May 22nd, 2013, 04:35 PM | #3761 |
I ride like a granny
Join Date: Jun 2012 Motorcycle(s): 2003 Ninja 250R - EX250F Posts: 521
I knows, right? The upper cowl looks awesome with the glossy black flush mounts. The colors highlight each other.
WANTED for 88-07 Ninja 250: Corbin Gunfighter & Lady seat |
May 22nd, 2013, 04:42 PM | #3762 |
Fast-Guy wannabe
MOTM - Jan '13
Rode to work like normal but I also checked suspension sag so I could order front springs and emulators. Checked the sag without my gear so the numbers are a little light but close enough, Front is 46mm and rear is 31mm. The rear is a stock shock with max preload and the front is OEM(never opened).
I tried to remove the fork caps to check the stock preload but I couldn't compress the ****ing cap to remove the ****ing clip Darren and rexbo made it look easy at the track ill try again tomorrow and hopefully ill get my parts in time for next weekends trackdays at Laguna. |
May 22nd, 2013, 05:02 PM | #3763 | |
2) use a gear puller to compress the fork caps. makes the job a ton easier. |
May 22nd, 2013, 05:17 PM | #3764 | |
Fast-Guy wannabe
MOTM - Jan '13
2) I was looking at using one but I had to leave so I didn't have time. Last futzed with by rojoracing53; May 23rd, 2013 at 05:12 PM. |
May 22nd, 2013, 05:49 PM | #3765 |
Thanks Jason. You're always helpful on stuff.
What did I do to my ninjette today? i checked the valves. All 8 are still on the loose end of spec, even after me getting the rockers mixed up when I had the head apart. #score! |
May 22nd, 2013, 07:35 PM | #3766 |
Join Date: Jan 2013 Motorcycle(s): 03' Ninja 250ex Posts: 333
Installed a matching Pirelli Diablo to the front. Went for a short ride to the store..feels good so far. I'll hit the twisties soon now that I have capable sneakers!!
Perform Random Acts of Coolness!!ATGATT |
May 22nd, 2013, 10:51 PM | #3767 |
Join Date: May 2013 Motorcycle(s): 2005 Ninja 250 Posts: 151
charged the battery!
May 25th, 2013, 04:44 PM | #3768 |
crash 250, get supersport
Join Date: Apr 2010 Motorcycle(s): 2010 250R SE (Sold 6/9/14), 2009 ZX-6R (Sold 6/25/14), Subaru BRZ Posts: A lot.
Changed the oil and lubed the clutch cable. Put in Motul 300v and going to send in my T6 with 5k miles on it for a UOA w/ TBN.
May 25th, 2013, 05:03 PM | #3769 |
Certified looney toon
MOTM Jul '13, Jul '14
Got new tires, Pirelli Rosso II, and new a new chain, EK 520 gold. Runs so smooth now!
May 25th, 2013, 05:24 PM | #3770 |
antiant
MOTM - Oct '14
I bent my shifter from a tip over in my driveway about a week ago (Yay, for noobies! - as I say that with sarcasm). Soooo, I ordered the part, which is on backorder (Just lovely! - more sarcasm). Anyways, I made a few calls and found a place in Hawaii that had 2 shifters in their stock and had them Express Mail it to me because I didn't want to wait over the Memorial weekend and damn it, I wanted to ride! I have absolutely no wrenching ability and or knowledge whatsoever if my life depended on it, but I can follow directions if they are thorough and there are good visuals!
Anyways, thanks to another website, I was able to follow directions on how to fix my bent shifter. So, I get the part today and I try to fix it. Start the bike, it's in neutral, put it into first gear and it chokes up on me and dies. I'm thinking wtf?!?! Then I tip over the bike, where I'm supporting it with my weight instead of the kickstand (but the kickstand is still down), try it again, it dies. So, I can't figure out what I'm doing wrong because I'm a noob. So, I go to the local dealership and ask the parts department what might be the problem. Lesson to be learned? Kick up the kickstand ya dumb ass! It's a safety feature that I knew about somewhere in the back of my mind, but somehow I completely forgot about that in my moment of frustration. Lesson learned. I'm just proud I fixed it myself and didn't have to pay anybody. |
May 25th, 2013, 05:39 PM | #3771 |
Join Date: Apr 2013 Motorcycle(s): Triumph Street Triple R Posts: 380
Finally took the bike into the twisties to get the slickness off the tyres. Happy to say I got pretty close to the edges (about an inch on both sides left), but more importantly I found out my bike really likes corners
Should have just upgraded both levers to the asv or pazzo fold-away ones. That way you won't have to worry about things snapping or bending on impact. Fully-adjustable as well so no more ridiculously far out friction zone. |
May 25th, 2013, 05:43 PM | #3772 |
MOTM - Jan '18, Sep '13
May 25th, 2013, 05:44 PM | #3773 | |
antiant
MOTM - Oct '14
Edit: Ninja'd by tfkrocks, lol. |
May 25th, 2013, 06:07 PM | #3774 |
May 25th, 2013, 06:53 PM | #3775 |
Join Date: May 2013 Motorcycle(s): Kawasaki Ninja 250R Posts: 51
I waxed mine just yesterday, got a vertical stand to store it better in my garage considering my garage is tiny! I plan on putting some wheel stripes on and maybe adding some flat black graffix to mine to break up some of the red a little. Already picked out a few areas on the farrings where it would look good with flat black.
May 25th, 2013, 06:54 PM | #3776 | |
MOTM - Sep '14
Edit How did your drop it? post answer here: http://www.ninjette.org/forums/showthread.php?t=25913 with your vote |
May 25th, 2013, 08:19 PM | #3777 |
Went to put the gas tank back on, and realized I lost one of the dampers. Oops.
Called a few local shops and no one had anything so I drove 40 mins to a huge motorcycle junkyard that I had been meaning to check out. That place is ****ING AWESOME!!! I found the damper, and the screw I was missing to hold the gas cap on the tank. My gf found a shift linkage for her Shadow VLX. Got the tank on, and the tail fairing. Bike wouldn't start... I plugged the battery back on the tender and went out for dinner. When we came back it started like a champ. Tomorrow I'll run her for a bit, then change the oil and install a new filter. I may check and clean the oil screen. Then, I'll do my fender elimination and wire the new rear turn signals. And I'll finally get to go for a ride
May 26th, 2013, 07:41 AM | #3778 |
63.3 MPG, wewt.
May 26th, 2013, 05:20 PM | #3779 |
Jersey Devil
Join Date: Oct 2012 Motorcycle(s): '06 Ninja 250 Posts: 469
Painted over the huge gash in my fender my bf left because apparently "my boyfriend did this!" stickers don't exist. Sexist mother****as.
Then I hack jobbed the clear because it was so thick and globby from being older but eh. It'll buff out. |
May 26th, 2013, 08:25 PM | #3780 |
drained carb bowls, added fresh fuel and a touch of seafoam. spark plugs tomorrow. new tires next week. fork springs and fluid week after that
May 27th, 2013, 05:53 AM | #3781 |
Join Date: Sep 2012 Motorcycle(s): 2005 ZX6R, 2011 Sprint GT Posts: A lot.
Rode it for the first time since buying the 650. Man is it different.
"The enemy is fear. We think it is hate, but it is fear." - Gandhi |
May 27th, 2013, 06:18 AM | #3782 |
MOTM - Sep '18, Feb '16
I drained the race gas out of it and put it in my lawn mower. It smelled like the race track.
May 27th, 2013, 06:44 AM | #3783 |
May 27th, 2013, 08:02 AM | #3784 |
Board Member
May 27th, 2013, 12:09 PM | #3785 |
Join Date: Jan 2012 Motorcycle(s): Ninja 250r - Track whore, Ninja 300 - SOLD, KTM RC390 - Orange Hulk, Ducati 899 Panigale - Red Devil. Posts: A lot.
I did something idiotic
and my bike got taken away by the cops... *sigh* I have it back now... But it was a major pain. I'm currently hiding my new 300 from certain family members and parked it in the club next door. It was parked there for about 3 days and They called the cops and had it towed... It was my fault because I didn't inform anyone about it. What an idiot... |
May 27th, 2013, 06:26 PM | #3786 |
Glad to hear you got it back
May 27th, 2013, 09:10 PM | #3787 |
Fast-Guy wannabe
MOTM - Jan '13
Installed RaceTech emulators, .80kg springs with 15wt. oil. Initially I installed 10mm of preload but my sag was at 42mm so I added 10mm of spacers for a total of 20mm of preload then my sag was 33mm. I'm running the stiffer yellow valve spring with 4 turns of preload but the bike still feels to soft for racing. Now it did feel quite good riding across town and this may be my street setup when I'm not racing but I'm going to call RaceTech and get their opinion on .85 springs and 20wt oil. I also took the opportunity to make some nice clean bottoming marks to see how much travel I'm actually using. With 90% braking force I would normally bottom out the suspension but now I've got around 15mm or so left.
I also installed this to monitor my rear travel as well. Only 4 days left till my track day so time is getting tight |
May 28th, 2013, 08:16 AM | #3788 |
Board Member
Yea...I did not like the rt setup.
May 28th, 2013, 01:38 PM | #3789 |
Fast-Guy wannabe
MOTM - Jan '13
Ordered .90kg springs for the front end so I can test .80, .85, .90 setting at the track this weekend. Also going to swap out the 15wt oil for 20wt to slow the dampening to something more similar to the sport bike suspension I'm used to.
I'm hoping to get my 31mm of sag with only 10mm of preload with the .90 springs in one or both legs. |
May 28th, 2013, 03:12 PM | #3790 |
Just different. I could smell clutch just from riding the 250 as I would the 650. I've quickly gotten used to the power that the 650 has, the 250 is like a toy almost.
May 28th, 2013, 03:13 PM | #3791 |
.80kg springs, 20wt fork oil, and GVE's were about as stiff as I would go in the front. You're a much better rider than I am though :P
May 28th, 2013, 05:57 PM | #3792 | |
Smell clutch? were you revving the crap out of the 250? I'm confused. |
May 28th, 2013, 06:09 PM | #3793 |
Damn Manufacturer!!! Finally got this darn thing off!!! I hate it when they put stuff too tight!!! 2006 Ninja 650R, but still!!, might be a problem with others ;-)
"Well, no matter what we did we could not get it off at all. We tried everything but no go!!! Heat, PB, WD, Elec. Impact, Air Impact, Tire On, Tire Off, and as long as 5' Breaker Bar, Specific (tight fitting) 32 MM 27 MM 31 MM sockets, And Nothing. It ended up so bad, GRNMSHN (aka: Whomp Stick) and I just "VERY CAREFULLY" cut the nut off with a Drimel, managed to skate away with ZERO damage to the Transmission Output Shaft" |
May 28th, 2013, 06:14 PM | #3794 |
Fast-Guy wannabe
MOTM - Jan '13
May 28th, 2013, 07:36 PM | #3795 |
I wired a switch into an H4 harness, so I can manually turn my HID on/off and use my LED halo as a running light Just need to splice a 12V regulator and some bullet connectors into my halo and I'm good to go. No more power usage issues for this guy, even on short trips!!
Added benefit is now my bike will look like those Bimmer headlights to approaching traffic. |
May 29th, 2013, 09:08 AM | #3796 |
Yeah the clutch on the 650 instantly grabs. I love it. I can almost just dump it. The clutch on the 250 is really light, and I just haven't been used to that. When I first got on the 650 at the dealer, the clutch was so freakin stiff. I'm glad it got a bit better. But yes, I was completely maxing the 250 out :P
May 29th, 2013, 01:12 PM | #3797 |
Ninjette Newbie
Join Date: May 2013 Motorcycle(s): '05 Ninja 250 Posts: 40
Nothing too fancy today. Just took her to the post office and went on a joy ride up Highway 1...they really need to fix the road in San Francisco, it would be an awesome ride if it was smooth sigh.
May 29th, 2013, 03:18 PM | #3798 |
Join Date: Mar 2013 Motorcycle(s): 08 Ninja 250R Posts: 29
Removed intake snorkel, shimmed the needles up by 2 (drywall bits work great if you can't readily find a JIS set), new air filter (temporary pods to come), redid wiring for the proton flush mounts with new bullet connectors, new electronic signal relat (Tridon EP34), clean chain. Just got back from a delightfully spirited drive and checked the plugs; right on the money right now. Much more to come with a new sprocket setup, emission block off plate, jet kit, full exhaust, and pods.
May 29th, 2013, 04:54 PM | #3799 |
Fast-Guy wannabe
MOTM - Jan '13
Got to ride my new suspension for the first time and I'd say its a lot better for the street. It has a much more planted feeling and soaks up road undulations a lot better, but in the end the biggest Improvment is the braking.
If you guys remember I don't exactly have stock anything front brake related a d although it was an improvment it wasn't as big of one as I had hoped. I always suspected the exaggerated front end dive when applying the front was keeping be from using 100% for fear of bottoming the front end going into a turn(happens all the time if I ride at a fun pace). Now with the stiffer front end I can give it 100% braking force with no fear of slamming the bumpers and I can easily lift the rear wheel if I so choose. After today I'm rethinking changing strait to the .90 springs in both legs and instead ill try just one so get a .85 rate. The jury is still out on wether ill change from 15wt oil to 20wt before the first day or after |
May 29th, 2013, 05:26 PM | #3800 |
Join Date: May 2013 Motorcycle(s): 2010 ninja 250 & 2001 Ducati Monster Posts: 20
Got Her a new tire since the last one got a freaking screw in it somehow!! Now she's handling smoother then ever.
Discovered something scary about my Ninjette today... | kjohng | General Motorcycling Discussion | 28 | October 15th, 2021 01:40 PM |
Sold the 2006 Ninjette today :( | Renner | General Motorcycling Discussion | 31 | October 16th, 2014 11:46 PM |
Today I Gave My Ninjette Wings! | BlueHairSar | Pictures | 5 | June 20th, 2013 07:38 AM |
my bro went down today on his ninjette | richierich781 | !%@*#$%!)@#&!%@ I crashed! | 46 | January 18th, 2013 11:59 AM |
Ninjette. org hacked today | CC Cowboy | Off-Topic | 9 | April 3rd, 2011 08:55 AM |
