main ingredients are in. Matt at Ecotron sent me the turbo and fuelinjection system. There is a lot between now and noise. But this is a beginning. Or I will be a beginning when I start. For now I am still collecting parts ad lining up people to make parts for me.
Old July 9th, 2013, 05:00 AM   #71
lgk
A dunno if they flow enough but i got some injectors you can have from a 600
Old July 9th, 2013, 05:26 AM   #72
Racer x
Racer x's Avatar
The injectors I have are 190g
The stock 250 injectors are 128g I should have enough.
Thanks anyway.
Old July 9th, 2013, 06:16 AM   #73
cuong-nutz
cuong-nutz's Avatar
so sexy
Old July 10th, 2013, 09:20 AM   #74
Racer x
Racer x's Avatar
I have the first part of the header made up. I now need to make a hanger for the turbo and fit the header.
Old July 10th, 2013, 05:46 PM   #75
Racer x
Racer x's Avatar
Turbo will go about here. I want it tight and high as possible.
Old July 10th, 2013, 05:56 PM   #76
mgentz
Board Member
looking good.
Old July 10th, 2013, 09:12 PM   #77
cuong-nutz
cuong-nutz's Avatar
How do you plan on plumbing the oil lines for the cooler?
Inline with the line from the crank to the head?
Old July 11th, 2013, 12:54 AM   #78
Racer x
Racer x's Avatar
I am still working on that. Current plan is an electric oil pump pulling warm oil out of the engine. Then pump it through and oil cooler and into the turbo. It will drain back using gravity.
Old July 11th, 2013, 09:57 AM   #79
mheitman
it is. a convertible caviler of all things. he was going for sleeper - and he nailed it. With the exception of the wheels you would never know anything is going on.
Old July 11th, 2013, 04:34 PM   #80
Racer x
Racer x's Avatar
The oil cooler is just for the engine. It mounts in place of the line between the head and block.
I have the lines and fitting all set up from Ecotron. I will have to mount it in front of the intercooler.
The oil for the turbo will be from 8an fittings and 5/16 hose.
Turbo250.com - My Turbo Build Blog garth285 2008 - 2012 Ninja 250R Tech Talk 319 June 19th, 2015 08:04 AM
My 07 250 cafe racer build elephantman78 1986 - 2007 Ninja 250R Farkles 12 December 25th, 2014 07:09 AM
My Cafe Racer Build girlracer 1986 - 2007 Ninja 250R Farkles 17 December 2nd, 2014 08:14 AM
Racer X engine build thread Racer x 2008 - 2012 Ninja 250R Tech Talk 189 June 12th, 2013 07:34 AM
I want to buy or build an 08+ 250R racer. Seanslides Ninjettes At Speed 20 March 1st, 2010 07:34 AM
