Old August 31st, 2012, 05:56 PM   #1
02337
Motorcycle(s): 03 ninja 250
Front tire resistance?
Change the fork oil today and upon reassembly of the tire I noticed thy when tightening the nut the tire encountered a lot of resistance the tighter it went, I have the speedo meshed correctly or so I think from everything I've seen. I get about 30ft lbs of torque and it wants to stop spinning. I know the manual calls for 60ft lbs. any suggestions?
02337 is offline   Reply With Quote
Old August 31st, 2012, 06:02 PM   #2
something is not correct. check both the wheel spacers are correctly oriented
Old August 31st, 2012, 06:09 PM   #3
Agree !
Don't force things; you are putting stress on the brake disc.
Old August 31st, 2012, 07:43 PM   #4
02337
There's only one wheel spacer correct? On the right side then the speedo on te left. The caliper is not hooked up so brakes weren't affecting everything. The axle bolt slides right into place. Matched up the notch on the speedo assembly between the 2 on the fork. Really don't know what I'm missing at this point.
Old August 31st, 2012, 07:51 PM   #5
http://www.ronayers.com/Fiche/TypeID...up/Front_Wheel
http://faq.ninja250.org/wiki/Reinsta...he_front_wheel
Are you sure that the speedo is in the right position respect to the fork (it has a false position) and the coupling 41064 is not binding?
Old August 31st, 2012, 08:05 PM   #6
02337
I'll double check. I can snap some pics of which direction the speedo is in. The speedo is in similar position to,
http://www.obairlann.net/reaper/moto.../speedo-drive/.
Oh and nice sig Alex....
Clutch in / resistance in 1st gear normal? Bob2010 2008 - 2012 Ninja 250R Tech Talk 3 August 28th, 2012 06:21 PM
[roadracingworld.com] - Bridgestone: New Spec Front Tire Is Now The Standard Front Ti Ninjette Newsbot Motorcycling News 0 June 12th, 2012 10:20 AM
Which Material is Best for Gear? Abrasion Resistance Tests gfloyd2002 Motorcycle Gear 1 April 15th, 2011 04:47 AM
tire upgrade question: front tire? stryder 2008 - 2012 Ninja 250R Tech Talk 1 April 5th, 2010 07:40 AM
