Old April 20th, 2013, 07:12 AM   #1
!!(0_o)!!
!!(0_o)!!'s Avatar
Motorcycle(s): 03 ex250
Front end wobbles
So. I was riding the other day with my roommate and he and I both noticed my bike seemed to be a little "shifty" in the lane I was traveling. It was mostly due to crosswinds I thought but later I let go of the handlebars to adjust myself after a nice pothole and the bike tried to pull to the right. Hard. Could this be an alignment issue? My back tire seems to be on straight, but my chain is really tight. Could that have anything to do with it?
!!(0_o)!! is offline   Reply With Quote
Old April 20th, 2013, 07:16 AM   #2
Pulls to the right. Two issues that come to mind.
Either
1) Your forks are twisted in the triples. Jack the front up, loosen the triples, kick the wheel a few times, and then tighten the clamps back up. Try this first.
http://faq.ninja250.org/wiki/I_need_...d_misalignment
Or
2) Your head bearings are shot. You have a couple options here. Either replace with OEM bearings, or install tapered roller bearings.
http://faq.ninja250.org/wiki/Steerin...ng_replacement
Old April 20th, 2013, 09:38 AM   #3
Originally Posted by !!(0_o)!! View Post
.........Could this be an alignment issue?..........
Yes:
http://www.ninjette.org/forums/showt...ight=alignment
/ (Front wheel follows direction of rear wheel)
(Real wheel shown as out of alignment respect to the bike's frame)
Old April 20th, 2013, 10:09 AM   #4
I guess it could also be because of your rear wheel alignment. Double check that. I like to use the string method.
Definitely adjust the slack of your chain. Too tight can be a serious issue. When adjusting the rear wheel, remember that the left side is to adjust chain slack, the right side is to align the wheel.
Old April 20th, 2013, 02:45 PM   #5
!!(0_o)!!
!!(0_o)!!'s Avatar
Yeah I'm going to check my alignment. I'll update when I get done. I'm about to replace my wheel bearings I guess I should go ahead and order my steering bearings, too.
Front End Wobbles kkim 2008 - 2012 Ninja 250R Tech Talk 318 May 25th, 2015 07:01 AM
Upgraded front suspension, front end tuck Ginganinja 1986 - 2007 Ninja 250R Tech Talk 12 October 30th, 2014 10:27 AM
1999 Ninja 250r - When riding front wobbles/feels loose 99Ninja 1986 - 2007 Ninja 250R Tech Talk 4 August 25th, 2014 05:31 PM
Speed Wobbles parox91 1986 - 2007 Ninja 250R Tech Talk 11 September 25th, 2013 08:35 AM
WTB 08+ Front Brake lever/Bar End/ Front Turn Signal 1LoneWolf Items Wanted 3 July 8th, 2013 02:50 AM
