Old October 5th, 2012, 02:03 PM   #1
rabies
time is running out....
rabies's Avatar
Motorcycle(s): pregen ninjari
bike wont start. fuse box is buzzing
im stuck in some other city in the cold :/
i turn the key and hit the start button. and the fuse box buzzes.
i put my hand on the fuses n it buzzs right on the 30a fuse.
its not blown n i switched it with another.
lights come on and battery is somewhat new.
not sure what happened obviosuly. i rode it here then this
The King
rabies is offline   Reply With Quote
Old October 5th, 2012, 02:08 PM   #2
sounds like the starter is not connected... try wiggling the wire going to the starter... it might be hard to get to it.
if you are stuck you might try bump starting it... put it in 3rd with the key on and kill switch on, push with clutch in, hop on and let the clutch out quickly but smoothely
Old October 5th, 2012, 02:38 PM   #3
if you hear the relay click you know the problem is either the relay, the battery, or the starter.
Old October 5th, 2012, 03:50 PM   #4
rabies
rabies's Avatar
thumper64 came to the rescue with another battery and multimeter.
meter told me the battery was givin 13v
the other day i put a car charger on the battery. he said that could have killed the amprage of it.
yup.
switched out the battery, started right up
The King
Old October 5th, 2012, 04:42 PM   #5
thumper64
Lesson of the day, use a motorcycle battery charger for motorcycle and ATV batteries. That's the only explanation, something inside the battery went wrong after that since the battery was supposed to be fairly new. Normally I would use a load tester since it tells you more about the batteries condition, however I don't know if a car battery tester would work on a bike battery. The battery had like 13.5 volts, which we both thought was enough. A load tester probably would have indicated something wrong.
Motorcycle noob, feel free to ignore me.
thumper64 is offline   Reply With Quote
Old October 5th, 2012, 04:47 PM   #6
you're lucky the battery didn't catch fire on that charger
Old October 5th, 2012, 09:09 PM   #7
rabies
rabies's Avatar
that would hav actualy been cool..jus sayn
The King
Old October 6th, 2012, 07:59 AM   #8
Copied from http://batteryuniversity.com/learn/a...surface_charge
"During use, and especially on overcharge, the water in the electrolyte splits into hydrogen and oxygen. The battery begins to gas, which results in water loss. In flooded batteries, water can be added but in sealed batteries, water loss leads to an eventual dry-out and decline in capacity. Water loss from a sealed unit can eventually cause disintegration of the separator. The initial stages of dry-out can go undetected and a drop in capacity may not be immediately evident."
Old October 6th, 2012, 08:26 AM   #9
rabies
rabies's Avatar
can anyone tell me what this relay is for. and these 2 connectrs that hav been swingin since i got the bike
The King
Old October 6th, 2012, 08:38 AM   #10
Looks like the turn signal relay.
I can't really tell from that picture, but it's on the right side right underneath the curvy part of the seat, has 2 orange wires, and a 2-pin connector right? If so, that's the turn signal relay.
Old October 6th, 2012, 08:47 AM   #11
rabies
rabies's Avatar
yessir thank u
The King
Old October 6th, 2012, 01:09 PM   #12
thumper64
Also, what are the two female spade connectors by the fuse box? There's also two up by the headlight. We both have these just dangling and neither of us have any idea what they're for. Special wiring for JDM grip warmers?
Old October 6th, 2012, 01:12 PM   #13
They are 12 v accessory plugs (always hot !!)
http://faq.ninja250.org/wiki/What_ar...to_anything%3F
Old October 6th, 2012, 03:40 PM   #14
rabies
rabies's Avatar
i actualy jus opened up all the wiring today and deleted them. along with the turn signal wiring
The King
- - -Bike Wont Start - - - Triple R 2008 - 2012 Ninja 250R Tech Talk 1 July 31st, 2014 06:54 AM
No start, click from fuse box, batt is good WAGESLAVEesc 1986 - 2007 Ninja 250R Tech Talk 17 June 7th, 2014 04:09 PM
Fuse removal and buzzing Jiggles 2013 - 2017 Ninja 300 Tech Talk 13 April 3rd, 2013 09:38 PM
Bike wont start, please help? zev42 2008 - 2012 Ninja 250R Tech Talk 11 November 9th, 2010 01:02 PM
uhh, bike wont start. ajaygraci 2008 - 2012 Ninja 250R Tech Talk 37 June 24th, 2009 06:39 PM
