Old May 16th, 2012, 05:24 PM   #1
Stingray1000
Stingray1000's Avatar
Motorcycle(s): 2003 Kawasaki Ninja 250R
So what is the petcock exactly for....
and when should I use it? Can someone explain the exact operation for each position of this valve?
http://www.facebook.com/groups/DeMdNjPagrouprides/
I live my life a quarter mile at a time!
Who is affraid of the big bad jiggles???? LOL
Stingray1000 is offline   Reply With Quote
Old May 16th, 2012, 05:26 PM   #2
prime: when the carbs are empty and you want to quickly fill them up (because you were servicing the carbs and you emptied them)
on: everything else.
edit: i see you have a pregen. that means you have a "reserve" option also. the petcock has two inlets, the normal inlet which is about an inch above the bottom of the gas tank, and the "reserve" inlet which is at the very bottom. when you start to get low on gas, the normal inlet stops sucking gas so the bike dies so you are aware you are about to run out of gas... then you switch to reserve and drive to the gas station, then flip it back.
Old May 16th, 2012, 05:30 PM   #3
There's a sticky thread in this section to the owners manual for your bike:
Kawasaki Website links: Parts Diagrams, Service Specs, Owners Manual
On pages 31&32 of the manual, it has a picture of the petcock and what all three positions should be used for.
Old May 16th, 2012, 07:23 PM   #4
According to the MSF, you are supposed to switch between off and on/reserve for every ride.
Petcock Filter Anyone? woodyshin 1986 - 2007 Ninja 250R Tech Talk 9 November 8th, 2021 05:52 AM
Petcock gaskets? MasterCylinder 1986 - 2007 Ninja 250R Tech Talk 15 September 12th, 2013 06:02 AM
Petcock jconolty 2008 - 2012 Ninja 250R Tech Talk 1 May 30th, 2013 01:42 PM
Vacuum nipple came off petcock - fix or replace petcock? fierostetz 1986 - 2007 Ninja 250R Tech Talk 3 November 24th, 2012 11:03 AM
petcock akcalhoun 2008 - 2012 Ninja 250R Tech Talk 1 August 7th, 2012 06:50 AM
