Old November 9th, 2019, 06:51 AM   #1
lavarsios
Motorcycle(s): Ninja250r
Front brake issue!
Hello,
I have the following issue.When i press the front lever it seems like it stucks at a specific place and when i release it it goes back to normal braking.For example i want to put 100% pressure on the brakes but it stucks and let's say it goes only 60% pressure,if i release it and pull the lever again it softens and goes normaly.Many times you can hear a noise when i pull the lever like a crack or something.I can feel the stucking place in the pump and in the brake pistons also.I have hell brake lines,new piston seals in the brake caliper and cleaned the pistons before 5k klm or smth.I have made many bleeds and it seems to dissapear in the first 10 klm and then its back.I have cleaned the brake pump also and dissamble it and i couldn't find anything.Any idea?
lavarsios is offline   Reply With Quote
Old November 9th, 2019, 02:25 PM   #2
You need to lubricate both sliding-pins that holds caliper to bracket (not brake-pad pins). These pins allow one-sided caliper to move laterally to centre itself over disc. Use only high-temp silicone grease. Regular axle/bearing grease will overheat, dry-up and turn into glue, causing you problems you're having.
Old November 11th, 2019, 12:43 PM   #3
lavarsios
You were 100% right although i used lithium based grease (as per my mechanic's instructions).THanks a lot!
Old November 11th, 2019, 05:55 PM   #4
nocturncal
nocturncal's Avatar
Motorcycle(s): '09 Ninja 250R
can white lithium grease stand up to a high temp application?
Old November 11th, 2019, 08:50 PM   #5
Not for long. He'll just have to redo it in 3-6 months.
Old November 12th, 2019, 10:29 AM   #6
lavarsios
i usually change pads every 6-7 months so im fine with that
Old November 13th, 2019, 07:04 AM   #7
SibSerge
I have been using this for many years in my cars with no issues. As cold as to -25C and its rated to +200C
https://www.homedepot.ca/product/per...ase/1000843847
Front Brake Cable issue w/ Driven Clip-ons Sirena 2013 - 2017 Ninja 300 Tech Talk 9 April 2nd, 2015 11:08 AM
Brake Light Issue/Front Master Rebuild? TDMX595 1986 - 2007 Ninja 250R Tech Talk 5 October 24th, 2014 05:23 PM
front brake issue gantt 2008 - 2012 Ninja 250R Tech Talk 15 July 13th, 2014 11:39 AM
Front Brake Issue nitehawk 2008 - 2012 Ninja 250R Tech Talk 5 October 15th, 2013 09:40 PM
Front brake issue. Myst420 2008 - 2012 Ninja 250R Tech Talk 1 May 17th, 2010 01:34 PM
