Old July 16th, 2012, 05:47 PM   #1
SPG
Motorcycle(s): 250 Ninjette
Help! Need RossoII tire pressure
I'm at the track and planning to ride tomorrow, but I don't have any idea where to start on tire pressure. I have a 110 SC1 on the front and just replaced the 120 SC2 on the back with a 140 RossoII. Any help with cold pressures (and hot for future use) would be appreciated.
Thanks in advance.
-Sean
SPG is offline   Reply With Quote
Old July 16th, 2012, 08:16 PM   #2
Zyconic17
Motorcycle(s): 2010 Ninja 250r Track bike, Honda CRF250r Dirt bike
I have been running 28-29psi HOT in the rear. it slides predictably and has the bike feeling pretty stable. When not using the warmers, I set them at 25-26psi COLD. although I am just your average track day junkie...not an expert or anything. so take it how you will
Zyconic17 is offline   Reply With Quote
Old July 16th, 2012, 11:09 PM   #3
abhijitz
Motorcycle(s): Many Two Wheels ..
26-27 Psi Cold.... Monitor your track ambinent temperatures and "hot" tire wear. Hot Psi may need to go up by 1-2 psi based on tears.
Feedback from riding at Laguna, Infineon, Thunderhill (Thill being hottest)
[ex-AFM #828 | SMUSA #828 |
Sponsors : MotionPro | LeoVince | Insurrection Racing Gloves | QstarZ Laptimers
+ OEM Parts @ 30-40% OFF : Harry @ 1-877-437-1631,17 harry@hondaeasttoledo.com
abhijitz is offline   Reply With Quote
Old July 17th, 2012, 12:32 AM   #4
KazMan
KazMan's Avatar
Motorcycle(s): none yet
Sean, start with 28 front and 26 rear cold. I'm assuming you're up north in Washington and either riding at Seattle or the Ridge which is a little cool at that moment. As Abhijit mentions, if you see tearing on the rear tire, bump it up a pound and check again.
Have fun where ever you are, both are fun tracks!
KazMan is offline   Reply With Quote
Old July 17th, 2012, 05:59 AM   #5
SPG
Thanks guys! I appreciate the speedy replies.
-Sean
Old July 17th, 2012, 12:08 PM   #6
Rexbo
CVMA / AFM / M1GP #250
Rexbo's Avatar
Motorcycle(s): 2009 Ninja 250r, 2011 Zero S, 2009 KLR 650
I don't know how much you weigh, but I tend to run a psi or two lower than what these guys are saying, just check the tire wear after a few sessions and get them where you feel good. But yes, 28 psi front 26 rear cold is a good place to start.
Rexbo is offline   Reply With Quote
Tire pressure gauges Soujyu General Motorcycling Discussion 44 April 4th, 2015 07:20 PM
Tire pressure question krapzed General Motorcycling Discussion 5 August 6th, 2014 11:00 AM
Best tire pressure ... Davis937 1986 - 2007 Ninja 250R Tech Talk 17 February 17th, 2014 02:25 PM
Bt-45 tire pressure indr 2008 - 2012 Ninja 250R Tech Talk 1 July 5th, 2011 09:05 AM
Tire pressure.... Davidb1986 2008 - 2012 Ninja 250R Tech Talk 31 May 24th, 2010 12:59 AM
