Old June 23rd, 2012, 05:56 PM   #1
emoyer
emoyer's Avatar
Motorcycle(s): 1999 Honda VFR800
Starting Problem
Hi everyone. I hope some folks will have some ideas about this. Sorry it is long.
Occasionally when I push the starter button on my pre-gen, nothing happens. This started maybe 1500 miles ago and has been happening with increasing frequency.
At first I thought it was a problem with one of the safety switches, so I would work the clutch a few times and put the kickstand down and back up, and hit the button a few more times, and eventually it would crank.
A couple nights ago I noticed that even though "nothing happens" when I push the starter button, the neutral & oil lights dimmed a little, which makes me think current is going somewhere, which I dont think would happen if one of the safety switches was preventing a start.
Today it happened again and it was the worst ever. I might have pushed the button 25 times, along with checking fuses, etc. When I finally got home and put the bike back on the battery tender like i always do, it took maybe 6 hours for the LED to go green, which is much longer than usual. So it seems like what happened really clobbered the battery.
So what I am wondering now is whether there is something wrong with the starter motor, that it just sometimes lets current run through but doesnt turn. Does this make any sense? If I put a voltmeter between the wire to the starter and the frame when the problem happens, and if I get 12 V when I push the button, would this prove that the motor is the problem??
Any other ideas?? Thanks. --Eric
emoyer is offline   Reply With Quote
Old June 23rd, 2012, 06:07 PM   #2
86ninja
86ninja's Avatar
Motorcycle(s): 1986 ninja 250r
Battery is weak or the starter solenoid
86ninja is offline   Reply With Quote
Old June 23rd, 2012, 10:13 PM   #3
Mocha Man
Blue Shell magnet
Mocha Man's Avatar
Motorcycle(s): 1997 Ninja 250
I noticed the same problem today. Sometimes unless I have it fully choked the bike won't even sound like it's trying to turn on, even if it has already been warmed up earlier.
Also, sorry for the lack of my correct terminology. I'm still learning all this stuff
Mocha Man is offline   Reply With Quote
Old July 3rd, 2012, 10:29 AM   #4
JLinde1339
Fighterer in Training
JLinde1339's Avatar
Motorcycle(s): 2001 Ninja 250R
I have had this problem on my 01. I usually fiddle with the key (turn it to off then on) and it will start. I thot my issue is the ignition
JLinde1339 is offline   Reply With Quote
Old July 3rd, 2012, 11:00 AM   #5
sounds like a short in the starter circuit before the solenoid. like on the wiring connector that goes to the solenoid.
Problem starting bike soliman 2008 - 2012 Ninja 250R Tech Talk 17 October 12th, 2014 12:16 AM
Peculiar starting problem Tom504 1986 - 2007 Ninja 250R Farkles 4 November 6th, 2012 07:11 PM
starting problem b4lt1m0re 2008 - 2012 Ninja 250R Tech Talk 15 September 13th, 2012 04:03 PM
having an intermittent starting problem! davidfriend 1986 - 2007 Ninja 250R Tech Talk 8 April 18th, 2012 05:16 AM
starting problem gogiburn 1986 - 2007 Ninja 250R Tech Talk 14 July 29th, 2010 03:24 PM
