September 11th, 2013, 01:18 PM | #1 |
Float bowl leak (I think)
Problem number 2...
After the bike has been running for a minute or so the middle of the carb starts dripping A LOT of fuel... I've determined it to be the float bowl gasket... I just rebuilt it with new gaskets but apparently they are too small diameter-wise to seal... Then when I take them out of the bowl itself they're too long to fit back inside the groove... Is there a cheaper alternative than speaking 30$ on just a small gasket that'll probably do the same thing again? Maybe some engine rebuild (black) gasket maker? |
September 11th, 2013, 01:30 PM | #2 |
Is there a hose on the overflow tube?
Yellow 2003 Ninja 250 |
September 11th, 2013, 01:48 PM | #3 |
September 11th, 2013, 02:16 PM | #4 |
I recently replaced the seals on my bowls and they dont leak. Did you use the oem seals? Did you clean the surfaces thoroughly before installing them? I believe mine had some kind of sealer in them that I had to clean out. My only other thought would be is the mating surface on the bowls or carb is warped.
September 11th, 2013, 02:31 PM | #5 |
It was from the K&L rebuild kit. The problem being when it is completely seated in the groove it is still lower than the metal itself. So it won't seal right.
Cheapcycleparts seems to have a set of 4 replacement gaskets for various carbs for 16$ but I'm a bit skeptical after the proper rebuild kit didn't work. |
September 11th, 2013, 02:37 PM | #6 | |
September 12th, 2013, 06:03 AM | #7 | |
September 23rd, 2013, 08:09 PM | #8 |
Blargh! The issue is still not fixed... Just as bad as it was.
I bought a new gasket set from K&L and the gaskets fit perfectly... Everything is nice and tight. Here's the weird part. When the bike runs with the fuel tank connected it leaks like there is no tomorrow. When the bike runs without the fuel tank connected it doesn't leak, regardless if I have the petcock vacuum line connected or not. I immediately took the carb off after it started leaking and saw it was damp only around the float gasket area. Nothing higher then that. The overflow is bone dry. Just short of buying another carb (don't want to since I just spent a bunch rebuilding this one) I'm out of ideas since gasket sealant is no bueno for carbs... Help please I want to ride again. =( |
September 24th, 2013, 07:20 PM | #9 |
i have the same !@#$%$$#%$%^ !!! problem last time i put extra silicon blue gasket on the services and still leaks
September 24th, 2013, 07:48 PM | #10 |
The problem is in the floats, the float's valves soft parts or the seat of the valves.
Floats could be leaking and sinking. The soft parts of the valves may be hardened or broken. The seats of the valves may have developed some hard sediments that prevent the valves from closing completely. Grab a magnifier !!! You can do all those tests with the carbs out and using a long hose that mimics the height of the fuel inside the tank respect to the floats' valves.
September 24th, 2013, 10:54 PM | #11 | |
September 25th, 2013, 08:13 AM | #12 |
If the two valves themselves are new, you will need to take a magnifier and check the edges of the orifices on which they seat to close.
Those should be clean and flat; otherwise, you will need to use some mototool and some dental paste to eliminate any irregularities or pitting. One of both floats may be puncture (you will see fuel inside) or having their movement restricted preventing them from reaching total closing position. Maybe everything is new and working as intended, but the fuel level has been reset too high by accident. Look around here for specific height for that fuel level or for the floats respect to the flat edge of the body. Read these references: http://faq.ninja250.org/wiki/How_do_..._the_floats%3F http://forums.ninja250.org/posting.p...&t=85429&tro=1
September 25th, 2013, 11:15 PM | #13 | |
Those links don't work. Found some videos on float height adjustment so I'll try that real quick and update soon. Thanks. |
September 26th, 2013, 06:54 AM | #14 |
Ok so neither float is punctured.
I tried blowing through a hose connected to the fuel inlet and it seemed either I'm blowing too hard (no idea what kind of pressure I'm looking for) or both of them might be leaking the same... New plot twist... I think the leak might definitely be else where... It's gotta be part of the make fuel inlet. It doesn't matter which way the floats are adjusted, I still got the same leak. Now the leak is more immediate. I don't even think the floats are filling up since they start leaking after only a few seconds of cranking (not even starting up). That is with everything bone dry. They still only leak with fuel tank attached... What else could be leaking that far down? I'm about to give in and take them to a shop to fix them. |
September 26th, 2013, 11:03 AM | #15 | |
http://faq.ninja250.org/wiki/How_do_..._the_floats%3F http://www.ninjette.org/forums/showt...ighlight=85429
September 26th, 2013, 03:45 PM | #16 |
Join Date: Jan 2013 Motorcycle(s): 1987 Ninja 250 custom gold Posts: 218
Although this is most likely not your case, i feel like i should mention it.
Every time i rebuilt the carbs, they would leak a little bit around the bowls and after some circulation, they would stop. This also happened to other people on this forum. |
September 27th, 2013, 06:28 AM | #17 | |
September 27th, 2013, 08:39 AM | #18 |
You sure the fuel hose is good? Is it leaking at both carb bowls?
Pull the carb out, and get some food color with some water, and fill the fuel feed hose with the color water and see where it leaks out of. I just ordered a rebuild kit from murphskits.com.
September 28th, 2013, 06:27 AM | #19 | |
It better not be the feed hose from the petcock/filter, it's brand-spankin new. I'll double check it just in case though... How would I get water into the carb bowls without it going in the engine? Doesn't it require some pressure? I'll give it a try though. |
October 8th, 2013, 05:59 AM | #20 |
Round 2...
Adjusted the float height to the correct height. Turns out I was way off on it BUT before I adjusted them to the correct 17mm height I had them way under the correct height so the bowls would have been super low and they still leaked... Fast forward to yesterday with the correct height... Here is what happened. |
October 8th, 2013, 06:43 AM | #21 |
Can't tell from the angle and position but I am assuming that you are leaking from your pilot screws. Might be worn or broken if it's leaking from there.
http://www.ninjette.org/forums/showp...3&postcount=16 Have you tried to "feel" where it's leaking from?
October 8th, 2013, 09:20 AM | #22 |
Well it's dripping off of the RPM idle adjuster bracket but that's good point... I'll have to take those out and look at it. They do have this weird squeak to it when I turn them. I'll check that.
October 8th, 2013, 09:30 AM | #23 |
pilot screw/needle - spring - washer - o ring
October 8th, 2013, 09:59 AM | #24 |
Trace the fuel line down from the petcock to see if it's wet anywhere. Also look at the point where it enters the carb. If the hoses have been off a few times they may just be stretched loose on the ends. If that's the case you may be able to trim off some to get it to fit tighter.
From what I can tell, I don't think it's related to the float bowls/gaskets - it's higher than that. |
October 8th, 2013, 02:58 PM | #25 | |
I'm gonna be inclined to try the food coloring trick if I wasn't so worried about gumming up the carb. |
October 8th, 2013, 06:56 PM | #26 | |
Pretty sure the fuel level wouldn't be high enough to flow fuel out the bowl gasket unless there was a problem with the float/needle/seat. |
October 16th, 2013, 04:18 AM | #27 |
Took out the a/f needles... It would appear there is no washer between the o-ring and the spring on both of them... Go figure. Wish I could find the remains of my rebuilt kits and see if there is an extra washer. =/
December 17th, 2013, 03:47 PM | #28 |
How can I be this bad at carbs???
Update... carb is still leaking from the middle between the carbs. I thought it might be flooding the boots but doesn't make sense why it would flow around it plus the area around the boot inlet look dry. As it sits, it runs fine [too rich though but can't get it to a point to adjust it yet] and only leaks when gas is flowing through the fuel filter (no leaks around the petcock or the fuel filter). I can disconnect the petcock and the bike will still run and it won't leak. Here's what I've done since last post. -> float bowls = brand spankin new seals -> A/F needles = new gaskets and washers (loosen 3 turns versus the recommended 2-1/2 turns) -> brand new needle valves -> area where needle valves open and close has been polished and cleaned up (it looked so pretty) -> floats checked for air leaks and none were found (can hold them under water and still want to float to the surface) -> floats adjusted to 17mm (+-1mm) -> New development: Petcock flows gas for a few seconds on start up then stops completely while the bike still runs. I have 2 separate petcocks that do the exact same thing. Even interchanged diaphragms and no difference was made. There is still vacuum being pulled from the carb to the diaphragm. So much disappointment. =( |
December 18th, 2013, 10:53 AM | #29 | |
Join Date: Apr 2013 Motorcycle(s): 2005 Ninja 250, 2006 SV650N Posts: 642
December 18th, 2013, 01:33 PM | #30 |
Filter isn't clogged.
December 20th, 2013, 10:16 AM | #31 |
See if you can get your hands a on a used pair of carbs that are in good condition. There are tons right now on ebay.
http://m.ebay.com/itm/121235502567?nav=SEARCH&sbk=1 Last futzed with by agentbad; December 20th, 2013 at 11:36 AM. |
Float Bowl Screws | kaybray | 2008 - 2012 Ninja 250R Tech Talk | 2 | December 16th, 2012 02:51 PM |
I need some float bowl gaskets ... | Jim Moore | 1986 - 2007 Ninja 250R Tech Talk | 9 | November 1st, 2012 10:59 PM |
Rear brake fluid leak (container leak?), any advice appreciated. | deaddemon | 2008 - 2012 Ninja 250R Tech Talk | 5 | November 6th, 2011 01:52 PM |
need float bowl gasket &/or oil screen | cuz | Items Wanted | 2 | October 19th, 2011 11:06 AM |
WTB: Float Bowl Screw, Gas tank fairing grommet | haze5736 | Items Wanted | 0 | July 19th, 2011 07:04 AM |
