Old June 17th, 2013, 09:55 PM   #1
tsdexter
Motorcycle(s): 2008 Ninja 250R - Kawi Green
Headlight out/fuse blown...
Before I got crazy getting Into electrical I just want to be sure it's not super simple... My low beam bulb is blown, high beam bulb is in tact. The headlight fuse is also blown and as soon as I put in a new fuse it blew...
So before I tear everything apart... Is it possible that the blown low beam causes the high beam not to go on (since high = low and high) and causes the fuse to blow right away? I don't want to just pop in another $20 bulb and see just in case there is a short somewhere and it ruins the new bulb..
Sorry about the Noob, I'm learning it all slowly...
tsdexter is offline   Reply With Quote
Old June 18th, 2013, 05:11 AM   #2
No need to go crazy.
If the low beam bulb is still in place, remove it, because that can be the cause of the short.
Old June 18th, 2013, 10:33 AM   #3
tsdexter
Not sure it is.. I've got an auto voltage tester... Lights up at both sides of the fuse, doesn't light up inside the headlight plug/clip at the back of lights and doesn't light up at the high/low switch on the left handle... This makes it complicated doesn't it?
Old June 18th, 2013, 10:41 AM   #4
You will find voltage at those points only when the engine is working.
This recent thread includes links to schematics and some helpful tips:
http://www.ninjette.org/forums/showthread.php?t=135883
Old June 18th, 2013, 12:43 PM   #5
tsdexter
Oh ****, I totally forgot about that, I only had it turned to ON. Not running. Sweet, might make it easier for me
That schematic goes a bit over my head haha.
Blown fuse. Then another. mrudich 1986 - 2007 Ninja 250R Tech Talk 34 July 30th, 2020 08:26 AM
Headlight fuse keeps blowing iangee 2008 - 2012 Ninja 250R Tech Talk 5 May 26th, 2012 01:00 AM
Keep blowing headlight fuse! Hexdex 2008 - 2012 Ninja 250R Tech Talk 8 October 26th, 2010 07:01 PM
where to buy headlight fuse ? tac12345 2008 - 2012 Ninja 250R Farkles 6 July 15th, 2010 06:40 PM
blown headlight fuse sombo 1986 - 2007 Ninja 250R Tech Talk 15 July 4th, 2009 11:00 PM
